Everything posted by mtaylor
Thanks Eric. I remember too well and somewhat miss that part of the country. Cahokia Mound, the rivers, and even the stone forts in southern Illinois. Lovely adventures and fascinating in their beauty. How bad is the flooding on the riverfront in St. Louis?
- 599 replies
- sidewheeler
- arabia
(and 4 more)
Ala-Kart by CDW - FINISHED - AMT - 1:25 Scale - PLASTIC
mtaylor replied to CDW's topic in Non-ship/categorised builds
Denis,, you've lived a sheltered life. I remember building it and also it getting destroyed when a bookcase fell off the wall. -
One of the best cars ever built in my opinion. There's a good article on Wikipedia. The one thing I did learn that it was rebuilt after catching fire from a fuel line leak. Memories and all that..... -
Welcome to MSW, Joel. Some groups say scratch building is building everything from scratch. Others go further in that you must draw the plans. We're a bit more open on the term. If take plans (more on that in a minute) and cut your own keel and bulkheads/frames, it's a scratch build. One can use kit plans, etc. As for the piracy issue... there are sites out there are offering plans and yes, many of those sites are pirating the plans. So if in doubt ask first here: https://modelshipworld.com/forum/13-ships-plans-and-project-research-general-research-on-specific-vessels-and-ship-types/
I've been looking into this issue from my Licorne... Having said that, I'm not 100% sure, so that's the disclaimer. I would suspect that yes, but not "cooling" as we know it and I'm not finding any references to "water". If a metal chimney is run up through the deck, it'll scorch the deck. The references I have only show a metal (for lack of a better word) "ring" or plate around the chimney and mates to the deck. There was no fabric or leather at this joint. If I discover anything more, I'll post it. Frolich's book only shows a metal plate. And Lemineur's book on Hermione shows the galley and plate. Same for the "74-Gun Ship" from ANCRE. The drawings are detailed enough to say anything beyond that. Does Ballu show any drawings?
From my readings and research on the models I'm building, Bob is right. The color of the tar depends on the rope, age, etc.
If you posted this, they you are now a member.
Quite a few from Missouri here. And also some us who used to live there. My self included (past tense, I'm in Oregon now). Cathead (building a riverboat currently) is in the southern part of the state.
Newbie paint questions...
mtaylor replied to CPDDET's topic in Painting, finishing and weathering products and techniques
Dave, The wipe on poly may be a problem. So might the ME paints. First off the Ms paints are reported to be "thick". The other problem is the poly. I suggest before you start buying anything, take a piece of scrap, apply poly as you did on the model and then try the paint on it. -
I'm confused (normal for me). Your post mentions gluing the "nuts" but the bottom photo only shows one. I hope that was just a test and you're doing a second mount point. Most excellent idea though getting it up and off the display base and also to hide the wiring. I think you'll have make a "box" so the wiring can run underneath it. Hit one of the home supply places. They often have some nice woods like cherry, etc.
Sweet. She looks right at home in the water.
- 79 replies
- pride of baltimore
- privateer
(and 3 more)
Welcome to MSW, Geoff. You've done a plank on frame so you probably have the basics down on the hull. Rigging skills are there from the plastic kits. I've not built the Snake but it may have it's challenges. I would recommend that you do start a build log when you decide on a kit as it's the best way to get help. Just go slow, and have some fun. Wooden ships can be challenging and overcoming them is the big reason why MSW is here.
Finding sheaves for small functional blocks?
mtaylor replied to FoxtrotHotel's topic in Masting, rigging and sails
Richard is spot on IMO. I did a couple that way before I ever bought a mill. -
I'm following along quietly and just loving the way the rigging is being done.
- 306 replies
- schooner
- la jacinthe
I'll go with Vossie and the "singing of angels".
I think Druxey has the right approach. Somewhere around here I recall seeing someone's rope dyeing method. Basically a spool of thread leading into the dye bath and coming out, it runs between two rollers like were on the old washing machines. From there, the rope went up to some hooks on the ceiling to hang and dry. The rope was draped over the hooks and hung down the almost floor level and them back up to the next hook, etc. Sounds a bit messy though so precautions like protecting the floor might be needed.
