Beef Wellington
Everything posted by Beef Wellington
  1. I 'started' at the rearmost bulkhead and which positioned that gun port. The rear of that gunport was flush against the full bulkhead with no adjustment. From there the other positions were determined, 30mm apart which resulted in only the first two bulkheads requiring 'treatment'. Based on differences on each it and construction, I'm sure this could vary a little which is no big deal. There is one pair of ports where the steps are located that are further apart as indicated on plans, I made a really silly error by mispositioning this which had to be corrected. I didn't find a satisfactory solution that avoided having to deal with bulkheads 3&4 keeping a consistent port separation. Good luck! Interestingly, I found at a later date on NMM plans that there was in fact another port added further forward, this could only be a bridle port with no cannon as it would be located in the manger area. It would be very difficult to show this port opened, but had I known I may have attempted to show this in a closed position.
  2. Hi Dave, please feel free to delete this as I really don't want to clutter up your log, but this may help your thought process. The first decision is the determine the gunport positioning, with an even spacing - I remember fiddling about out with this a lot, rather than relying on the plan position (i.e. figuring out the position based on the equal distance from other ports). This is all rough work, so plenty of time to neaten it up and strengthen where necessary. And yes, the supplied cannons are atrocious, seemingly having footballs for cascabels aside from all the dimension issues!
  3. Hmm...think there are some other considerations here to consider. Even when shot garlands were used, it doesn't seem practicable have been used as a permanent place to store cannon balls on an exposed deck due to rusting. Even shot stored in lockers below would rust and require that to be removed before use. There would have to be a reasonable ready storage area around all guns to allow even the shortest of engagements, whether in garlands or racks. Considering a typical well trained RN crew could fire 2-3 times in a 5 minutes, each gun would likely require at least 9-10 readily available balls to last first 15mins of an engagement. Its amazing to think of the logistics bringing shot up in a lengthy engagement - you don't exactly put 10 of these things in a plastic bag and carry it up a few deck levels. That would be worthy of logistical analysis all by itself! I'm skeptical that the practical driver of the change was due to weight alone. Lets use a 32lb shot as an example, a rough back of the envelope calculation ...a single 32lb cannon weighed 56 cwt (hundered weight)....or there abouts. This as approximately 6272 lbs (Long imperial cwt of 112lbs) so assuming a 32lb ball weighs...er 32lbs....then it each cannon would be the equivalent weight of 196 balls (!). Considering motion of guns being run in and out, and ships motion, the weight of 10 (for example) balls at hand would be negligible (5% of the cannon weight) and would not impact to any significant degree the centre of gravity to a point that ship stability would be impacted.
  4. Good to see you back at it Alistair. You've got some nice details going on.
  5. Interesting subject and approach (to finish the hull before glueing the upper bulwark pieces on). Nice to see some new ship types!
  6. For what its worth Kevin (and please feel free to delete!) I experimented a little with wipe on poly and tung oil when I was trying to decide. I found the sample sheet from what must now be close to 7yrs ago, although this has not been in sunlight (though this photo was taken in natural light) The wipe on poly gives a little more of a rich finish to my eye. I seem to recall putting a second coat of both on the outside edge and this is faintly visible as well, both being a little 'richer' again. Of course, your results may vary....
  7. I think 'raised wooden welcome mat' is probably the best answer, it is a nice detail. I wonder if its practical application would be to reduce tripping hazzard when entering/exiting as it is at the same level as the floor of the entryport and step. I just can't think of a sensible drainage explanation.
  8. Deck shots in natural light look fantastic Dave, the level of detail you've achieved is very impressive. Well done indeed.
  9. Mark - your work is outstanding and inspirational, such clean woodworking. One question if I may, how do you shape the underside of your beams? The concave profiles must me challenging than the convex upper side.
  10. This looks like a great kit coming together! Question maybe for Chris, I see the carronade beds that will be provided look to have a molded wheel arrangement vs the flat PE wheel arrangement that is currently available. Will these be available to buy separate from the kit? They look so much better.
  11. Hi Alistair - yes, it is the Syren rope, and from memory it was the largest diameter Chuck produces which seemed to fit the bill nicely.
