mtaylor
Moderators
Everything posted by mtaylor
  1. Thanks for the likes and comments. Hi Bill, The frames are <cough> a bit <cough> rough at this point. I'm using 100 grit paper but will go to maybe a 120(?) or a tad finer for the final of all final fairings. I tell myself I'm done and then go back and hit it again.. <sigh> I want the glue to hold the planks on and using something 400 just doesn't leave enough tooth. If I were doing an "admiralty style", there would be no rough edges or gouges allowed and I'd probably just now be getting the second or third frame into place.
  2. Mike, I've used the Amati quite a bit as well as the Billings. The AL is pure crap. The old Billings was nice but the newer stuff leaves a lot to be desired. So.. while the Amati is nice (and it varies depending on the day it seems) it's also a bit kinked due to the way it comes wrapped on the cards. Chuck's is best I've ever seen. I've not seen the Morope but heard many things good and some bad. The price and fact it unravels made me not want to use it. ChuckRope really is excellent rope and I'll be using it. Now to figure out how much I'll need...
  3. The damage from a 30 caliber (about what the Germans used) would be infinitesimal at best. Even the 20/30mm cannon they used might not show. As for how far apart would depend on the angle of attack and drift on part of the aircraft. Holding a tight group on the ground with a machine gun is hard but flying in at a couple hundred miles an hour, in a dive, with wind and a moving target.... unlikely. Now if the attack is just above the waves and the pilot was trying to hit and correct his flight path for say, a gun mount, you might at this scale, see peeled paint and some raggedness of the metal.. Try it on some scrap plastic and see what you can do and what it looks like. Also, look for some pictures of the ships at Pearl Harbor or other after battle pics and use them as your guide.
  4. Battle of the Stern - Opening Salvos Reread the plans at least 10 times and compared them to the salvaged stern section from V 1.0... realized I can do a lot better and also figured out where the errors crept in. Then reviewed Hahn's article from the NRJ on her. The pictures were unclear and perhaps I missed something first time through. So... scanned the article and adjusted the pics... yep. whiffed it. Scan of a a scan of a printed magazine with retouched photos... <hangs head since he knows better> So, I started with some deconstruction by removing the stern post. That done, took some basswood and worked on the filler piece. The pics seem to show one curve (which I used for V 1.0) and plans show a different curve. Originally, I figured Hahn found something and did the filler differently then the drawing and I followed that. Wrong!!!! It was the pic. I followed the drawing this time. Much happier. Also, worked on the first transom frame. A lot happier even though it took the second try to get it right. These are "rough faired" for now. I'll go back and finish shaping when the second transom is installed.
  5. Good looking wood, Mike. I'm happy to hear that you finally got what you wanted. That Lumberyard pear doesn't look at all like Swiss Pear. It looks more like regular unsteamed (or unSwissed if you like) pear.
  6. Daniel, You always seem to ask the tough questions... I gave this some thought since 1) the plans are flat sectional plans and thus no detail as to how these were done 2) much wasn't written down as it was "common knowledge" and... 3) the builders and sailors were practical men who seemed to take the KISS (keep it simple, stupid) principle to heart. Ok.. here's my musings. Having two sets of dales seems counter-productive since if the lower pump set was open, no water would reach the top. I notice that most of the plans (but not the photos you show) have only one set shown on the upper deck. I've read that most 1st and 2nd rates had pressure pumps for these function which drew in sea water from under the ship. But, these weren't pressure pumps that could be used for fire-fighting or washing the decks, the water came from the deep down in the hull... probably very yucky. So... back to the original thought that it's counter-productive to have both sets of dales open... Well, there's no sign that there were two chains or two tubes inside one tube. If it had been two tubes, I think it would have been shown on the draughts. Could it have been in case of battle damage? Probably not, since anything taking out the upper cistern would damage the chain. Back to brain work. Your premise that double the men could operate the pumps, but what would be the advantage to have 4 cisterns down low and only 2 up top (unless there were 4 up top, but they would be shown, right? Then not battle damage. Maybe exhaustion. Double the men wouldn't mean double the water being pumped but it is hard work to crank the pumps. My thought would be that it allowed the men to be rotated as exhaustion set in. Use the lower deck crew and switch to the upper deck crew without stopping the pumps. I read somewhere that starting the pumps moving was when many times things went to hell... the chain broke, jumped off the sprocket, etc. so it makes sense in a logical sort of way, to keep that chain moving. Stopping the pump to change out the pumpers would be asking for Murphy to jump in and break something. I'll go with this for now until someone versed in the research (Hi Druxey ) slaps some sense into me and has the correct answer. Edit... hmm... my reasoning falls to the wayside when I see that there's only one top set of cisterns and not two. I did mention I was musing out loud, right? However, the lower set are connected by the cranks.. Which creates another set of headaches in that crew up top is only half as great as the crew at the lower... Very strange on there only being one set on the upper vs. two sets on the lower.....
  7. I'm not asking Santa for tools, wood, or books. I'm asking for time. I want a few more hours each day for building.
  8. Mike, That's excellent news. Were you able to find holly? Steve, Thanks for keeping the first post in this topic updated. I'm sure we all appreciate it.
  9. Daniel, I'm not sure they used boxes for the fish... probably barrels. The bread (ship's biscuit also known by some as hardtack) was bagged.
  10. I agree with Steve. It looks great and at this scale, if someone tries to move there is no telling how much damage they could do.
  11. Daniel, I looks from here that your efforts are well worth the time. Everything is looking super. As for the fish room.... dried fish or salted fish. Not much fresh of anything on these ships.
  12. "Warming room"???? Why do feel that there's a hot tub in this ship's future?
  13. Grant, The only thing I see missing is glue. Put those babies together as they look great. Almost forgot: Welcome to the Club of Over-thinkers. We meet every day and at every hour.
  14. Impeccable machining, Michael. I'm always amazed at what you do in miniature.
  15. An excellent start, Fam. I'm looking forward to seeing more..
  16. Admirals are like that. Maybe you need to move the refrigerator so she won't come into it often?
  17. Nenad is right, Bill. A build log will get you help fast. We do have quite a few plastic and card logs so wood is not the only medium.
  18. Alternatively, you could spot paint. I did that on my Wasa. As far as the hull goes, I just painted the bulwarks and stern (along with seemingly a thousand figures). I've also seen other builds done very effectively using that method.
  19. Hi Carl, Actually I do overthink. Though for the stern I think it's the fear since that's where I crashed and burned the last time. Anyway, pics coming as do the transoms... Thanks, Dave. I've seen your work and I have no doubt you could do a POF and it would be excellent. Hi Lou, The best overview of his building is in the book you already have. The chapters on Alfred pretty much tell you how.
  20. The first one I turned were done with a hand power drill and file. I tried a dremel but too darn fast.
  21. I think Michael is correct... Correction, make that I know he's correct.
  22. Frank, You are a master at weathering. Wonderful work, my friend.
