Posts posted by vossiewulf
20 minutes ago, harlequin said:
cheers kier......I wouldn't say great .... more of a how did I manage that ? corel kit builder..
It looks to me like you've done a very good job, I've never heard anyone talk about how easy Corel kits are to build and yet your ship is very clean and straight and pretty Bristol fashion to my eye.
Good luck! Actually, for the first layer of planks you can "cheat" and use easier methods since the point is just to get a good substrate layer for the final planking, but like you since I'd never planked a ship, I used the first planking to figure out this whole ship planking thing in hopes I would have a reasonable grasp for the final planking.
The method you stumbled on of using hot water, a hair dryer, and leaving clamped to cool is one of the preferred planking methods and will work well. However don't assume spiling is always necessary, planks will edge-bend (within limits) just fine with the same hot water or steam methods. I in fact did not spile a single plank for the second boxwood planking of my Lady Nelson. That wouldn't be possible with anything with a fuller bow, but it does demonstrate that if a plank has a gentle edge sweep, that can be handled like any other bending.
Pump handles and pump parts, and the small windlass that will go mid deck, I'm including one of Tony's pics to show what I'm trying to follow.
If the method to the madness isn't obvious, I've been making all the parts required for the deck furniture up to the point at which they need paint, and stopped there, the point being to minimize my opportunities to break things already installed. I've now made the final pieces and I will be painting most everything black or red, then each of the subassemblies will be installed bow to stern.
I've decided to not do much about the stern other than adding some thickness to the transom so it doesn't look like it will collapse at the first wave over the stern. If the transom was flatter I'd consider major surgery to cut it down and add a cap rail, but with it so curved we'd end up with a Seppings round stern on a cutter and that's just replacing one unrealistic thing with another. I wish I'd spent more time early looking at contemporary models instead of trusting to a reputable kit manufacture and kit designer for that matter, I don't think this is Chris Watton's greatest work.
One thing I've learned about ship modeling is that to be fully successful, you have to build the entire model down to every detail in your head before you build anything, including working out all the required processes and tools and materials. Assuming you will figure out something when you get there will result in the gods of ship modeling smiting you a good one.
- src, Landlubber Mike, rafine and 6 others
- 9
Uschi is definitely the place to go for woodgrain decals, paints, and metal finishes. The metal powder finishes are very easy to use and produce spectacular results. Below was me playing around with them, I made a balsa wood glider, filled the pores with lots of sanding sealer, painted Tamiya flat black over everything and then burnished that down (Tamiya flat black is soft and can be burnished out to a still-soft semi-gloss or gloss), and then rubbed in some of Uschi's aluminum powder. Once I was done I couldn't tell it wasn't solid highly polished aluminum.
Tragically the balsa proved much too unstable for that level of surface smoothness, after I set it aside for a month all sorts of ripples started to appear. But certainly styrene and resin and acrylic and other easily workable substrates can be made into complex parts that are indistinguishable from solid metal.
An extremely precise and handy tungsten scriber. This is now my awl for all small drill holes and I've been using it for general marking on wood also, the consistent fine line can be highlighted if necessary by running a pencil gently down it.
- thibaultron, CDW, Mike Y and 6 others
- 9
If it doesn't qualify as a masterpiece, I'm not sure what does. I have not the slightest idea how you managed to achieve some of the carving, particularly what appears to be long lengths of carved rope.
I also agree with LH that there aren't many comments because your skill level places you in a completely different league from most of us here, you are playing in the Bundesliga and in comparison, we are playing in the fourth division in Finland. It's hard to say much useful other than "wow".
It's a rusted electrified power egg, obviously.
- keelhauled, Piet, mtaylor and 2 others
- 5
Extremely good work. You make that joinery sequence look easy.
- Keith Black and mtaylor
- 2
No glue yet, but Trial has them lined up all the way across. Or at least the outboard one on the port side lines up with the inboard section on the starboard side, which are the only two I can see on Tony's pics.
I knew about the nail trick, but wanted to play with Mikhail's chisels It wasn't that hard, one of the chisels was exactly the right size and I matched a drill bit to it so the squaring required very little removal of wood.
Progress has been a bit slow since work is being busy, but I've made everything at this point except the pumps and a small windlass I'm going to add below the spanker boom as seen in the model of Trial. Actually almost all of them have more than one small windlass on deck, but there isn't room between the anchor windlass and the forward grate on LN to fit the one typically seen forward.
The anchor windlass started with an octagonal section of boxwood. I just marked an octagon on each end and did it by hand with one of my small planes, it wasn't hard. I then drilled holes for the windlass bars, and squared them off using one of Mikhail's small chisels. To prevent tearout, I "crosscut" the piece into the various required sections on the lathe, and also made a couple round slices from another piece of boxwood to go on each side of the ratchet gear.
