Everything posted by mtaylor
Interesting new model ship company
mtaylor replied to Erebus and Terror's topic in Wood ship model kits
Judging from the pics, I'm thinking that's the prototype. It does look, on the assembled pictures, that the char was cleaned off at some point. The Hanna looks to be a Hahn style from the way the frames are set. As for the others... Le Couronne might be ANCRE. The rest, I'm not so sure. They may not be copies but heavily "influenced"? Still, it's a good way to get into plank on frame. -
Deadwood.... Duh!!!! Somedays the words just don't seem to be there. I've got my fingers crossed. I think the technique will work if the initial tests that I've done are valid.
Thanks for the likes, the comments, and just checking up... I'm there... the keel is now where I want it to be. The two main mods are the bow and the stern areas. I've also reworked the formers for the ribs. The red circles show the areas that were the problem children and how they ended up. I eased the arc of the bow, made it a bit wider for the planking. The stern was the most radical change with the angle, and the (not sure of the word) bit where it now curves up into the sternpost. I'm putting it together so hopefully later this week, it'll be finished externally. I'm still deciding how much detailing of the interior such as seats, rudder stowage, oars, etc. Almost all of this was stowed in the hold when not in use, but I'm thinking "visual interest".
Very ingenious, Tom. Looks good and since it works well..that makes it great. Try some sealer on the guns..might help with the grain problem. I ran into that recently on a none ship project.
I do hope you had some fun, Jerry. Somehow I don't think she would have fit in that pond....
- 553 replies
- sloop of war
- constellation
(and 3 more)
I too, am catching up Nils. The crew brings her to life and gives the ship character. The detailing of the penents is a great touch.
- 692 replies
- eagle of algier
- chebec
You have captured what Hemingway wrote, Igor. Looking great!
- 131 replies
- bottle
- the old man and the sea
Brass Black
mtaylor replied to Nirvana's topic in Painting, finishing and weathering products and techniques
I find it curious and interesting that it works on britania metal. But good that it does. -
HMCSS Victoria 1855 by BANYAN - 1:72
mtaylor replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Very well done, Pat. That had to be some intense work with all the detail at that size.- 993 replies
- gun dispatch vessel
- victoria
I'm playing "catch up" and just of your brother, OC. I will keep him and you in thoughts and hope there's a joyous outcome to this.
- 455 replies
- slightly modified
- greyhound
Thanks for the likes and comments. Just a brief update.... I'm currently on version 4 or 5 (I lost count.. ) I tweek and then assemble some bits, decide if it's not good enough, not right, or I'm just not satisfied with it. Sooo... tomorrow, I'll be re-cutting the final (I hope) keel, stern section, and foremost bulkhead/ribs. I think i"m getting there. Hindsight says it's good to start small, less scrap with things go awry.
Ah yes, the Hobby Gods DO need appeasing now and then. i just wish they'd back off and say they had their fill of me but I guess it's possible that my blood is particularly tasty OR I need a lot to make a lot of sacrifices to atone for my hobby sins.
Spare torpedo and warheats under the decking? Just surprising to see that. Is there a hatch or some method of accessing and the torp into tube?
I should add, I'm no a needles kind of guy as once dropped, they hit the carpet and so my feet and the dog's feet are at risk. I use a small paint brush for glue/water mixture and a pointed (sharpened) toothpick for all other glues.
I'm of the "no CA on rigging" camp as there's been too much about it destroying the rigging. I use white (not the yellow stuff) glue thinned about 50-50 with water. I coat the knot and let the glue soak in. If I even suspect the knot isn't secure, I add a second coating. So far, so good.
I think it's more of a "mixture of both". Both have their place and all power tools do is speed up the process and/or make thing repeatable. In order of most used to least used here's my list. Be advised that it's easy spend more on the accessories than the tool cost. Small ME table saw with an assortment of blades for different thickness of wood. A full size jig saw, Hitachi for cutting things like frames, etc. A mill from Little Machine Shop. Used for sanding bits and pieces and milling things like capstans, etc. A lathe (14") from ME. Used to turn guns, masts, etc. Laser cutter... It sees more and more uses as I progress and transition from the jig saw. There's other assorted hand power tools such as a Dremel, some small power sanders, and very small rotary from WeCheer I find useful for odds and ends. Having said that, I've did one heavy kit bash (my Constellation) where the only power tool was a dremel. I even turned the guns using it and a set of files. The best tool is your mind... if you can visualize what you want to make, you can make without any major tools. I'm just getting lazy in my elder years.
Needed a knife so I made one
mtaylor replied to Antonio Vasquez's topic in Modeling tools and Workshop Equipment
Nice looking knife. I've never considered making a knife but seeing yours has me interested in trying.