  12. Headworks (Part 2): @DaveBaxt - the diamond cutting wheel is similar to this, easily cuts into the razor blades (545 Dremel | Tools | DigiKey ) with suitable eye protection! Sure there are many other similar items and prices from other retailers. The razor blades were bought in bulk...similar to these Multi Purpose Razor Blades (Pack of 100) (double-glazing-parts-spares.co.uk). Also, have provided a little more detail in update below...The wood used is either pear or castello box depending on what I have on hand, these woods are great for this. I would suggest you have nothing to lose, and much to gain by giving it a go....think you'll be pleasantly surprised at how simple it is with a little practice. Much fiddling, fettling and fine tuning has been going on with the headworks, but this should bring me up to date. Think the back of this challenging task has been broken as I will likely be needing to spend much of any available time on unrelated projects. Once the shape of the head timbers had been finalized, the covering boards could be added. These are identified as being 1" in TFFM, so these were cut from 0.5mm pear sheet to approximately the correct dimension. TFFM suggests shaping these and attaching once the lower rail is in place, but am going to try and simplify because I'm not sure how successfully I'd be able to do this. Photos below show work very much in progress. Once finalized, the time head timbers can be finished. A scraper was made specifically for the purpose to scribe the profile, with a long inner face than usual to act as a guide on both the fore and aft sides, and to account for the very different angle the face presents. A light coat of blue paint was applied to the outer face of the covering board to aid the eye in seeing the results of introducing the profile. Unfortunately, the only photo I had of this was of horrible quality, so apologies in advance but you get the idea. The scraper detail and a more final version is also shown below with paint applied. The lower rail was profiled by temporarily attaching to some spare sheet and again a custom scraper. Finding one that followed approximately the desired profile and looked acceptable took quite a few attempts. With all the key components really only requiring the some final finishing, it was time to cross fingers for another dry-fit - it gives confidence knowing that any additional tweaks can be easily addressed before glued to applied. The covering boards introduce a 'ledge' for the main rail to sit on, something that the simplified approach to shaping the head timbers did not include but seems prototypical. Some slight alignment issues apparent in the photos below should disappear when finally secured in place with glue. Next up is clearly some touch up after seeing these pictures on the PC!
  13. Kevin, Hamilton, Mort - thanks for overly kind words and the likes. Hopefully have another progress update soon. Dave - all the moldings are made from wood strip of various dimensions. I had ordered a long time ago some of the brass strips you reference but never used them, the brass just seemed very hard to work with, so I made the decision to make my own because it was a technique I wanted to get to grips with given the large number of molded profiles that may be needed. There are more professional techniques involving heating and cooling to harden, soften and harden again which probably allow a little more control, but I unashamedly just use razor blades and a cutting disc on my dremel. For me its a bit more art than science, and many reworks are sometimes needed because until you see the profile cut onto the wood, you don't know if it looks right or not. Getting comfortable with the result on a spare or offcut first is recommended!
  14. Looking very good as always. Nice feature to have the stem fascia create the rabbet. Are you going to taper the stem, or will that mess up the figurehead fitting? Looks like the main stem piece could be tapered before attaching the facings.
  15. Siggi - the comments made above by others are all appropriate. The state of readiness of a ship could change in a very short time period, either bringing up cannons and makign up carriages stored in the hold, or moving a cannon lashed to the side to bring to bear in the gunport. The same for breaking down bulkheads. The "state of readiness" would be consistent with the threat situation....which is still true for warships today. There are many examples of models not necessarily reflecting a snapshot in time of contemporary practice, so none of that should get in your way.
  16. Hi Dave, think it is true that it will be very hard to see the interior bulwark when the foc's'l is in place so its definitely an 'optional extra' to plank further forward....however be aware you will need to build up the forward gunports if you don't plank there. I seem to recall that Ray went down that route on his Diana build if you have found his log.
  17. Have you tried looking at second hand book marketplaces? While not ideal, Abebooks for one does have one available as part of the set. You could always sell your duplicate volume 1. Naiad by Tosti: Books - AbeBooks