The ratchet gear itself is just a slice from the starting octagonal piece that I carved with a knife.
Test fitting, it's missing its starboard end piece here. Also, the cross piece on boom support of Trial is much lower than that on LN, and the pawl for the windlass ratchet attaches to that cross piece. So in my case, no pic but I've added a small piece to the centerline boom support and the pawl will attach to that. I also stuck with a single ratchet, whereas Trial has two.
And I also took a couple evenings and made and soldered rings for all of the eyebolts on deck.
14 hours ago, BANYAN said:
Your joinery is
an inspiration!proof you are an 8-armed alien posting to Model Shipworld from the orbit of SaturnFixed that for you.
- Bluto 1790, mtaylor, Obormotov and 1 other
- 4
Beautiful work Kortes. These are very odd boats- hull turned almost into a circle, everything on the hull is sweeping curves whether it makes sense or not, but then we come to a bowsprit that is stark square-sectioned black iron with solid iron bar stays, it's like a section of prison wall bolted to the bow
If you look at the real deck planking patterns of the Vasa or the Mary Rose, you'll stop worrying about it It seems the driving concept of the period was to use whatever they had at hand, including 2 foot planks and wide planks and really narrow planks, fit together like the decks were done on All You Can Drink Free Beer day.
- vaddoc, pontiachedmark, russ and 1 other
- 4
7 hours ago, keelhauled said:
I'm not really familiar with Vallejo, but I've worked professionally on ink and paint formulations as a chemist. Vossiewulf's correct, although it isn't actually mass spectroscopy the thought is correct. It's actually chromatography
Apparently I am not a scientician.
- Canute, mtaylor and keelhauled
- 3
US, France, and Italy respectively. Don't spend $200, get their medium-range needle/riffler file sets in the $30-$60 range, their value line products are much better than the hobby store sets and are good enough for what you need unless you intend to do lots of metal work. Cuts 0 and 2 are best for wood, the higher the number the finer the cut. For metal it's good to finish with cut 4.
Waterstones will keep anything made of steel sharp. The downside is they're messy and soft, so it's difficult to keep them flat, and you have to keep them flat for good sharpening. I don't like the cut of diamond as it cuts deep scratches, I find you have to remove lots of metal to get out the scratches of a 1000 grit diamond cut. The best option are the good ceramic stones, but they are expensive and only worth it if you intend to use lots of edge tools that you sharpen regularly.
- Landlubber Mike, Canute and mtaylor
- 3
The waterstone files are intended for sharpening gouges/V-gouges, I thought you were saying you purchased their micro carving tools, not just the tiny chisels. You can sharpen those chisels with a watchmaker's screwdriver sharpener and the waterstones you already have.
You should return the Veritas jig unless you're going to get full-sized chisels and planes, which are of limited use in ship modeling. With the turning tools, yes you can use your waterstones on those as well.
WRT more tools, invest in good needle files and riffler files, don't buy the $9.99 set at the hobby store. Good files work much, much better and working mostly on wood, will last forever so they're a good investment. The other major one is a micromotor, they are much handier with much more torque compared to Dremels.
- Landlubber Mike, mtaylor and Canute
- 3
You're basically running a mass spectroscopy test of the paints with that "palette" arrangement. I'd be more surprised at an acrylic hobby paint that didn't separate. That said, I've seen Vallejo paints act weird with any solvent other than their "high compatibility" solvent, that only really works with their paints.
- Canute, mtaylor and thibaultron
- 3
The Mk.II honing guide is brilliant for sharpening full-sized plane irons, it's not much good for your small chisels.
A preferred option is waterstone files, these are only about 1.5" long and can be easily shaped to fit inside and outside profiles, just use an old metal file you don't care about to shape them.
https://www.japanwoodworker.com/products/set-of-four-1000-file-stones-king (you need at least 1000 + 4000).
And for straight chisels you use a watchmaker's screwdriver sharpener.
- druxey, mtaylor, Landlubber Mike and 1 other
- 4
Danny, very nice job once again. But if you're a stickler for accuracy, the winterketten track extensions on your track should bend inward toward the bogies a bit. See pic below for an example.
- popeye the sailor, Canute, Baker and 3 others
- 6
Per the contemporary model I'm most closely following, I spent some time soldering rings for the eyebolts, do they have a specific name? And what is the purpose, only thing I can see is they might let a rope twist freely a little bit as compared to going straight to the eyebolt.
How to make pintles and braces from brass
in Metal Work, Soldering and Metal Fittings
Very nice method, thanks.
