Everything posted by mtaylor
I vaguely remember a monograph being offered for L'Ocean. I'll have to do some digging as to where but then, I might be remembering wrong.
- 2 replies
- french 74
- decoration
raising and lowering an anchor on a sloop
mtaylor replied to timboat's topic in Nautical/Naval History
Like a lot of things, the yards knew what was needed and things don't always show up in prints that were part of the ship. Is there a contract available for the vessel you're interested in as it should list what was there. -
Scientific Kit of USS Constituion No. 170
mtaylor replied to Nat Fay's topic in Wood ship model kits
Folks, when someone asks for an address, real, email, etc... send it to them a PM. This site gets crawled by bots and spammers so take precautions to protect yourself. Nat, I'd delete your two posts and if you can't contact a moderator. -
Welcome back, Pete. The shop is looking good.
No math really on tapering.... just tic strips and counting planks. There's tutorials here: https://modelshipworld.com/index.php?/forum/14-building-framing-planking-and-plating-a-ships-hull-and-deck/ and in the database here: http://modelshipworldforum.com/ship-modeling-articles-and-downloads.php Take a look at them and pic the one you like. There's a simplified method in the database.
- 15 replies
- joshuah humphreys
- frigates
(and 4 more)
We all work from plans... Rule for a scratch is if you cut the keel and frames/bulkheads, it's a scratch. BTW, it's great you got this moved.
- 122 replies
- independence
- privateer
Looking good, Ken. Since this is now a scratch build, change the title to reflect that and ping a moderator to move it.
- 122 replies
- independence
- privateer
Ah... this model is NOT one of the first frigates. The AL kit is a fraud. We had a total system crash back some years and lost everything so this is actually a kit bash. As I explained way back early on, what sits in Baltimore, which the plans were taken from decades ago, is the sloop of war from 1854. There were some shenanigans pulled when they acquired her to make everyone belief this was one of them. Drop the following into Google (minus the quotes) and you see what I mean: "fouled anchors the constellation question answered". Given that the plans for the orginal frigate have gone missing, there's really no plans to build the first Constellation. I was disheartened to find that out, but such is life.
- 28 replies
- artesania latina
- constellation
About halfway down the homepage, you'll see this: https://modelshipworld.com/index.php?/forum/9-members-build-logs/
- 15 replies
- joshuah humphreys
- frigates
(and 4 more)
No... not really. The bulkhead (POB) kits usually use plywood or similar and about the only decks to be built are the gun deck and upper decks fore and aft. Look at Chuck's Winchester (link below) as an example or almost any AL kit as examples. A POF would be like my Licorne and probably 80% of the scratch builds. POF more closely resemble actual practice and allow everything below decks to be done. Other than the Orniada I don't recall any of the Lumberyard's Hahn sets being precut for the frames. Bob Hunt (Lauck Street Shipyard) did some that fully framed. I've attached a link for one of those build.
As is my ilk, I tend to research, think, then jump right in. My next step is the ship's boats. I've been looking over the plans and sorting out to do this with out making a dog's breakfast of it. For the cutter and the barge (the two smaller boats) I'm going to use a modified jig. The longboat will be built around the plug that I already have made. This may change once I really get into things. Basically, I have a couple of old ME ship's boat kits.. a 5 inch and one that appears to be 6" (by their definition). To make a long story short, I took their instructions and modified the heck out of the plans and the thus, new parts, which I've drawn up and cut on the laser using boxwood for the keel, the stern, and first frame. The only seats will be the fixed ones at the rear and bow. I'll decide on what goes in this boat once I get it put together. But, historically, everything was removed, rudder, oars, the benches the rowers used, etc. and stored in the hold. The other two will be the same since the boats were stacked n the gundeck. The picture shows the keel with the stern structure and also the first frame. The stern structure gets planked externally first before doing the strakes. The frame has been modified for the forward "seat" instead of a bulkhead as some boats (other navies) had. As soon as I get the forms added to the build board, I'll start install the keel and start planking. Looks to be another small (size) fun part of the build.
Hello Marc, Welcome to MSW. I would suggest that by all means, open a build log in the kit area. You'll get help and encouragement for your project.
- 15 replies
- joshuah humphreys
- frigates
(and 4 more)
POF = Plank on Frame (like the actual ships were built. POB = Plank on Bulkhead which is the way almost all kits are.
What constitutes “Fighting Sails”?
mtaylor replied to GrandpaPhil's topic in Masting, rigging and sails
In close, the main sails would have been not furled as that took some time but brailed up to get them out of way. The other sails would be used for maneuvering during the battle. -
Paul, Most of the Lumberyard (but not all) are a pile of wood to cut into blanks, assemble, then cut the frames. As for pre-cut framing... other than the Oneida mentioned and one that Chuck is exploring to make, I'm not sure there any. Many of the center section kits are however.
I should also add that there's several cross-section type models (not the whole ship, just the center sectin) out there.
Hi Paul, When you say "already prepared" what are you meaning? Cut out? Fully set up and the frame just needs installing like the bulkheads on a POB?
ancre Le Fleuron 1729 by rekon54 - 1:24
mtaylor replied to rekon54's topic in - Build logs for subjects built 1501 - 1750
It's great to see that you're still building her,Giorgio. I hope it's just life that gets in the way and nothing's wrong. -
Amazing optivisor light
mtaylor replied to Kurt Johnson's topic in Modeling tools and Workshop Equipment
According to this... https://electronics.stackexchange.com/questions/164103/if-li-ion-battery-is-deeply-discharged-is-it-harmful-for-it-to-remain-in-this-s deep discharge isn't a good thing. -
Hmm... I checked the CD... The aft deck is a poop/quarterdeck raised up from the fore/main deck. There's no decks below these. The Halifax is the same way. So you're spot on, sir. Which basically means they're refurbished cargo vessels with a large open hold....
Kurt, Do you know what kind of battery it has? That will make a difference as to whether drain it completely or being able just partial discharge and recharge. -
Hi Greg. Welcome to MSW.
