Everything posted by mtaylor
Thanks for the comments and the "likes"... Dan, I've noticed that with cherry about inconsistent and that's part of what is the conundrum and decision process. I'm not coppering so I'm just musing as I've discovered some planking challenges that need addressing. One of which is that at the wales, the planks are 1 foot (real or 3/16" scaled) and after 10 strakes they change to 9" (real or 1/8" scaled). The planking then goes back to the larger for the garboard strake. Should be an interesting trip down that road. Right now I'm checking my wood supply and figuring out if I have enough of either one. I'll order more no matter which way I go.
Longboat by Rao A.L.G. - FINISHED
mtaylor replied to Rao A.L.G.'s topic in - Build logs for subjects built 1751 - 1800
Lovely work, Rao. I hope you have a nice place picked out to display her. -
Hit a big milestone... framing is complete and ready for planking. Well, one minor tweak to the transoms to get smooth run to the counter but that's not going to be a stopper. Right now, I'm having second thoughts about the bulk of the planking in Swiss Pear and am considering cherry. I'll ponder a bit more.....
They do replica guns to ease the strain on the old timbers in case you're wondering.
HMS Alert 1777 by Jaekon Lee - 1/64
mtaylor replied to Jaekon Lee's topic in - Build logs for subjects built 1751 - 1800
Yep... you're right. I didn't have my thinking cap on straight. -
Well.. that's about normal. I've found it takes some sometimes careful re-wording of the search to find what we need in this hobby.
Nice progress that looks wonderful, Hamilton. Keep telling us what's on the menu and I think there will a bunch of us outside your door on Christmas. Have a great one.
- 69 replies
- fair rosamund
- occre
I went the same way but since you wanted "origin"... I had to fine hone the search... baggiewrinkles then added until I found something: definition, etymology, and finally hit it on: origin I'm not the brightest light in the chandelier.
Have look here: http://modelshipworldforum.com/resources/materials_and_tools/ToolsNotToBotherWith.pdf The general answer that's been posted many times is: save your money.
I was wondering the same thing that Greg mentioned. Your output and quality is amazing. This goes way beyond a "like" button. It's a masterpiece. Edit.. I needed to find out what the broaching was about.. now I know: http://en.wikipedia.org/wiki/Broaching_(metalworking) Your builds are an education unto themselves. Thanks for that also.
The only reference to it's origin that I could find by Googling is: https://books.google.com/books?id=Fp63wWByImQC&pg=PA16&lpg=PA16&dq=baggywrinkle+etymology&source=bl&ots=dvNAIl65rv&sig=R2NGugN_d39jN1wF2fj3OnoFcQg&hl=en&sa=X&ei=rSyTVPnSLMSeggSTt4DgDg&ved=0CD0Q6AEwBA#v=onepage&q=baggywrinkle%20etymology&f=false
Lee, It looks like that joggle in the middle got sorted out with the keel and limber. As for the breasthook, I think it connects to the stem and to the frames. -
mini drill chuck for those small drill bits
mtaylor replied to AON's topic in Modeling tools and Workshop Equipment
Alan, Check the link Tom gave at ModelExpo. They claim down to #80. -
Essex - Process and corrections to the new Model Expo Kit
mtaylor replied to samueljr's topic in Wood ship model kits
It's sad that he doesn't at least get an acknowledgement. -
I'd suggest you call them and ask. I seriously doubt that any (ok.. almost all) of modelers have a clue on that question. Let us know what you find out. -
Fletch, I haven't done a Constitution but I did do a Billing Wasa (single planked kit) that I double planked. What I did was used a cherry veneer that's about the thickness of cardstock. To minimize sanding and the chance of sand-through, the first planking has to be very smooth and the use of filler is needed.
Victory paint finish
mtaylor replied to EinsteinTaylor's topic in Painting, finishing and weathering products and techniques
I might be wrong, but back then when she was sailing, I doubt that they had gloss or semi-gloss paint. Varnish maybe.... -
I think Tadeusz may have your answer. A various times they also hung barrels off the chainplates to soak the salted meat to get the salt or soaking peas and/or beans out before cooking. I've also seen accounts where a barrel was set up by a scupper to catch rainwater, but that doesn't appear to be the case here since it's sunny.
Congratulations, Mick. Looks perfectly at home in her case with the map. Ok,... what's the next project of which you speak?
- 83 replies
- sloop of war
- sloop
Lee, She's looking pretty good. A little fairing and the framing should work for you. The only thing I see that might give you problems is a couple frames in the mid ship area that might have to be de-glued and re-set but that will depend on how flexible the frames are. If they're flexible enough, a bit of heat might work to move them into position and then the wales and deck clamps to secure them. -
Impressive work. Looking at the pictures, I'd say you had built quite a few models. For a first model, it's even more impressive. -
If he didn't count, we'd think it odd that there was a large hole in the middle. Ok. seriously nice work, Ben. Looking superb.
- 889 replies
