Everything posted by mtaylor
I think the kit people got builders hocked on "black" as it's the color of tar. Road tar that is. Personally, I'd drop the black. As others have said, want black, it can be dyed. I did use black on my Constellation since that was how she was rigged in the photos when I built her. Hindsight, I should have went with browns or maybe off-white.
So they assume the pigments didn't change over time or pick up some color from next layer of paint? Interesting.
If you're nuts, so are the rest of us. At least we all gather in the same place. Birds of a feather and all that.
HMCSS Victoria 1855 by BANYAN - 1:72
mtaylor replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Have a great holiday season, Pat. Pumps look good.- 993 replies
- gun dispatch vessel
- victoria
Wow, doesn't it sum it up at all. I'm speechless. I think after looking over the exhibition I'm going to shut down my computer and wander off... totally overwhelming images of superb models.
Cutty Sark by Cuda1949
mtaylor replied to Cuda1949's topic in - Build logs for subjects built 1851 - 1900
Two ways that I know of Al. The best probably is it pin the yard to the mast in the proper location. The yard should at least be completely ready for it's rigging or even pre-rigged. The other way, and I'm not a fan of it, is to rig the yard, hoist it aloft using the rigging and them a spot of glue to hold it to the mast. You might have a look at way Rob is doing his: -
Very much not "small" Daniel. I think Wow sums it up. Looks like I'll be busy going through the exhibition for a day or two.
I'm 100% LED. Replacement was easy, just a trip to the local home supply store and bought in "bulk" boxes of 10. Depending on the room and need, I use both daylight and pure white. Cost wasn't that bad compared to incandescent.
Wonderful work on the lighting, Doris. The warm glow captures the time period and the whole effect is amazing.
- 1,035 replies
- royal katherine
- ship of the line
Beautifully stunning, Alan. Taking what Druxey said, I think someone at somepoint will comment that you were a trendsetter. It may not be authentic but it does stand out.
- 125 replies
- 9 pound naval cannon
- 3d cannon barrel
You need not be afraid. Everyone has been where you are and the amount of help is incredible.
Hi Mike. Welcome to MSW. That's the first time I've seen a model of one of those. I see them on Rogue here in Medford a lot and they just seem to be the peaceful way to fish...
Bucklers were port lids that were installed and then lashed into placed. No hinges or hardware to speak up. I hope the info helps. Very confusing times on the details back then. Even into the late 1700's, some French ships had port lids, others didn't. May have been Captain's discretion?
- 2,623 replies
- heller
- soleil royal
(and 9 more)
Marc, As I've discovered, the French usually didn't arm the first port on any ship. When no gun in place, they used it for ventilation and also during anchor handling. On many vessels, this port was somewhat smaller than the gunports. It was also, speaking generically, the only gun port with a lid on the upper gundeck. The other ports used bucklers. As always, your mileage and research may vary.
- 2,623 replies
- heller
- soleil royal
(and 9 more)
Vasa deck shift
mtaylor replied to BLACK VIKING's topic in Building, Framing, Planking and plating a ships hull and deck
Ah.. the original "check the scrap box, mate" when looking for lumber. -
No worries, Eric. I think I have the same disgust as you.
- 599 replies
- sidewheeler
- arabia
(and 4 more)
Jeff, Just a gentle nudge to do a build log. Also I also see in the Index that there's 8 unless I miscounted Billings kits, with one completed. Index is here (pick the ship kits):
Can you find a larger photo or circle the area in question? That whole area looks in shadow.
Welcome back, Keith and it's great the recovery went well. The model looks great.
