  • Already tomorrow by the time you see this, but I hope you had a fine party.
Bob
Current build:  SS_ Mariefred
Thank you all so much...  Dirk - Steve - David - Denis - Daniel - Christian - Bob - Marc ,
for your Kind birthday greetings yesterday and for your nice appreciations and comments
best regards,
Nils
Current builds
-Lightship Elbe 1
Completed
thank you very much Martin,
Nils
Current builds
-Lightship Elbe 1
Completed
Hello Nils,
I see that you have tried out a sample piece before putting your hands and tools to the job. Just one tip if I may, When it comes to drilling of port holes, this is the worst nightmare for us modelers. Passenger liners and German Warships were littered with port holes. I would strongly suggest to construct a jig tool. this can follow the deck line or the water line, according to how the portholes were actually placed. That is, if they in reality in a straight line or follow the curve of the deck lining. The jig must be able to move along the ship side. This would prevent the twist drill moving around.
If I am not mistaken and stand to be corrected on this, as time may play some tricks on my memory, I should have posted a picture of the wooden jig I made for the Scharnhorst.
Hello Paul,
I just drilled the portholes (not all yet) for the KWdG, and think now I know what you meant with ".. the worst nightmare for us modelers...", and why you recommended to make and use a jig tool for doing so.
Although I was utmost careful with the drilling ( no Jig used :o ) there were some that fell a little bit out of the alignment. For the first upper two rows I will try to mount "eyebrows", also here your comment of the last chance to get the optic a little better are still well in my mind :rolleyes:
As I`m using the porthole inserts without flanges on the outer hull skin, I wo`nt be able to file the holes a little oval in the right direction, in that case there could have been a covering of the "oval hole" by the flange to a certain degree
Nils
it is important to cut a clean hole through the metal plating foil before the wooden planking is carefully drilled through.
it gets tricky if the drill partialy hits a frame or a stringer inside the hull. This must be avoided by check before the hole-positions are marked
for the alignment at bow and stern there is a bit of vertical offset acc to the drawing and the museum model shown and built by others earlier in this log
there are 14 coalports on each side, in the largest coal bunker areas there will be no portholes on the lower porthole level.
The upper side-portholes just below the promenade deck are neighther plated nor drilled yet, because the deck must be put on first.
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Nils, I'm not there with my micrometers, but the alignment of the portholes sure looks good to me.
Bob
Well done Nils!!! I know what you mean about the portholes...It's a nightmare.... Today I ordered the last 160 portholes for my AV from  rbmodels...
Kind Regards
Dimitris
Edited by Dimitris71
Current Build: Amerigo Vespucci -Mantua- 1:100 scale
Completed Build logs: Bluenose II AL 1:75 scale
Gallery: Bluenose II AL 1:75 scale
Future Build: Royal Caroline -Panart- 1:47 scale
Outstanding work, Nils -
Your strake edges are crisp, clean and straight.  That's not easy with metal foil.  You even have the rivet heads lining up at the intersections of the vertical columns and horizontal rows.  No doubling or offset of the pattern.  Congratulations.
Coal hatches are a nice touch.  Did you solder the hinges?
Dan
Thank you very much Bob, Dimitris and Dan,
For appreciations and comments
as well as all the "likes"...
Bob,
thanks Bob, there are some mis-alignment borings, that moved out a bit, which were obviously not able to be prevented whilst drilling (except with a not existing jig tool). Hopefully I`ll do better on the other hull side
Dimitris,
I also used RB portholes on my Pamir and Gorch Fock, a good source choise. They shall look fine on your AV
Dan,
with Jan`s help (identifying one of the appropriate Frames, showing the way of opening for the coalports) I could put the hinges on the top side. Yes, the "hinges" are soft soldered, and then glued on to the hull skin
Nils
Current builds
-Lightship Elbe 1
Completed
for your comments, I`m glad you like it...
Nils
Current builds
-Lightship Elbe 1
Completed
only a small update today...
soldering the 14 ea. port side coalport doors, the starboard ones are already mounted...
Nils
the holding device is of good help when soldering with the flame
clean surfaces, the right amount of flux and careful, steady heating up provides a good joint
all 14 doors done, a cleaning with aceton shall follow next
Current builds
-Lightship Elbe 1
Completed
HI David,
the hull above the waterline will be in dull black resp. anthrazit (charcoal, dark Grey), including These doors..
Nils
Current builds
-Lightship Elbe 1
Completed
A nice Illustration, many thanks Crackers,
all people seem to be happy about dad`s b-day event...
Nils
Current builds
-Lightship Elbe 1
Completed
nice progress Nils  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you Denis,
Nils
Current builds
-Lightship Elbe 1
Completed
Nils, I found,or rather my wife found, my picture of my Titanic. Turns out I built it 20 years ago. The plans were French but I got them from Taubman. The model is scratchbuilt. Bill
Edited by reklein
Bill, in Idaho
Completed Mamoli Halifax and Billings Viking ship in 2015
Next  Model Shipways Syren
Fascinating! Hinges smaller than 1mm, and as it is not enough - soldered !!!
You are real wizard Nils
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Bill,
that really is a very impressive model, and the sideboard below is just long enough for the distribution glass-case, Well done
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you Nenad,
you`re right with the hinges, they are made from 0,6mm brass wire, and soldered in 0,6mm drilled holes, the plates are 6 x 5 mm and 0,5 mm thick brass plates
Nils
Current builds
-Lightship Elbe 1
Completed
The anchors,
found these good looking and scaled heavy metal anchors, in nostagic design of 1900 in a Hamburg based modeling web shob.
The parts are of castings and have to be deburred, the vertical bar and the hole in the spike-base have to be reworked a little larger, I`m glad I found them, love that nostalgic look with the long spikes.
Two will go at the bow, one at stern and two in the spare anchor supports on the forecastle deck
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you very much Dimitris,
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 23
little update
not much this time, but it keeps the wheel turning...
Nils
in this lower deck area there are the bulwark doors for the kay gangways
mended two misalignment portholes with wooden dowels and drilled new...
upper forecasle side-rail, and aft forecastle-deck bulwark
Current builds
-Lightship Elbe 1
Completed
Thank you David,
your comment is very much appreciated.., I`m also quite happy with the Project so far. Presume that doing the superstructure will be far more ambitious...
Nils
Nils
Current builds
-Lightship Elbe 1
Completed
Okay, I also need a new Thesaurus as I'm lost for words. Brilliant work Nils - I'm really enjoying following your progress here.
