IJN Ise 1944 by RGL - FINISHED - Fujimi - 1/350 - PLASTIC
you gotta give yourself a little credit though.......a lot of these parts are as small as the P.E. your using.  not to mention the set up and paint ;)    wonderful bit of progress there!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Share on other sites
The kit provided anchor is pretty much rubbish, the stock is a curved piece of plastic! There are also no stern anchors provided.
I widened the hawser holes holes and used a North Star anchor set, joined to the Artwox chain, running strait through to the capstans. Hawser holes covers, chain stoppers and brake handles, as well as covers for the bit where the chain runs into the chain locker.
The bit where the chain runs was recessed into the deck after the wooden deck was used, so I used the cut outs as stencils to cut plastic strip to fill the holes.
Mall of the bollards from the kit were shaved off ages ago and are brass on plastic strip.
Little bit of weathering, and railings to go.
Greg
Link to comment
Should you have thickend the "chain gutter" on your previous builds too?
The wheathering looks really good on the bow and forecastle, as does the colour. You picked up these trades very quickly mate ... inspiring ... very much so!!!
Carl
Link to comment
It's good you are stubborn mate ... that will make you finish the work at hand. That trapezium muscle is a bit over extending yourself, you know you should do it with your hands right - by the way left or right side ...
Railing is looking good despite your muscle pains
Carl
Link to comment
The Pagoda has been lightly weathered with grime, rust and salt. The lugs that go into the deck were cut off and it sits almost perfectly snug without glue. I'll weather the funnel next, then once attached I can add the crane and it's rigging. You can see from the close up there is a lot of detail to add, and I still need to add 9 25mm's, and do up the remainder of the 13.7cm guns plus one barrel which has gone god knows where.
Greg
Link to comment
really nice work Greg!   look'in super  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
The stack, or funnel. Horrible bit of kit as the PE really needs to be done up with the deck to get the alignment correct which if flat out impossible with the wooden stick on deck. Good enough for government work and weathered using black pastels for soot.
This is the last main structure with only the mast to go and then lots of planes, boats and guns.
Greg
Link to comment
I still think you don't give yourself enough credit......she looks awesome!   the funnel structure looks so realistic.....WOW!   now if I can only learn a fraction of what you do with these vessels.......I think I'm too old to learn new tricks  :)   beautifully done Greg!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
I haven’t posted for a while because there has been an enormous amount of small piecework to do. Putting a fence around the back veranda; I don’t know if the flight deck had railings, but I know the rear bit did as the video of the ship in 1945 shows it. I’ve added the 6 rocket launchers at the stern, the turntables and done up the 25mm’s. That is just back breaking work, 31 triple 25mm’s, each with individual barrels and magazines and 11 singles. Tomorrow I can start throwing them on. The baseboard was made up for me and is a beautiful bit of hardwood with Tung oil to season.
Greg
Link to comment
She is looking superb greg easily your best to date  pure genius.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
There is always a certain amount of hands on - reaching across - holding a model to do work on them, and sometimes parts get broken or knocked off, but your work with extra fine details always looks as if you have mini robots doing the work for you, or you must have a surgeons hands.
Amazing.
OC.
Current builds
Completed works.
Link to comment
Work inboard to outboard. Wait till you see the convoluted mast. I was starting to get a bit stale with this build, and considering I still have the ship’s boats and aircraft to go I think I’ll be well and truely over my IJN phase after this one.
Edited by RGL
Greg
Link to comment
I still salute your experise greg  I know not just me but a good few of us think you are a master craftsman,  and have established a benchmark on here pushing the boudaries of plastic modeling.
Good on you greg.:cheers:
OC.
Current builds
Completed works.
Link to comment
"set the TV aerial up... " At least you can watch "The Man in the Yellow Hat" during a lull in the fight ...
Great work on the mini flight deck, although, I wouldn't have expected a railing on it. On the other hand the crew, sizewise, would easily be blown off. You've got yourself a very nice base board too. Hope it fits in your collection, if not you may always send it over.
Didn't know you could phase out ... but what will you phase in to after this one ...
Marvelous work again Greg!!
Edited by cog
Carl
Link to comment
Who's been a busy boy then :)  Looks great Greg.  Here you are nearly two done, already bought the third and I have hardly dented the build of the Victoria :( - but I have been a little distracted with making furniture for the latest addition to the family - a lovely granddaughter :)
cheers
Pat
Link to comment
Very awesome update!   so much detail...........it's amazing  :)   railings look sweet!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
