Posts posted by vossiewulf
4 hours ago, KeithAug said:
In the end I decided on the minimalist approach
(Tells the grumbling crowd of half'drunk woodworkers to go home and put out their torches and put up their pitchforks)
I'm sure you'll like it in the end more this way, it's just not very common for someone to walk by beautiful wood that's beautifully finished and say to themselves gosh, I really wish I had hidden that with paint. And you know to keep a supply of boring non-figured planking wood around for the next time you're looking at a painted finish
- Keith Black, druxey, FriedClams and 2 others
5
- paulsutcliffe, SandyBay and Sea Hoss
3
And now you've run into another aspect of planking that must be watched very carefully, that is like many others totally obvious in retrospect, but not at all obvious before: the need to have the planking of both sides be exactly symmetric.
I solved this problem by drilling a hole in the bottom center of the keel, exactly square. I mounted a piece of carbon fiber rod in that hole, sticking up a couple inches. I then attached two threads to that rod, one glued at the forward center and one in the rear center. With those threads, I could easily check any point on each side against the other, and it made it easy to maintain the required symmetricity.
As to how to fix it, if it's half a plank width out you really can't fix it without removing at least one plank on each side and then splitting the difference between the two replacement planks.
- Nikiforos and paulsutcliffe
2
24 minutes ago, Dr PS said:
Hello Vossiewulf, when attaching a long strake with CA, do you attach it little by little or all at once? Since it seems to bond so fast, I have not tried it except on small pieces.
I do it bit by bit, glue down a section an inch or two long and repeat. I don't edge glue, only putting glue on the bottom of the planks. Also the best method is to add glue in dots, don't try to smear it around, and the dots should be small enough that you never get squeezeout- if you do, you used too much.
The only answers are either to reduce clamp pressure, spread that pressure over a larger area, or use a harder wood for the strakes. Sometimes just gluing a small piece of 1/32" or 1/16" latex rubber on the clamp jaws evens out the pressure enough to prevent significant denting. If that isn't enough, you need some kind of small cauls to spread the pressure over a larger area. A fancy-dancy caul will be slightly concave so when a single center clamp bears down, it ends up very evenly spreading the pressure.
But this problem is also why I use CA instead, I've never had any fun figuring out clamping solutions for complex multiple curved pieces. With CA the only clamps in use are fingers 1-10.
11 hours ago, SHIPSCAT said:
I am loving this planking, I can see the ship taking place now 😻.
Mark was referring to this. No it's not bad
- popeye the sailor, SHIPSCAT, src and 1 other
4
If you wish Keith, you can go to a considerably higher level of gloss if you shift at this point to automotive finish buffing compounds. You don't need an electric buffer, they work fine with some elbow grease. There are many different "cuts" however from pretty rough to final polish, if you want to try this ask your local auto supply place which to use for final buffing.
I've done some very high gloss finishes this way, they look great with beautiful natural woods like you have here.
- mtaylor, FriedClams and Keith Black
3
Have had company in town for the last week, little time to do anything, I just finished the two anchors. I ended up rigging both of them up, although I liked the idea of hanging one from a cathead I keep having to remind myself that I'm doing this for the first time and I don't need a lose anchor floating around waiting to be ripped off while I thrash with full rigging for the first time.
I made two brass cleats for the cathead hauls, I think that's what they're called, and set them at an angle as seen below because one in line with the cathead would have been rendered too small. So I went once again with the what would I do if it was my boat method, and made reasonably big cleats and set them at an angle. I made them out of two pieces as that seemed the simplest method with a cleat this small.
I'm also spending time fiddling with the lines to get them to drape correctly as if they had real weight/stiffness ratios.
- popeye the sailor, tkay11, BANYAN and 12 others
15
One thing to consider with handles Gaetan is how well it locates the point of the blade and its rotation for you. A curved and fully rounded handle can be quite comfortable, but it's hard to know exactly where the point is just by the grip. That's why I always make the back edge of the handle straight, and perfectly in line with the point of the blade, and also with slight flats on the side, these help you intuitively feel where the edge is pointed. With a fully rounded handle, you can be holding the knife slightly twisted in your hand without noticing.
But in the end, handles are very personal things, make what feels right for you.
You can't fool me! He's just hiding the other six arms behind him!
- Obormotov, coxswain, FriedClams and 1 other
4
2 hours ago, daddytotwo said:
I am just getting into doing my gun rigging on my Connie.
