Everything posted by mtaylor
Copper Plating
mtaylor replied to Kurt Johnson's topic in Building, Framing, Planking and plating a ships hull and deck
Sounds promising, Kurt. The only potential "gotcha's" I can see would be the thickness of the paper might be more than the copper and that applying paint might wrinkle it. I look forward to your tests. Just a thought hit me... is there such a thing as copper colored wrapping paper for presents? Then dry brush your patina instead of a wash. -
Hit "edit" at the bottom of the post, then at the bottom of the post you'll see thumbnails. Hover the mouse over the offending photo. On the lower right of the thumbnail is a small trashcan icon. Click it.
Oscillating Wonder Cutter
mtaylor replied to Jim Rogers's topic in Modeling tools and Workshop Equipment
Yeee-ouch... $400!!! I'll keep my homemade cutter. I'm not that much of a tool junkie. -
I have a (since discontinued) filer/sander from MicroMark. Modified one the sanding attachments. Not perfect but it works. BTW, it looks like MicroMark is selling that Wonder Cutter or something like it. -
Might be time consuming, Mike but those will be worth the effort.
- 967 replies
- hahn
- oliver cromwell
One Ebay there's one guy (I think) selling the MB kits. Model Expo only carries a few kits. Best bet is Master Korbel directly if there's a kit you want that the other two don't carry. Shipping from Russia isn't that big of a problem.
- 216 replies
- masterkorabel
- ships
(and 3 more)
Beautifully done, Jim. I two am a fan of the "different than normal" models. The case and water base look great and add a lot to the model.
- 28 replies
- cannon jolle
- master korabel
Hello Jack, Fires seem to be everywhere this year. We've had our share here in the west of the US and while undamaged, I and others are deeply saddened by the loses. I hope you and your family and home there are harmed by the flames.
- 190 replies
- ragusian
- marisstella
Thank you for the likes and comments. Working on the model is going slow, but productive. I have a few nitpicking details to resolve before going to the planking stage. I hope to have an update soon. I'm planning on Swiss pear, Jim. It should give an nice contrast to blend with the other woods.
I've found research, even while frustrating at times, is half the fun. You're doing some impressive work on researching and building.
- 108 replies
- leon
- brigantine
If it's books, I can recommend Wolfram zu Mondfeld's Historical Ship Models. There are some errors in details but essentially it covers pretty much everything in period ships.
Kevin, They're a sponsor here. There's several build logs and also their topic for products, etc.
Thanks for the patience on this build, the advice, and the likes. It's been slow going what with personal issues, re-cutting some pieces, etc. Here's where I am on the this first ship's boat. The build jig has been built and the keel and the two risers on each side are installed. The risers still need a bit of tweaking as to some bits and pieces where the planking will run and then glue them into position. I'm pretty pleased with how it's going just need more time and focus. After the tweaks, the next step is to cut out the ribs and install them. I see from the photos, I need to do some more clean up of the char on the keel and the risers.
<Graps popcorn and heads to seat> I'm looking forward to this build, Dan.
- 238 replies
- leviathan
- troop ship
Looks like ball, tracer, armor piercing, and repeat. In aircraft it was 3 balls, tracer and AP as I recall. Not sure about the Navy though. Stunning workmanship and detailing.
Byrnes Table Saw Tips (requested)
mtaylor replied to Matrim's topic in Modeling tools and Workshop Equipment
Joss, Will this help? It's the page on sawing tips from our former (retired) wood supplier that owned and operated HobbyMill. I'm having a senior moment and have forgotten his name. Byrnes Saw Operation.pdf -
Master Korabel do have some interesting and well thought out and designed products. They (in my opinion) can give a new builder some insight into the finer points of scratch building. For example, the hull planks are pre-shaped which can give you insight on a scratch build.
