Halifax by rafine - FINISHED - The Lumberyard - 1:48 - semi-scratch schooner
that is a really nice job on the transom Bob!   the decorations came out look'in sweet  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Share on other sites
Link to comment
Well done. I very much like the completed look.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Thanks so much Grant, Michael, Rusty and Jim for the kind words, and thanks also to the "likes".
Jim, I'm afraid that with age the skills become more tricks than physical abilities, but I appreciate the thought.
Bob
Link to comment
Just catching up here Bob - truly wonderful work as usual. The Halifax looks like a really fun project - and I'm also glad to hear you made it through the weather ok!
hamilton
MS Glad Tidings (1937) (in need of a refit)HMS Blandford (1719) from Corel HMS GreyhoundFair Rosamund (1832) from OcCre Dos Amigos (missing in action); Amati Hannah (ship in a bottle); Mamoli America (1851)Bluenose fishing schooner (1921) (scratch); Off-Centre Sailing Skiff (scratch)
Link to comment
Work on the outer hull began with the quarter badges. As with the transom, i needed to make a decision as to how to handle the carvings. My answer was essentially the same; I couldn't make my own; I couldn't use the laser cut carving pieces from the Lumberyard; so I had to use the resin castings from the kit. To use them, I first cut out the windows from the castings and then painted them to mach the hull wood, with a bit of black background. I liked the paint better than what I had done on the transom, so I did some repainting on the transom to try and match. The windows are, again, the Lumberyard laser cut ones, again thinned down considerably. The glazing is again Micro Kristal Klear.
I then made up the main channels from boxwood strip, painted them black and glued and pinned them in place.
Lastly, I started to add moldings to the hull sides, The lowest is half round and the others are a simple double bead. All of the moldings will be painted black. The moldings were simple to place because when planking the hull I had used base pieces for the moldings in the planking and was able to just follow those base pieces when attaching the final molding pieces.
Bob
Link to comment
Nice work Bob, the quarter badges and stern look real fine together
Link to comment
Very nice transom, Bob! The paint on the carvings looks very much like wood!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Link to comment
Link to comment
Thanks so much Zappto. Yes, I used Micro Krystal Klear. It is very easy to use. You just dip a tooth pick in it and then swirl the toothpick in the window frame opening until it it is filled. Each pane is done individually.
Bob
Link to comment
Once again, some rainy weather led to extra modeling time. I accomplished a few things.
 First, image and mounted the rudder. The basic piece was the laser cut part from the kit. I had to add a piece to the upper portion to enable a proper fit through the deck. I then shaped the fore sideband tapered the aft side. The pintles and gudgeons were done with black painted paper (I avoid metal work whenever possible) with blackened brass for the working parts. The tiller was cut from boxwood sheet and rounded where appropriate. It was then attached to the rudder after the rudder was mounted.
I then started making and mounting the various timber heads. These were made from boxwood strip, shaped with files, painted black and mounted to the cap rail with pins and glue.
Lastly, while access was still easy, I started drilling holes for, and mounting eyebolts for future rigging attachment, including the aft most guns.Many others remain to be done. I also added a black wire horse for the boom sheet, on the inner transom.
Bob
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
