Nils, Great looking vents, you must see them in your sleep after making so many. :)
Zipper hydroplane(Miss Mabel ) finished
John Cudahy  Scratch build 1/4" scale Steam Tug
1914 Steam Tug Scratch build from HAMMS plans
1820 Pinky  "Eagle" Scratch build from; American Ships Their Plans and History
It was nice to do a little catching up, Absolutely incredible work Nils
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Thank you so much for your kind appreciations and compliments - Bob - Albert -Nenad - Bill - Steve - and Pete,
and all those that expressed their "Likes" recently...
Bob,
I`m pleased you like the vents...
Albert,
a nice compliment, thanks very much..
Nenad,
much appreciated, thanks very much...
Bill,
sorry for the wrong term in this relation, and thanks for putting me on track again, much appreciated..
Steve,
the learn curve sets in at an early stage, this evening I made a few more bowls, and am pleased how fast they can be done now, Am still looking for some with only 10 mm diam. (found some and ordered at Ebay already, hopefuly the turn out right)
Pete,
thanks very much for your words...
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
awesome vent assembly line.........they really look good  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Denis,
thank you for your nice compliment, ...
I just received the smallest bagfeet with 9,5 mm bowl OD, and 4 mm vent tube, am removing the clips and shall probably solder 20  of them tomorrow
Nils
Current builds
-Lightship Elbe 1
Completed
that really is a good idea........most vents I've seen have no throats........they look so fake  ;)    I've taken Billing's vents and drilled them out {of course,  after I cement them together.   I think it's great!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Denis,
trust now all vents in raw, basic shape are done. There are so many, that I had to make a plan, which and how many go where...... For the length adjustments there is a bit surplus tube on every vent. The pics show the variety of sizes, tube / bowl diameters and raw lengths. The plan though is not in scale ( only to give an overview)
Some of the tubes go through the boats deck and remain visible looking on the promenade deck, some tubes will be blended behind vertical claddings on the promenade deck
Nils
Current builds
-Lightship Elbe 1
Completed
Bag feet ventilators.  How ingenious...my kind of ingenuity.
Fantastic job...everything looks so awesome.
Rob
Current build:
Finished build:
Current build(On hold):
Thank you very much Rob,
like your compliment...
yes, I`m quite pleased with the metal vents. (bowl on tube). In opposite to later liners, after WW1 the ships started to show more streamlined type vents with not so easy to model designs. I often ask myself how the builders-model makers made those, if not from rather expspensive resin cast tools and moulds
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils
Re vents for post WW1 liners. I have seen then made using a shaped plug which is pressed into a circular die. The vents are usually made from copper with many annealing steps to avoid work hardening and splitting. The tubes are than soldered on and the hole is cut from the inside of the tube. I am planning to have a go at this method later on in my current build....... just for the experience!
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
I'm sure glad my Pequot didn't have that many vents.
Bob
Current build:  SS_ Mariefred
Hi Nils
Many thanks Keith,
Am very interested in the technique you describe, shall certainly be watching when you go for it....
Nils
Current builds
-Lightship Elbe 1
Completed
Update
40 deckchairs and 20 benches in scale 1:144
This is what the good looking filigrane etched build brass kits look like. Will be quite a tough soldering job to get things into the right shape I guess...., have`nt started yet...., may require some holding gig.... If they workout, its worth the effort...
Sorry for the flash reflections on the last three pics
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks Carl,
I have no doubts with the deck-sitting furniture, its the style of the era and looks good regardless to the ships name. Besides that I was pleased to find any at all in this scale . There were some benches in plastic (train gauge N ), but they did`nt find my approval....
Nils
Current builds
-Lightship Elbe 1
Completed
I'm with you. those chairs and benches will look great on the KWdG.
Bob
Thanks very much Bob,
yet I`m a bit anxoius to start the soldering of those tiny, thin parts. In this case even a drop of solder would be too much, I am thinking of using tiny portions of soft solder paste (flux already mixed by) in scarce limited dosis aplication. I remember using this once for gas tourch soldering 0,4 mm brass railing wire to stanchions on the "Heinrich Kayser" steamer model. Will do some trials first....
Nils
Current builds
-Lightship Elbe 1
Completed
I'm sure you will do a fine job, my friend.
Bob
Nils,
Presently I'm building a 1:72 Fokker Dr I, mainly brass. Everything is glued with CA. You can forget soldering, you'll ruin your parts, far to fragile.
Edited by cog
Carl
Carl,
thanks for your kind comment...., I´ve been thinking of that alternative in using CA as well, in fact the manufacturer of these parts recommends the use of super glue..
Nils
Current builds
-Lightship Elbe 1
Completed
I'd recommend  CA  also. You'd just be going round in circles trying to solder and resolder joints However you should be able to find a 12 watt soldering iron online. Used for soldering tiny LEDS. Things would need to be jigged up to hold while soldering which you probably know already.   Bill
Bill, in Idaho
Completed Mamoli Halifax and Billings Viking ship in 2015
Next  Model Shipways Syren
Thanks Bill,
much appreciated your suggestion,   ;)
think I´ll sacrifice one of the etched parts for trials, if I should loose confedence, the CA stands ready anyhow...
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you very much John,
your compliment is much appreciated, and I saw you were catching up with the build log, thanks for looking in.
Today I assembled one of those benches ( fiddely stuff I must say !  ), but I think its acceptable with a bit more routine it will do.... Trust Bill and Carl were right with their recommendation to avoid soldering (thanks again Bill and Carl) , The CA connection of parts is strong enough for this.
Also thanks to those for all the " likes"
Nils
Current builds
-Lightship Elbe 1
Completed
There are no frontiers for you, Nils !
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Many thanks Johann and Nenad,
for your nice and appreciated words....
Nils
Current builds
-Lightship Elbe 1
Completed
What a lovely little bench.
Bob
