I daresay that this build is the "gold" standard to strive for.  I'm pretty much speechless.
I tend not to look as closely at time periods outside of my specific interest (17th C.), but that is obviously a mistake on my part!  WOW!! Johann, your ship chandlery skills are second to none, as is the fashioning of all the rest of the ship.  What a beautiful model!  I'm late to the party, but I will catch up and follow along until the end.
You are a phenomenal modeller, Johann, your work and realism of model performance are admirable.
Thank you very much for this beautiful inspiration and plenty of useful information about ship equipment.
Best regards,
Doris
Doris
Current build:
HMS Royal Katherine 1664 from card
Hello,
it's always a great pleasure for me to receive such a positive response, for actually a tiny detail.
For the nice comments I would like to say thank you very much, also for the LIKES.
Here it continues with another piece of equipment:
Bouée d'ancre (Anchor buoy)
For the execution of the anchor buoys for my French Corvette, I originally assumed that these were customary around 1800, also made of cork discs (2.5 - 3 cm thick). Therefore, my assumption that the drawing to anchor buoy of J. Boudriot from the monograph to La Créole is rather schematic to understand, as well as the buoy on the Parisian model.
Source: Monograph La Créole
Source: Monograph Original Model
However, the buoys made of cork disks have uniform structures, contrary to the presentation of J. Boudriot; These remind me more of bands or rings. Thus I tried to get even more information for the production of the buoys.
Source: Seventy-Four-Gun-Ship Vol. 2, J. Boudriot
Source: Royal Museums Greenwich
In Franz Ulffer's handbook of seamanship, a buoy with banding is shown. In addition, subdivisions can be seen in the longitudinal direction.
Source: Franz Ulffers, Handbook of Seamanship 1872
Consequently, I tried again to study the relevant passages in the monograph in more detail.
Accordingly, Boudriot describes the buoys in such a way that they consist of four light wood parts, which are held together with a banding. From what these bands should have passed, I could not find out so far. However, it is obvious that they may have been very thin iron bands.
In order to get clarity to the implementation of the buoys in the model scale 1:48, I must probably get some information.
Maybe someone of you can contribute to this?
Sequel follows …
Thank you for your comments and LIKES,
dear friends!
When making the hoops for the buoys, I used a small goldsmith anvil.
The ropes of the slings were served.
To serve the ropes I use a little wonder tool from our member Robert @Tarjack.
In addition, more information: LINK
Johann, I am always in awe of your craftsmanship! I guess these metal hoops are (silver) soldered together from thin brass strips? How do you fix them in position during the soldering to achieve the desired ring diameter?
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Hello Thomas,
recognized correctly, these are thin brass strips.
This I cut with the table saw of a brass sheet is 0.25 mm thick.
After the provisional adjustment of the ring diameter (slightly smaller than necessary), the two ends are brazed with silver solder.
For this I form the ring so that the obliquely filed ends touch on pressure.
I hope I have explained it somewhat understandable with my poor English and using the Google translation.
For safety, the following drawing:
Edited by archjofo
Even small progress by you makes such a hughe difference, Johann. Beautiful!
Edited by cog
Carl
Thank you, Johann, for explaining the making of your rings. It is very nicely explained, sounds pretty easy, and I know it is not. It takes some pretty advanced craftsmanship to get this sort of thing done with the kind of results which you always show.
Thomas
Hello,
thanks for the nice comments, and also for
the LIKES.
An anchor buoy has been completed in the meantime.
I put the buoy rope around the arm of the anchor and tied it to the anchor shaft twice.
The size of the buoy rope is one-third of the cable. The length varies, for it is shortened or lengthened according to the depth of the water in which you will drop the anchor.
Usually the buoy rope  was at least 18 threads long.
I really have to watch out I do not start to drool when you show details like this ... stunning
Carl