Looking at your pic, one more suggestion since your hooks aren't like mine, where I'm making them out of wire and can slide the loop onto the hook after the loop is made. In your case it looks like you have premade hooks. In that case, go ahead and make the loops as I've described, but once the loop is made and seized, add thin super glue to the top of the loop so it will soak in, and after it dries, cut it with a sharp knife right at the top of the loop. Pry it open a bit to add the hook, then use CA to glue the cut ends back together.
- Gregory, mtaylor and thibaultron
3
This is the little jig I have been using, it works well enough. The little prongs that are holding the block are carbon fiber rod, I don't know of anything else stiff enough at this scale. Also I use fly-tying thread that is very thin for the seizing. Add the hook after the loops are made. In this case the hooks were pretty large as these are the catfall blocks.
First step is putting a tiny drop of CA on one side of the loop, and using that to attach the fly-tying thread about in the middle of the length of the thread. Once that sets up, wrap both ends of the thread around the loop a couple times, and pull tight to bring the stropping together at the bottom, this forms the loop. Glue it again with CA. Cut off one end of the thread at that point, and continue wrapping with the remaining thread until it looks correctly seized. Glue one last time and then cut off the excess.
I'm putting another example below, of one of the anchor buoys I made that shows what the loop should look like before you start seizing.
- mtaylor, thibaultron and Gregory
3
For all those who use yellow glue, I suggest you try Luthier Mercantile International's glue. It is excellent wood glue, but has an additional feature needed by instrument makers who can't afford a single spot of glue anywhere: it contains a fluorescent dye that reacts to a UV light.
So all you need to do is buy a small black light, and shine it over surfaces and any glue spots will be immediately visible, and in a case like Dr. PS has there'd be no guessing, you could see exactly whether you have glue present or not.
- thibaultron, Maury S, bruce d and 2 others
5
18 hours ago, John Allen said:
CA is better than sutures
Totally agree. Let it bleed a bit and then rinse out with water, dry it, put down a bead of CA and close the wound with your other hand. If you do it right, it will heal very quickly and you probably won't even be able to see the scar. I have lots of scars on my hands, but none that are noticeable since I started using CA to close the dings.
- BETAQDAVE, John Allen, thibaultron and 3 others
6
14 hours ago, Blue Ensign said:
I am also thinking about a boat, Cheerful would certainly have carried at least one, probably two, but space onboard is severely restricted. There is not room between the winch and the pumps, and storage of even a modest 14' four oared boat stored on deck either port or starboard would effectively fill the deck space.
I've been wondering about boats on cutters, considering their role they'd have to have had boats, but like the forward gunports there really doesn't seem to be enough room to keep one other than on stern davits, but I don't see stern davits on the contemporary models. I had concluded the standard procedure must have been to tow a boat.
And I agree with others that you could call her done after you have the anchors on, she's a very fine model as is.
- Blue Ensign, davyboy and Martin W
3
Solvaset and Microset are both basically weak concentrations of acetic acid (vinegar) and pretty much identical, although I tend to use Microset as it's cheap enough to not spend time experimenting with making my own. I've never known Microsol to do much of anything useful, it's the acetic acid in Microset that makes the decals flexible to conform to underlying surface.
And I agree with others that the decals on the Crusader look great, very nice job.
Agree with Joe, lots of very good workmanship there from the research required, to building out all the details, to all of the many finishing and painting skills needed to produce highly realistic weathered surfaces of all kinds as you have done. That's very much worth showing off
- popeye the sailor, Canute and mtaylor
3
Nice job on the cross section Michael, it will result in lots of questions from anyone with curiosity. Also your Wasa is one of the better ones I've seen, and in particular I find your painting of all the stern figures to be much more plausible than others I've seen, which lean toward colors that are considerably brighter than any that were likely to have been available at the time.
Nice job with the rib tapes, not something most modelers know to do.
- Old Collingwood, thibaultron, CDW and 3 others
6
4 hours ago, BANYAN said:
I have included better pictures of the Spencer Trick Stopper, so you can see how it worked.
Thanks Pat, makes sense now.
I haven't seen real detail about how anchors were released and stowed, what I've found in Seamanship discusses ship movements and actions of the ship, but not the details of what happened with the anchor. I am thinking that the cat hook would have to be removed from it, and then the served rope was released at the same time as any other lashings that held the anchor in place. Is that correct?
Best type of micro drill bits for metal
in Metal Work, Soldering and Metal Fittings
IMO Cobalt HSS drills made for professional jewelers are the best compromise as they offer long life for anything but drilling high carbon steel while not being nearly so fragile as carbide.
