Everything posted by mtaylor
Rope making question
mtaylor posted a topic in Rope Making/Ropewalks's Discussions about Rope Making
Well, the holiday season is upon us and my Admiral and were talking about things. She brought up the question/suggestion of my making my own rope. I can sense what's going to happen.... So a question. Is there a formula or table of what size threads to use to make rope of a given size? I figure I got to be prepared. -
Beautifully done and a another great tutorial, Karl.
- 662 replies
- bonhomme richard
- frigate
Careful there, we're all about to be sent to our rooms without dinner.... :D
- 625 replies
- bounty launch
- model shipways
Nice cannon work, Augie. Use my philosophy... If they growl, hug them. If they scream and turn red in the face, run across the room to a safe place and throw chocolate at them. :D
- 2,191 replies
- confederacy
- Model Shipways
Nice work on the bow, Sjors. It seems everyone has trouble with the stern and bow on this ship.... you've done well, sir.
- 1,616 replies
- caldercraft
- agamemnon
So first scratch build... you claim. Looks like you've doing this all your life. The frames and jig look great.
- 255 replies
- granado
- bomb ketch
Daniel, On the Queen cross-section.... it looks like the lower pumps are chain pumps (cistern) and elm-trees. The lower chain pumps have square 'pipe' and the elm-trees have hexagon 'pipes'. Neither set of pumps has any detail such as dales or pump handles. The upper pumps are elm-trees... hexagon 'pipes'. The ones I think are elm-trees is due to their length above the deck and the hexagon shape. Note the number of, let's call them pipes) going up from the lowest deck and that they stop at two decks pump areas. Those hexagon things on the upper.... I have no idea.
wq, The tiller was overhead along the beams. Hatches, knees, etc. were all part of the "normal" for them. You'd be wrong in your assumption of the guns not being installed. Maybe in times of peace as many ship were not completely fitted out with guns and crew. The ship I'm currently building even had cabins on the quarterdeck for the officers and higher ranks (it was French). It was common on other nations also and these cabins would be removed during time of war.
Those were spliced on Vulture? I was thinking they would have had the hooks, though that was probably later. Well done on that bit of tricky rigging, Danny.
Lextin, Can supplex be bleached? I think the gray might work, though.
- 366 replies
Planking question
mtaylor replied to Daydreaming's topic in Building, Framing, Planking and plating a ships hull and deck
Hi Warren, Trust the instructions. Do tick marks down the hull in the middle of the hull (or thereabouts) with each mark being the width of the plank, Count the marks, as that is how many planks you need. Now measure the hull fore and aft and divide the measurements by the number of planks. You'll see that the planks will need tapering even with the sheer. Make sure that the measuring and tick marks are on the wood itself and not by using a ruler or T-square standing proud next to the model. I hope this helps. -
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
Thanks for the tips and tutorials, Nenad. Very insightful and useful.- 4,152 replies
- cutty sark
- tehnodidakta
Nice work, Lou. I also like the contrast. As for the "like" notifications... check your settings in your profile and see if they changed.
- 18 replies
- granado
- bomb ketch
Here's a couple of tricks when the blade only needs honing a bit... Danny Vadas posted (and I can't find it now, naturally) that he strops the blade edge of an x-acto blade against the back side of another one. A version of using a steel. I'm an old tech writer and picked up a trick from the old board and ink draftsman... a piece of typing paper. Before every use, strop the blade on it. Even a new blade. Also works with chisels.
Excellent work, Nenad. I think they look wonderful. Macros and close ups are NOT our friend.. but on your Cutty, they still look great.- 4,152 replies
- cutty sark
- tehnodidakta
You might be having a browser issue. IE 11 has some incompatibilities. There's been some discussion on this along with copy/paste, etc. here: http://modelshipworld.com/index.php/forum/47-questionsinstructions-on-how-to-use-and-post-to-this-forumsite-problems-or-suggestions/
- 176 replies
- muscongus bay lobster smack
- Midwest Products
JPett, That looks very similar to the one I have.... http://www.woodcraft.com/Product/414749/Dockyard-Gouge-and-V-Tool-Strop.aspx
