mtaylor
Moderators
Everything posted by mtaylor
  1. Hi Archie, Welcome to MSW.
  2. What Piet said, Lou. Scratching is fun... but you need the additional sub-skills of cursing, tossing stuff against the wall, burning the evidence, etc....
  3. Best to measure in both dimensions. I've seen scanners/printers that only one dimension not at 100%. Best to double check and be sure.
  4. Have a great roadtrip(s). Looks like the suitcases need to be large for all those destinations. Have you tried linoleum glue/adhesive? With vinyl bristles it might just do the trick. And it's not too pricey either.
  5. Just get feeling better, Moxis. I hope to see videos of this ship on the water.
  6. Thanks for the likes, comments, and encouragement. These two parts were harder than I thought they'd be but worth the effort for the confidence even if they won't be seen once the foredeck is in place. Steak? BBQ? Either works for me. Although I'm sure the standard fare at that time was something less wonderful. Well.. the stoves/fireplaces are just about there. The chimneys currently aren't glued into place as with the work on the upper deck, I don't want to risk damage. But I did put one into position to see how it looks. I'm thinking mission accomplished. There is a small pile of scrap now in the bin from the failures but I'm very pleased with the final result. I still need to do the two pots per so will hit the mill hopefully tomorrow along with some planning for the next steps.... <looks at list of things to do><shrugs><pours fresh cup of coffee> Hmm... ship's boats it looks like... 3 of them stacked and secured over the hatches forward of the main mast. Here's the pics...
  7. I totally misread/understood what you were needing input for... So I killed my answer.
  8. I'd stain before gluing. I only use stain occasionally, like ebony as I'm trying to get away from the toxicity of that wood.
  9. Hi Amy,
  10. Looking good, Lou. AL does have it's screwups and I see you ran into one. Been at least one kit where port side didn't match starboard side on the bulkheads. I, sadly, don't remember which ship it was though. What I see from your photo says it was more than just a "little" off....
  11. Marc, All this "extra" work is about to pay it's dividend when you start putting it together. What's been done is just fantastic.
  12. Wow... takes the breath away to see the details and the precision work.
  13. Hi Vaddoc, Get some scrap aluminum and practice first please. Aluminum uses aluminum solder and the melting point of the solder seems to be darn close to the melting point of the aluminum. It's a bit tricky until you get the hang of it. I never could though... If all else fails, use brass and then prime and paint with some aluminum paint. I've not worked with stainless steel so have no idea what would work or not work.
  14. My... that hull shape looks like something for a science fiction spacecraft. You've managed to get the complexity of the shape, Patrick.
  15. Interesting and fascinating discussion. I'm just wondering if they used a simple wedge or two at the foot of the mast to keep it from shifting?
  16. That seems to be my normal mode of operation. Test, test, test, and maybe I get what I want. If not, change parameters and try again.
  17. Michael, ME used to sell lantern housings made of solid brass. You might also check Age of Sail. I know I've seen some somewhere but not sure where. Oh.. try Cornwall Models... and also Shapeways. They might have something in 3d printed.
  18. I recall there's also some video of firing a gun from the Vasa era. A rather big brute but all things considered, the recoil wasn't that violent in that the gun didn't buck or jump... just rolled backwards. There's also a video or two of a gun being fired in the desert (strange place) at a mockup of the Constitutions hull. Yes, I'd love to see some video of a 32 lb gun.
  19. Nice work, Greg and great problem solving skills. That must have a bear to put together.
  20. Here's a pic of the one that the wood work and brick work are completed in "extreme" closeup. I see that I need a bit of touch up paint.. hmm.. missed that I did when I effected repairs after the glue pulled the paint off. And there's dust all over it. I took the picture outside so there's some "hotspots"... Needs the two brass pots and also the top with chimney. I bought the brass to today so I'll start pushing my envelope tomorrow or as soon as the other fireplace is done. These are more of a test to push myself harder. I'm not unhappy with them.... just realize I need to push a bit harder.
  21. Looks good, Lou. Keep going. The problem with these serious kit bashes is you suddenly wake up one morning, and realize that "don't need no stinkin' kits"... and get sucked into the darkside. It's not so back here.... good refreshments, warm buttered popcorn, and deep appreciation of what others go through but all in a good way.
  22. So the wedding is this weekend???? I missed that part. Have something tall, cold, and alcoholic once the ceremony is over. Both of you two. You deserve it. I've seen projects like that. Maybe it's time (if you haven't already) called in the customer and said..."pick one". If they pick one of the those that you're not working on, change the billing and the deadline...
