Thank you Jason,
from now on the design goes after the sequences requirements, I have a certain pattern im my mind, but still there may come some unforeseen necessity for short term adjusting here and there. If I were designing a "kit" one could say,,, the first prototype and see what comes out...
Nils
Current builds
-Lightship Elbe 1
Completed
I love the size Nils!    simply awesome......slip set up is awesome too!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
thank you for your nice complement Popeye,
very much appreciated..
The size was limited to max. 1500 mm, looks like it will turn out appr. 1390 to 1400 mm over all, but still considered as scale 1:144, but its going to be a "beast" compared with my other models.
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks for dropping in Nigel,
and thanks for your nice appreciation
its good to hear from you again, hope all is well on your side (job and house moving related....)
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you very much Bob and Mr. Pucko,
and all the "likes",
Bob,
I was also very much interested in building a British Naval Cutter of 1777, but then favoured this odltimer Atlantic runner which was also on my list as the next Project.
AnywayI have saved up all my gathered cutter-Information and plans though, perhaps for the overnext...
Mr. Pucko,
Thanks for your Kind appreciation
Nils
Current builds
-Lightship Elbe 1
Completed
Hartmut and John,
thank you very much for your Kind words and your interest in this build...
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Build log part 5
preparing for attaching the stingers to the frames
all frames are set and glued in. The cut out notches for the stringers are also done
there are three places, where the  3 stand M4 spindles go through keel and square bar. Some supporting ply bits prevent later distortion of keel when spindles are tightened to the stand
spindle fitted in and reinforcement cladding both sides to the keel
there are locking nuts M4 on the inside of ship (into the sqare bar)
bow post fitted in and beveled to angle where the later planking will lay on
Stern is also prepared for putting on stringers
the stringers have been cut with my hand- circular saw, (which I fitted as a table-saw) Then cut the 2 m long strips from a 5 mm thick plank. I wanted to have the stringers over the full ship length in one piece
Nils
Current builds
-Lightship Elbe 1
Completed
a very interesting design.......I like the idea of the stringers.    I also like the size ;)   super progress at this point Nils  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Popeye,
my other ship hulls are also built comprising stringers of pine wood. If the stringers follow the frame outer contours without dents and boils, the planking afterwards shall be an easy job to do. Also the stringers provide very useful hold for glueing and for for all the pegs and pins whilst planking. It is also much easier to do the sanding over the stringers and same time in some places the slightly overstanding odd-outer frame potions when fairing (before planking)
I do single layer planking, 2mm thick and use mostly only white PA glue. I do`nt use screws or nails for planking
Nils
Current builds
-Lightship Elbe 1
Completed
Nice work Nils, Shes looking really good
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Thanks very much Pete,
Nils
Current builds
-Lightship Elbe 1
Completed
Those days I felt some magic appear on MSW, but could not locate it
Today I find your log, and now I know. You are obviously one of the MSW modeling wizards
Can I join  ?
Fantastic work, as always
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Impressive project :-)
Love it !
XXXDAn
Many thanks Nenad and Dafi,
and all the "Likes".....
Nenad,
thats a nice comment , also wish you all the Magic on your CS, I saw you (like it..) are making so many Details by yourself
Dafi,
Thanks Dafi, glad you like it, and greetings from Glinde to Ludwigsburg
Nils
Current builds
-Lightship Elbe 1
Completed
Starting with the stringers.......
it takes appr. 2-3 hours to have the glue cured, before removing the pins and the pegs for the next glueing session
I`ll have to move the screws that hold the frames more to the outside for having better access to the srews now, before further stringers are put on
the relatively long and gentle bows do not bring too much tension on the on the wooden strips
the tricky part of the job though will be the stern portion, maybe I shall use filler pieces to a certain degree....
Nils
Current builds
-Lightship Elbe 1
Completed
I've been following along so far, and I'm really excited to see this starting to come together. She's a very nice subject, and the type of ship I don't see done a lot on here (but maybe I'm just not looking in the right places.) You're going to do her justice, I'm sure of it.
I'd love to have space to build and display a model of that size.
~ Ben
___________________________________________________________________________________________________
Current Builds:
'Doll-Boat' - 1:12 scale 40' Cruising Sailboat
S.S. Edmund Fitzgerald - 1:350 plastic kit w/ Photo Etch Parts (On Hold)
Another interesting build that will teach me something and how how much I have to learn.  You know how to pick a project Nils.  I might have missed it nut how did you determine the notches for your stringers?
David B
Edited by dgbot
Many thanks to my fellow building mates   Mark - Patrick - Robin - Ben- David,
and all the "likes"
Mark,
I`m happy that you like and enjoy following the progress...
Patrick,
whilst doing the hull I can well imagine, what the actual designers had in mind way back in 1897
Robin
thanks very much. I do hope that the original shaped ship`s magnified shape and lines can be brought into this model, I also love the shape of this early engineering and shipwright design
Ben,
I appreciate your nice comment, and hope you shall further enjoy......
David,
I`m glad you like it. For determining the stringer notches I refer my own drawn frame plan. I`ve set a stringer  at the outside frame contour at the crossing point of every horizontal deckline (see pic below)
Nils
how to determine stringer notches.....
The bilge keels will be brought in later on...
Current builds
-Lightship Elbe 1
Completed
looking very nice Nils!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you very much Popeye,
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks for your nice complement Lee,
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 6
Today I built two prop tubes 6 mm diam. with glide bearing bushings at both ends to take up the propshafts made from 3 mm round Brass bar.
some more stringers have been cut and most of them already brought on. Now the sub waterline streamline end claddings were shaped and dry fitted to place. For doing so I had to mount the shafts and the props to check out the clearance to the hull.....
dry fit of props and shafts
two more stringers will go to the port side
note the fastening screws for the frames, I set them to the outside for better access now
the propcircles go so close to the hull, there`s hardly 1/2 mm or less clearance
the base can be tuned to every desired way for all round access
the lines are extreme sharp and slim, just like the actual ship
the portions above the upper stringer line ( line of Promenade deck) will be cut off, when the hull is removed from the base later on
Nils
Current builds
-Lightship Elbe 1
Completed
