Everything posted by mtaylor
Thanks for the likes and comments. Stoves are on hold for a few days. The cutters on the lathe need to be sharper so I took a new and an old one over to the local sharpening guy.. I told him what I was doing and he's interested so hopefully by the weekend I can be cutting cookware. He's actually going to deliver as he wants to see the ship and also check the cut on the lathe. I put a small barrel (4 feet tall or so) next to each stove just for some interest. Not sure if any of this will be visible but I'll know it's there. Also starting a rigging table and did some testing. It looks like I'll be able to have access to the foot of the main mast for rigging so I added the eyebolts around it. I'll double check before I start doing the forecastle. Ovens were common on French ships... As for these stoves, I doubt that they anywhere near the capacity that the Victory had. As I recall, each pot is about 3 feet in diameter and 3 feet high. Maybe a bit more. Rats.. forgot the wine cellar. Mike, the tops are 0.010" brass. I used a pill bottle of the right size to bend the sheet brass around, cut to length and bent up the edges for securing to the stove. I also used an old piece of broom stick as a backing when I drilled the chimney mounting hole. There's a small round rod inside the square chimney to secure it to the top. The front and rear panels were rough cut out (larger than needed) and silver soldered to the top. Once cool, they were filed down to the roof. Then they were cleaned up with an acetone bath and blackened with Birchwood Casey Brass Black. I prefer this to the Jax even though the Birchwood Casey takes two "dips", it doesn't need as much polisining after blackening. I hope this helps. Now to go fiddle with making 3 ships boats.
Hi Archie, Welcome to MSW.
Laying out plans in a smaller workshop
mtaylor replied to alde's topic in Modeling tools and Workshop Equipment
Best to measure in both dimensions. I've seen scanners/printers that only one dimension not at 100%. Best to double check and be sure. -
Thanks for the likes, comments, and encouragement. These two parts were harder than I thought they'd be but worth the effort for the confidence even if they won't be seen once the foredeck is in place. Steak? BBQ? Either works for me. Although I'm sure the standard fare at that time was something less wonderful. Well.. the stoves/fireplaces are just about there. The chimneys currently aren't glued into place as with the work on the upper deck, I don't want to risk damage. But I did put one into position to see how it looks. I'm thinking mission accomplished. There is a small pile of scrap now in the bin from the failures but I'm very pleased with the final result. I still need to do the two pots per so will hit the mill hopefully tomorrow along with some planning for the next steps.... <looks at list of things to do><shrugs><pours fresh cup of coffee> Hmm... ship's boats it looks like... 3 of them stacked and secured over the hatches forward of the main mast. Here's the pics...
I totally misread/understood what you were needing input for... So I killed my answer. -
Looking great, Piet. I'm smiling form ear to ear because it's all coming together with no hitches.
- 378 replies
- java
- pacific crossroads
Marc, All this "extra" work is about to pay it's dividend when you start putting it together. What's been done is just fantastic.
- 2,667 replies
- heller
- soleil royal
(and 9 more)
Hi Vaddoc, Get some scrap aluminum and practice first please. Aluminum uses aluminum solder and the melting point of the solder seems to be darn close to the melting point of the aluminum. It's a bit tricky until you get the hang of it. I never could though... If all else fails, use brass and then prime and paint with some aluminum paint. I've not worked with stainless steel so have no idea what would work or not work.
My... that hull shape looks like something for a science fiction spacecraft. You've managed to get the complexity of the shape, Patrick.
Interesting and fascinating discussion. I'm just wondering if they used a simple wedge or two at the foot of the mast to keep it from shifting?
That seems to be my normal mode of operation. Test, test, test, and maybe I get what I want. If not, change parameters and try again.
I recall there's also some video of firing a gun from the Vasa era. A rather big brute but all things considered, the recoil wasn't that violent in that the gun didn't buck or jump... just rolled backwards. There's also a video or two of a gun being fired in the desert (strange place) at a mockup of the Constitutions hull. Yes, I'd love to see some video of a 32 lb gun.
Nice work, Greg and great problem solving skills. That must have a bear to put together.
Here's a pic of the one that the wood work and brick work are completed in "extreme" closeup. I see that I need a bit of touch up paint.. hmm.. missed that I did when I effected repairs after the glue pulled the paint off. And there's dust all over it. I took the picture outside so there's some "hotspots"... Needs the two brass pots and also the top with chimney. I bought the brass to today so I'll start pushing my envelope tomorrow or as soon as the other fireplace is done. These are more of a test to push myself harder. I'm not unhappy with them.... just realize I need to push a bit harder.
Looks good, Lou. Keep going. The problem with these serious kit bashes is you suddenly wake up one morning, and realize that "don't need no stinkin' kits"... and get sucked into the darkside. It's not so back here.... good refreshments, warm buttered popcorn, and deep appreciation of what others go through but all in a good way.
So the wedding is this weekend???? I missed that part. Have something tall, cold, and alcoholic once the ceremony is over. Both of you two. You deserve it. I've seen projects like that. Maybe it's time (if you haven't already) called in the customer and said..."pick one". If they pick one of the those that you're not working on, change the billing and the deadline...
