Everything posted by mtaylor
It's been awhile since I looked in. I like what you did to the shop and Cutty seems to be back in the yard and progress being made.
- 525 replies
- cutty sark
- mantua
Byrnes table saw blade for cutting planks
mtaylor replied to genericDave's topic in Modeling tools and Workshop Equipment
I love your work on your steel navy build, Greg. Just excellent eye for detail and great workmanship.
I would order a couple of each of the ones you'll need (for spares and to save shipping/handling) to cut the sizes of wood you'll use. I order mine from Thurston and they're good blades. http://www.thurstonmfg.com/cut-off-saws.html -
That's good and makes me smile as it reduce both your down time and your headaches.
- 1,784 replies
- winchelsea
- Syren Ship Model Company
I've found that brass rod isn't always as round as it should be, so I touch rod up in a lathe. If it's out of round that causes problems also.
- 954 replies
- hahn
- oliver cromwell
Sweet work, Jerry. I can't wait to hear the next sailing report.
- 553 replies
- sloop of war
- constellation
(and 3 more)
Thanks for looking in and the likes everyone. Thanks Pat. The laser is a blessing as I couldn't cut that accurately. I'm still sorting things out. I ended tossing the work above and re-doing it with some tweeking and am starting to plank, again with boxwood. I'm a lot happier with the mods I made a day ago or so. It also struck me that I should build the "big" boat first and work down from there, but no.. I have to do it the hard way, start tiny and get bigger.
Chuck, I think the reason for why the other "guys" don't flip to fit parts is that they never thought of it, or somehow tied into time and money.... not sure. On the laser rebuild... do it one step at a time and test/re-test before the next bit. I'd do the power supply first, the mirrors and then the tube. Take photos of the wiring and check then check again that the wiring matches. I found that if I aligned mirrors as I changed them out (one at a time) when I did the tube, there was minimal fiddling. It's a PITA to be sure but taking time, going slow and douible even triple checking pays off. Oh... don't try to splice the high voltage led (red) to the tube. If you must connect... solder the leads and lots of heat shrink insulation. Try to do that part in a place in the chassis where the joint is well away from any metal. Don't ask how I know... it still pains me to remember.
- 1,784 replies
- winchelsea
- 1,449 replies
Here's the documentation that was on one of our wood supplier's website. It's an excellent resource and includes his recommended blades... I'm having a brain f**t and even though I bought a lot of wood from him, I can't remember his name...<sigh> Byrnes Saw Operation.pdf -
I vaguely remember a monograph being offered for L'Ocean. I'll have to do some digging as to where but then, I might be remembering wrong.
- 2 replies
- french 74
- decoration
raising and lowering an anchor on a sloop
mtaylor replied to timboat's topic in Nautical/Naval History
Like a lot of things, the yards knew what was needed and things don't always show up in prints that were part of the ship. Is there a contract available for the vessel you're interested in as it should list what was there. -
Scientific Kit of USS Constituion No. 170
mtaylor replied to Nat Fay's topic in Wood ship model kits
Folks, when someone asks for an address, real, email, etc... send it to them a PM. This site gets crawled by bots and spammers so take precautions to protect yourself. Nat, I'd delete your two posts and if you can't contact a moderator. -
Welcome back, Pete. The shop is looking good.
No math really on tapering.... just tic strips and counting planks. There's tutorials here: https://modelshipworld.com/index.php?/forum/14-building-framing-planking-and-plating-a-ships-hull-and-deck/ and in the database here: http://modelshipworldforum.com/ship-modeling-articles-and-downloads.php Take a look at them and pic the one you like. There's a simplified method in the database.
- 15 replies
- joshuah humphreys
- frigates
(and 4 more)
We all work from plans... Rule for a scratch is if you cut the keel and frames/bulkheads, it's a scratch. BTW, it's great you got this moved.
- 122 replies
- independence
- privateer
Looking good, Ken. Since this is now a scratch build, change the title to reflect that and ping a moderator to move it.
- 122 replies
- independence
- privateer
Ah... this model is NOT one of the first frigates. The AL kit is a fraud. We had a total system crash back some years and lost everything so this is actually a kit bash. As I explained way back early on, what sits in Baltimore, which the plans were taken from decades ago, is the sloop of war from 1854. There were some shenanigans pulled when they acquired her to make everyone belief this was one of them. Drop the following into Google (minus the quotes) and you see what I mean: "fouled anchors the constellation question answered". Given that the plans for the orginal frigate have gone missing, there's really no plans to build the first Constellation. I was disheartened to find that out, but such is life.
- 28 replies
- artesania latina
- constellation
About halfway down the homepage, you'll see this: https://modelshipworld.com/index.php?/forum/9-members-build-logs/
- 15 replies
- joshuah humphreys
- frigates
(and 4 more)
No... not really. The bulkhead (POB) kits usually use plywood or similar and about the only decks to be built are the gun deck and upper decks fore and aft. Look at Chuck's Winchester (link below) as an example or almost any AL kit as examples. A POF would be like my Licorne and probably 80% of the scratch builds. POF more closely resemble actual practice and allow everything below decks to be done. Other than the Orniada I don't recall any of the Lumberyard's Hahn sets being precut for the frames. Bob Hunt (Lauck Street Shipyard) did some that fully framed. I've attached a link for one of those build.
As is my ilk, I tend to research, think, then jump right in. My next step is the ship's boats. I've been looking over the plans and sorting out to do this with out making a dog's breakfast of it. For the cutter and the barge (the two smaller boats) I'm going to use a modified jig. The longboat will be built around the plug that I already have made. This may change once I really get into things. Basically, I have a couple of old ME ship's boat kits.. a 5 inch and one that appears to be 6" (by their definition). To make a long story short, I took their instructions and modified the heck out of the plans and the thus, new parts, which I've drawn up and cut on the laser using boxwood for the keel, the stern, and first frame. The only seats will be the fixed ones at the rear and bow. I'll decide on what goes in this boat once I get it put together. But, historically, everything was removed, rudder, oars, the benches the rowers used, etc. and stored in the hold. The other two will be the same since the boats were stacked n the gundeck. The picture shows the keel with the stern structure and also the first frame. The stern structure gets planked externally first before doing the strakes. The frame has been modified for the forward "seat" instead of a bulkhead as some boats (other navies) had. As soon as I get the forms added to the build board, I'll start install the keel and start planking. Looks to be another small (size) fun part of the build.
