Great having you back at the Epic scale.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Glad to have you on board, OC.
With this Mikasa model, I am hoping to tune up for the next big project coming up. I need to decide between these...cast a vote if you wish:
1:250 Woody Joe Akagi
1:250 Woody Joe Yamato
1:250 Arri Yamato with Very Fire update set
1:200 Trumpeter Iowa with two huge Pontos Update sets. One is the detail up update set with the teak deck, and the guns update set.
1:200 Trumpeter Bismarck with full update sets.
All these big models are sitting in my closet, waiting to be built.
7 minutes ago, GrandpaPhil said:
That’s going to be one of my upcoming projects (eventually).  I bought the Anatomy of the Ship for the Yamato.  I’d like to build in 1:150 or 1:200 scale.
I would like a 1:200 scale Yamato as well. But I am hesitant to shell out $500+ for the antiquated Nichimo kit that will require another large investment in aftermarket to do it right. I keep hoping that Trumpeter or someone will come out with a newly tooled 1:200 Yamato. Seems to me there would be a market for it.
This is where I left off and where I begin, again. Gun port doors. Builder has the option of posing the doors either opened or closed. I'm going to have to carefully examine the locations of the several torpedo net booms that line each side of the ship so that installation of the doors (open doors in my case) don't interfere with the installation of the boom hanging hardware.
Edited by CDW
36 minutes ago, yvesvidal said:
So you are going for the grey hull and superstructures as it is painted today.
Yves
I am using black-gray for the hull color. I never use straight black. The flash on the camera lightens it up WAY more than it appears in person. This is more how it actually looks:
Edited by CDW
CDW, try placing a single layer of Kleenex (brand or any similar brand) tissue over the built-in flash when you take the pictures. If one layer still is too bright then add another layer.   The tissue will diffuse the light, make it softer and help keep from "washing out the color" in the extreme close-ups.  You'll have to experiment with the number of layers of tissue until you get what you want.  It's an old photographers trick.
Jack
Current buildUS Constellation
I didn't know you had this project in the works!   you gotten off to a very nice start so far :)   glad to see your continuing the build.......very interested in following along  :)
BTW......my vote is for the Iowa.........I'm a sucker for a gorgeous battleship  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks for the kind comments. I should have mentioned, I also have the 1:200 USS Hornet to add to the mix.
Much better with the flash trick, back in my days we used to experiment with all sorts of flash diffusers, anything we could find around the house realy.
Anyway great progress  - see your at the the captains walkway.
OC.
Current builds
Completed works.
On 8/10/2018 at 10:05 PM, CDW said:
Following Jack's advice, I took the last two photos with a piece of tissue covering the flash. The other pictures are taken without a flash, low light.
That worked well, Jack! Thanks for the tip.
That worked well.  You can play with the light intensity just by adding or removing layers of tissue.    Nice work on the boat and painting.
Jack
look'in very nice CDW :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
5 hours ago, CDW said:
It's Vallejo black-gray paint.
You might get a problem if it is applied on bare brass ... looks very crisp though, can't beat an airbrush at these details
Carl
To avoid problems with painted photo etch, the PE must be prepared sufficiently to give the surface something where the paint can "bite".
I first place all my photo etch sheets into a warm sonic cleaner using a small amount of Dawn dish washing detergent and leave to clean for about five minutes. I then thoroughly rinse. Next, I place the sheets in a diluted bath of vinegar for a few minutes, then rinse thoroughly again. I place the sheets on paper towels to dry.
When the PE sheets are dry, all the oils and glossiness are gone. Paint can get a bite into the metal when applied. Failure to do this can and will lead to problems with paint adhering to the PE regardless of whether it's primed or not. Primer is used primarily to fill minor surface irregularities (which photo etch does not have) and to provide a surface that finish paint can bite. There are no qualities inherent in model primers I am aware of that give a better bite to photo etch in and of themselves. In automotive body applications, we used "self etching" primers on metal bodies before finish paint. This primer actually causes the bite into the metal all on it's own...self etching. But those types of primer are far too harsh for modeling purposes and besides, many modelers would kill themselves using it for not having appropriate respirators/ventilation.
