Part 100 –Oyster Dredge Cont’d
In a previous post I described the soldering jig that would be used to create the sides of the 2 dredge bodies.
The pieces to be soldered were primarily .020” brass rod.  In addition, 24 gauge copper wire was used for the rounded ends, 1/32” rod was used for the main structural rod on the sides, and 3/64” rod was used for the tooth bars.  Given the small size of most of the pieces, I used a low melting point solder paste. The reason for this choice was to avoid damaging the small pieces with high heat required for other solders. Even so, the heat of soldering did cause some unwanted bending of the thinner pieces.
The following photo shows the solder that was used, along with a couple of tools that were used to apply the solder.
The side was clamped to the soldering jig using small machinist clamps.  These clamps also served as legs to raise the jig.
Some of the pieces wanted to raise from the pressure of the clamps, so a small weight was used to keep the pieces on the jig.
After the sides were completed they were attached to the former using 2-sided tape.
The former needed to be held steady, but the odd shape of the dredges made clamping the former difficult.  I tried several approaches for holding the former. First, I tried using a ‘painting stick’ that is designed to screw into the workpiece and had a heavy base.
This wasn’t steady enough, and any pressure on the dredge sides loosened the bond of the tape and caused the sides to move out of position.
The next arrangement I tried wound up being the one that was used.  The former was held in place on a magnetic squaring jig, and wedge-shaped pieces were pressed against the outside to make the whole arrangement square.
This wasn’t ideal – the sides still tended to move out of position, but it worked well enough to use it.
After a lot of do-overs, frustration, and cussing, the dredge bodies were soldered together.
The dredge bodies were cleaned up and primed.
And, finally, were painted flat black.
So now the ‘easy’ part of dredge construction is over. Next up is the installation of the ring net and rope net to make up the body of the dredge.
Thanks everyone!
That's a dredge and a pretty darned good one at that scale kudos.
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
Nice bit of soldering Frank. Truly a part of the model that you will be proud to look at, knowing what it took to build them.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
22 hours ago, Omega1234 said:
Hi Frank
Once again, you’ve made a complex job for a mere mortal, such as me, look incredibly easy.
Very, very nice work....but, then again, that’s totally to be expected.
Have a great week.
Cheers.
Patrick
Hi Patrick - yeah - I made it look easy in the photos, but it was very frustrating to say the least.  I guess practicing perseverance is good thing, though.
Thanks John.  I'm glad I'm not working in a smaller scale!
Thanks Lou.  I'm actually very pleased when I look at any part of Kathryn - a fun build and easy to look at.
11 hours ago, allanyed said:
Great use of a forming jig!  Including the dredge tines is quite an achievement
Allan
Thanks Allan.  The Sherline Mill made the tines a fairly easy job.
9 hours ago, druxey said:
Neat solution using Corian for the jig!
Thanks Druxey.  The Corian doesn't let solder adhere to it, and resists burning pretty well, especially when using resistance soldering.
5 hours ago, Jim Lad said:
Just catching up, Frank.  A very nice job of soldering on those dredges.
John
Thanks John.  The wonders of soft solder and a resistance soldering setup.  Using a micro torch would have been a different story, I think.
On 6/2/2019 at 6:39 PM, thibaultron said:
Great work Frank! The dredges look fantastic!
Thanks Ron.  They came out pretty well, but as you'll see in the next post they needed some additional work.
I sent photos of the dredges to a good friend in the Chesapeake area.  He’s an excellent modeler with extensive knowledge of the Chesapeake workboats, and he was quick to point out that the ‘apex’ (nose?) of my dredges was wrong. He sent along the following photos of an actual dredge.
So obviously I needed to correct this.
I started by soldering two straightened pieces of 24 gauge copper wire together.  I used the soft solder with the following setup.
I cut the resulting piece in two, so that there was enough material for both dredges.  One end of the piece was formed into a round eye – this will take the ring that is used for the dredge cable.  The eye was formed by wrapping the wire around the jaws of a small pliers that was shaped for making rings, and then was tightened using small straight pliers.
The eye of the workpiece was clamped by a small machinist clamp, and then the arms of the workpiece were pulled apart - easily done because of using a soft solder.
This made the shape of the apex for the dredge.
The apex was epoxied to the dredge body, using two-part epoxy that had been mixed with talcum to prevent the epoxy from spreading too much.
The front of the dredge was primed and painted.
Now, back to work on the nets.
Cheers!
An eye for the details and the skills to build it.   I'm at a loss for words.
Thanks Mark.  The details are a result of the excellent reference material I've been lucky to have, plus access to some folks who really know the Chesapeake watercraft.
4 hours ago, EdT said:
Amazing work, Frank - very impressive. Hats off.
Ed
Thanks Ed.  It has been a fun journey and a great learning experience.
