Hello Johann,
agree with Mike - truly elegant framing. And very fine work!
Alex
Current build: HMS Sphynx, 20 gun ship launched in 1775 at Portsmouth, Hampshire.
On the drawing board: HMS Anson, 64 gun third rate ship of the line, launched in 1781 at Plymouth
Very elegant!
Hard to understand the scale - how long is the longboat?
Hello Mike,
the scale is 1:48, of course, like the Corvette.
The model of the longboat is accordingly 18.4 cm long.
Quite something else ... Learned a lot from just a few photographs ... Ist ja wunderbar!!!
Carl
Hello Carl,
thanks for the nice comment.
We continue the construction of the long-boat with the planking.
First, the profiled planks must be made. This is the first strake.
By heating with a soldering iron, the soaked planks can be brought into the required form.
I'm not aware of the credentials necessary to be designated "master modeller" but I would not hesitate to suggest that Johann deserves such recognition.........Always a treat to view your accomplishments!!!
JP
Built & De-Commissioned: HMS Endeavour (Corel), HMS Unicorn (Corel),
Abandoned: HMS Bounty (AL)
Completed : Wappen Von Hamburg (Corel), Le Renommee (Euromodel)... on hold
Current WIP: Berlin by Corel
On Shelf:  HMS Bounty (Billings),
Johann,
As Mick already wrote: A delight to follow such a masterclass! Like the colour of the wood a lot.
Carl
G'day Johann
Beautiful work is all I can say! What is the size of planking that you are using? 6 x 1 mm, I'm only guessing? The tapering is so exact, it's mind boggling!
Haveagreatone
Greg
"Nothing is impossible, it's only what limitations that you put on yourself make it seems impossible! "
Current log : The Royal Yacht Royal Caroline 1749 1:32 by Greg Ashwood:...
Johann,
If it isn't what you imagined, it already exceeds what I did ... masterful, she will be very classy!
Cheers,
Carl
What type of wood are you using? It looks very good, nice color.
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
The planking is looking really nice, Johann
Regards Christian
In German, the wood is referred to as Elsbeere.
In English it is called probably wild service tree?
But I'm not quite sure.
It might be Swiss Pear for the english speaking world (german wiki mentions Schweizer Birne as an alternative name for the Elsbeere) although some of the wood sold under the name of swiss pear appears to be actual pearwood so im a bit confused.
Very well done on the planking.  It's not sanded???  It sure does look smooth.
Hello,
thanks for the nice compliments.
Here is the continuation from boat building:
Hi Johann,
next to your outstanding work on the "La Creole" hull, also the boats manufacturing is beautifuly done
The making of the plugs, the framing and the planking on the ribs is looking fantastic
Nils
Current builds
-Lightship Elbe 1
Completed
@redshirt
@JesseLee
Indeed, that's a little confusing.
But I actually use "Elsbeere".
Hi Christian, Carl, Mark, Greg and Nils,
thanks for the positive response.
The planking is now ready.
The finishing touch still missing.
Here are two pictures.
The removal of the boot shell of the mold will be an exciting moment.
Edited by archjofo
I'm confused too. What is Swiss pear, if it's not pearwood?
