mtaylor
Moderators
Everything posted by mtaylor
  1. Nice work, Jim. With ratlines and treenails are both something we shouldn't ever count because we really don't want to know how many we did.
  2. In real life, the bricks already are dark and dirty looking. I'll try to get photo in natural light as the flash seems to have lightened them up.. or I have a camera problem.
  3. Smart man you are on naming her, Peter. Great looking model.
  4. A couple of questions.... Is the grain straight. If not, it will break. Soak and then heat (I use an old curling iron). Repeat as needed to get the bend you want. It is possible that the wood is just too dry to be used.
  5. I think that's normal for our work. Cut, go "yuck" and sand until it looks good.
  6. Copper, of course. I might be a masochist, but I'm not that bad yet... then again, model ships.. hmm..
  7. You are a true artist, Merchen. What I've seen would rival any carvings in any museum, ship museum or otherwise.
  8. There's lots of pics here: https://www.google.com/search?q=khalilah+yacht&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjog6Wk0c_aAhWDwVkKHdeUDmsQ_AUICigB&biw=1337&bih=769 Google is our friend. Sometimes.
  9. Mike, the cherry might just work very well. It does darken with age in the rich deep, I'm not sure I can call it red but it is beautiful I've used it and with the right woods for contrast, it works well.
  10. Hi Patrick You didn't miss it as I never mentioned it. It's model railroad brick wall. Appears to be a vacuum formed sheet of plastic. I tried making bricks but they were just too darned tiny. Each one is 1 inch (25mm) wide, .75 inches (20mm) deep and .625 inches (15mm) high.
  11. Since I'm working on the fireplaces, here's a picture now that the iron bars the pots sit on have been installed. I still have the exterior to plank and the pots to make. The flash made them redder than then actually are as they're more of a red-brown or rust color. I wanted them to look like they had been used.
  12. Unpainted PE? Won't someone think of the poor sailors who'll have to polish it every day?????? Ok..just being a butthead. So far, so good.
  13. Interesting, Jerry. Is it possible that the 1892 version was "test"? I would think that anything sliding up or down the mast like rope ring would have a problem with the rings around the mast. I looks like there are from the picture, but with these eyes, I could be wrong.
  14. Jason, I wondered the same thing also but that's the layout both using Hahn's plans and the one's I ordered from the British archives. Plus those ladders are coming up under the pinrail. This ship seems pretty compressed and packed as far as space on deck. The access below decks gets even more restrictive once the ship's boats are in as the large open hatchway will have a boat over it. Thanks for the comments on the pumps and for the likes. I'm working on Rev 4 of the stove/kitchens/fireplaces (depending on the translation) and I think these will be the ones. I did try two more times on the gun rigging but there's just no way. I'll give it another shot when I've completed the gundeck furniture.
  15. Count me in, Patrick. I love your subject choices and then the execution. Genesis looks to be a huge challenge and I daresay that you'll be up to it.
  16. You've got a good plan Piet. Coming together splendidly. I do think Lou is right about testing. The casting resin doesn't expand during curing does it? I've heard that some get pretty warm and also expands.
  17. That... exactly that. A very good plan in my opinion. I think I'm in the same boat but with one exception... my tools, wood supply, and ships all go with me.
  18. Make the hole just big enough to put eyebolt in. Some just bend the eyebolt "tail" 90 degrees, others drill the hole at an angle, and others just insert it into the hole. A little (very little) epoxy or CA will secure it in position.
  19. Excellent start. If you're using balsa, once everything is sanded, put a coat of 50/50 white glue and water on the balsa after it's shaped. It'll harden it up and help prevent dings and ouches.
