HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
mtaylor
Moderators
Everything posted by mtaylor
  1. Nah... she won't do that if she's been watching court shows. Find a hit man maybe.....
  2. Nice work on the eyebolts, Nenad. Those things are tiny but look great.
  3. Thanks Piet. Mike, It's too big for the Death Star. The main backbone (false keel) is about 29" long. I've ordered "Lite" plywood which I'll let settle in before using it. I'm also planning on putting in spacers between the bulkheads to help.
  4. Shall I delete the two extras or leave them in for emphasis?
  5. I've tried the brush and thin CA. Be prepared to have a supply of brushes on hand as the CA sets up fast. Anything other than "thin" won't soak in a bit into the wood. I have used diluted white glue (water to dilute to "milky" consistency). Put it on, let it dry, and bit of sanding to take of any highspots.
  6. I wouldn't paint the outside that rolls on the deck. Iron banded wheels wouldn't have been used as they chewed up the deck. If it's a ship with the iron tracks on the deck then the wheels would have been iron also.
  7. Thanks Chuck. That sounds like good idea. The white inside is what is supposed to be left... but hasn't happened so some rework is required. I'm going to follow your advice anyway, no matter how I cut themb and I'll still do a test cut using the laser but 1/4" ply which might not be doable. I like your idea no matter what method. I'll include this in my testing for both the scroll saw and the laser. When I test the laser to mark the wood for cutting, I add double the blade kerf thickness, print out the cut sheet and cut just at the outside edge of the marks. So far, so good on that. With the long weekend, wood is not expected until Weds. or Thurs. <sigh>
  8. What Phil said. In many ways, we're not just builders but friends and when needed, a support group.
  9. Have you glued down he main deck? The top one? There's a gotcha' in the instructions and that's putting in and working on the gundeck. Almost impossible once the upper decks and walkways are on.
  10. Plenty of chairs and the popcorn is fresh. I'm just about done doing drawings and have actually cut a few piece of boxwood for the keel. But really on hold until the plywood gets here later this week. Seems the holiday got in the way of the delivery truck.
  11. Thanks gentlemen. The Belle Poule log is started (in my signature below), rework of the drawings is mostly done. I did a test cut for the false keel and tossed that result. I'm cutting some wood but basically on hold until later this week when the plywood order gets delivered. Once it's here, the laser gets a workout and the saw dust will really start flying.
  12. I'm happy you didn't wait on going in, Marcus. Hope the recovery goes well and is uneventful.
  13. I'd say go right ahead and do a log. Title using the guidelines and after the last post is made, add the word "Finished" to the title. We've had others do that also we've had some that started building before they found MSW.
  14. Johnathon, What the others said.... start a build log. You'll find it's great to get help.
  15. With wire, you'll some how have to stretch it to get to look right. I'd go for the thread.
  16. Welcome aboard Kevin and Carl. Popcorn is good. I re-considered some issues... like having a false keel in 4 parts. Too much room for idiocy on my part. So... redrew it a single unit. Looks better now. I'm happy the wood order hasn't arrived yet. It should work out better now. I did move some bulkheads a very small bit and reworked them to not alter the ship's lines. Here's the false keel drawing (note that dimensions have been altered because "reasons").
  17. Hi Lukas, Welcome to MSW. Do start a build log. It's a great way to get help when you need it and to make some friends from all over the world.
  18. Check this Log out as Occre is using his work, which is good thing.
  19. Beautiful work. I do love the knives more than the pens though.