Thanks Carl.  I'm not sure I would have been able to get the dredges completed without using Resistance Soldering and a very low temperature solder.  That combination allowed me to solder very close to existing joints without disturbing them too much.
Hi everyone.  Thanks for following my work on Kathryn, and for all of the encouraging 'Likes' and comments.
I haven't been able to get in any shop time since the last post - too many things needed to be wrapped up before our planned vacation.  We'll be leaving on our trip tomorrow, and won't be back for a few weeks.  I won't be able to post any updates until the end of the month.
We'll be staying in a nice condo and plan to spend a lot of quiet time, so while we're away I'm hoping to start drafting the plans for my next build.  If that works out I may start a new topic to cover that.
In the meantime, I hope you all enjoy a healthy and happy June 2019.
Enjoy your vacation! :champagne:
Part 102 –Oyster Dredge Cont’d
Hi Everyone
It’s been about a month since my last update. We had a very enjoyable vacation, then shortly after we got home some unexpected company showed up.  So there hasn’t been very much shop time lately.
After my last update I tried out the dredges on Kathryn’s deck, and discovered that they are slightly too large.  They look ok hanging off the side, but I want to display one on the deck and one off the side, over the roller.  So, after a lot of thought I decided to build new dredge frames that are reduced by about 15%.
Because of the issues that I previously ran into regarding holding the pieces while soldering, I decided to make a jig that gave me a lot more control.  The wedge shaped main body of the jig is drilled to take a 6-32 threaded rod, and two smaller wedges slide over this rod to hold the two sides in place.
A pair of 3/64 brass rods are inserted in the bottom of the main body so that it can be held in the vise.  This new jig provided a much more stable base for soldering the dredge body together.  Following is a photo of the dredge ready for soldering.  The rod with the tines, or teeth, is held in place by a third hand.
In this latest pair of dredges I planned for the apex (front of the dredge) before assembling the dredge.  The next photo shows the sides for the new dredge, with the apex extension already formed.
The final photo shows a new dredge next to the previous version.  I’m happy to report that the new dredges are a good size, and look good on the deck.
Now for the final part of the dredge construction, making the ring and rope net.
17 hours ago, druxey said:
Lovely work, Frank!
Thanks Druxey!
10 hours ago, allanyed said:
These look REALLY well done.   I have always been a proponent of silver solder, but you have given me pause after seeing your use of low temp solder and now epoxy for the last tongue/extension piece.   Well done.
Allan
Thanks Allan.  The low temperature solder paste with resistance soldering worked really well on the very thin brass (.020) rod.  The epoxy rescued my first attempt, but the last (and hopefully final) dredges have the tongue built in.
9 hours ago, Omega1234 said:
Very nicely done, Frank!
Cheers.
Patrick
Thanks Patrick - it's good to be back at 'work'.
3 hours ago, PETERPETER said:
Bravo! Ever the perfectionist. Were you able to make any progress on your next build while away?
Hi Peter.  Yes, I did some initial drafting for the next model while away on vacation.  I'll probably start a new log in a month or so.
Part 103 –Oyster Dredge Cont’d
Kathryn’s dredge has a net of rings and a net of rope forming the ‘basket’ of the dredge.  In Part 96 (post #762) and Part 97 (post #798) I discussed my planned approach to making the ring net.  I spent over a dozen hours making the strands of rings required for the net.  Joining these strands into a net was the planned next step.
I set up a configuration that was intended to allow me to join the strands by tying the strands together with the fly tying thread, as in the following photo.
Joining the strands required tying from ring to ring along the strands.
The process of joining the first two strands was time-consuming and frustrating, and when I got to the third strand it became nearly impossible to keep the strands properly arranged.  I realized that making the ring net this way would take more time than it was worth, and the results would be questionable, at best.
So, I looked for alternatives.  My wife suggested using a piece of costume jewelry that was quite old.
This would have been a great approach, but the rings were more than 3 times the size I needed.  I also looked at netting fabric, and found one that would work.
Unfortunately the ‘rings’ in the fabric were also too big.
A friend of mine (a military modeler) has a Silhouette Cameo III cutting machine, and volunteered to try to help.  Using CAD, I drew strings of rings and he reduced the scale to the smallest the cutter could produce.  The resulting parts cut out of a thin plastic sheet were quite good – a little bigger than the scale called for, but would work.
My hope was to produce two versions of the dredges, one sitting on the deck and one hanging off the side of the hull.  I used the plastic rings to create the one for the deck first.
In the enlarged photo the rings don’t look that great, but in actual size they look good.
After painting they look even better.  The quality of the photo doesn’t do justice to the rings – I dry blended some grey on them to highlight the curves but this doesn’t show up in the photo.
The next effort will be to make the dredge basket that hangs off the side.
Frank maybe early but are you going to add rope lacing from rings to upper bar?
Necessity is the mother of invention, problem solving A#1 Kudos.
John Allen
On deck
Finished
