Everything posted by mtaylor
mini drill chuck for those small drill bits
mtaylor replied to AON's topic in Modeling tools and Workshop Equipment
Alan, Check the link Tom gave at ModelExpo. They claim down to #80. -
Essex - Process and corrections to the new Model Expo Kit
mtaylor replied to samueljr's topic in Wood ship model kits
It's sad that he doesn't at least get an acknowledgement. -
I'd suggest you call them and ask. I seriously doubt that any (ok.. almost all) of modelers have a clue on that question. Let us know what you find out. -
Fletch, I haven't done a Constitution but I did do a Billing Wasa (single planked kit) that I double planked. What I did was used a cherry veneer that's about the thickness of cardstock. To minimize sanding and the chance of sand-through, the first planking has to be very smooth and the use of filler is needed.
Victory paint finish
mtaylor replied to EinsteinTaylor's topic in Painting, finishing and weathering products and techniques
I might be wrong, but back then when she was sailing, I doubt that they had gloss or semi-gloss paint. Varnish maybe.... -
I think Tadeusz may have your answer. A various times they also hung barrels off the chainplates to soak the salted meat to get the salt or soaking peas and/or beans out before cooking. I've also seen accounts where a barrel was set up by a scupper to catch rainwater, but that doesn't appear to be the case here since it's sunny.
Congratulations, Mick. Looks perfectly at home in her case with the map. Ok,... what's the next project of which you speak?
- 83 replies
- sloop of war
- sloop
HMS Alert 1777 by Jaekon Lee - 1/64
mtaylor replied to Jaekon Lee's topic in - Build logs for subjects built 1751 - 1800
Lee, She's looking pretty good. A little fairing and the framing should work for you. The only thing I see that might give you problems is a couple frames in the mid ship area that might have to be de-glued and re-set but that will depend on how flexible the frames are. If they're flexible enough, a bit of heat might work to move them into position and then the wales and deck clamps to secure them. -
Longboat by Rao A.L.G. - FINISHED
mtaylor replied to Rao A.L.G.'s topic in - Build logs for subjects built 1751 - 1800
Impressive work. Looking at the pictures, I'd say you had built quite a few models. For a first model, it's even more impressive. -
If he didn't count, we'd think it odd that there was a large hole in the middle. Ok. seriously nice work, Ben. Looking superb.
- 889 replies
Which quarks? The up, down, or strange? I've ordered some fresh Higg's Bosons so well see what happens.
Before stripping off the rigging, try brushing it with a bit of white glue mixed 50/50 with water. It should add the sag back and might even take out some of the slack. As for the paint messed up.. I don't see it. You've gone this far, don't even think scrap box.
Look to the rudder cover for ideas. On the bowspit, they lined the opening (see Danny's Vulture log for this). You might do a search for pictures of Civil War ships but be choosey as some of the techniques for various things varied wildly between the North and the South.
- 569 replies
- shenandoah
- corel
Well done on those. They are tiny aren't they? I didn't realize how tiny until I saw the cutting mat.
Mary Rose 1545 by tarbrush - Scale 1:72
mtaylor replied to tarbrush's topic in - Build logs for subjects built 1501 - 1750
John, From an interested observer... you might put it back in the jig and recheck before doing anything. It looks like the keel might have a bit of warp and thus, an optical illusion. If it is warped, remove and save the frames. Fix keel and put frames back on. I hope it's as easy as that and you won't have to start over. -
Deadlights. After staring and thinking... I decided deadlights next. Not the frames yet but the black background part. Being a glutton for punishment, I decided to use ebony since I love the look of this wood. Which begat more contemplation because that stuff is a bit hard to work with. I think I found an adequate solution. Being fond of quick prototyping in many areas, I made up some deadlights from basswood. Gave it some thought and decided to make some ebony veneer. I tried to rip some down to 1/64" (.35mm)....by 1" (25mm) with the thin side coming off the 1" thick billet. Don't try it. I got it down to 1/32" (.7mm) before things starting exploding across the shop. Might have something to do with the blade but I wasn't going to kill a new Thurston blade on an experiment. Anyway... now I have to clean up fragments everywhere. I was using the table saw for this. I took the 1/32" inch thick piece that survived and ran it through the thickness sander to get it where I wanted it, glued the prototype deadlights to it and cut them out with the scroll saw. A bit of sanding and they fit about right. The pics show a gap but that will be covered by the window framing. Did I mention I hate macros... To the naked eye (or even with glasses on) it looks pretty good. I don't feel anything out of place running my fingers around everything, so that's good also. I'll re-fillet the glue joints on the framing and cut them down to shape. Also need to get the middle area of the counter fixed up with some wood for the landing of the counter plank ends at the rudder and stern post. First pic of the basswood and veneer laminated together for the deadlights. Second one is the installation and..hmm... wet glue. What the hey.. I'm having fun it's turning out well in my opinion. I past the point where Version 1.0 met it's end (the stern area) so I'll be carrying on.
Steve, The English used leather around the bowspit to pad the opening and waterproof it. Not sure what the Americans used in this particular time frame but possibly the same method.
- 569 replies
- shenandoah
- corel
