All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
20 minutes ago, Kevin said:
brasso e wapparantly is ok for glass, but im surprised it was damaged that much just using the wrong side of a sponge
Yep  it was a fresh sponge with the brasive other side  - I too didn't expect it to scratch glass,    what do you think will be best  brasso or rouge,  it would have to be available in out of town as we are limited here for DIY places.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
12 minutes ago, marktiedens said:
Wallace has a good idea - try using toothpaste.  I`ve used it on plastic & can get a mirror finish.  Way back when I built plastic car kits I would polish the plastic body parts with toothpaste & it would look better than paint.
Will it work on glass though?    I assume the glass in this magnifier is similar to whats used in telescopes.
OC.
Current builds
Completed works.
Mark and Wallace are right. Toothpaste can work as a pretty good polishing compound. If you were able to scratch it that easily then you should be able to polish it out as well, but if that fails You can try Johnson floor shine.
https://www.ebay.com/itm/Johnson-S-C-Inc-Future-Acrylic-Floor-Shine-Finish-Floors-Wax-Home-Cleaning-Home-/252295061184
(At least I think that is the current bottle) It may even have a different name where you live but whatever, if you coat the glass in the floor shine all of the scratches will go away just like they do when the glass is wet.
Good luck
Edited by lmagna
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Good luck
Thanks lou,   you can imagine my face  :omg:   it was priceless  - I nearly fell to my knees in the kitchen when I saw what I had done,   I just thought  "How can I finish her now  - Im blind as a bat"   I even bump into the door frame when going out lol.
OC.
Edited by Old Collingwood
Current builds
Completed works.
17 minutes ago, Wallace said:
Yes, toothpaste is like a very mild grinding paste. I even used it years ago to put a fine finish on valve seats when I was grinding them in on an engine rebuild!
Thank you wallace  - I will pick some up tomorrow  - just the plain simple unflavoured white variety?
OC.
Current builds
Completed works.
Might as well get the stuff you will use anyway. It is almost certain that you will have a bunch left over.
All kidding aside, you might look at Crest Pro-health with a RDA value of 189. RDA stands for relative dentin abrasivity. Teeth have a hardness of about 5, a diamond is rated at ten. So combining the factors used to measure this hardness teeth come out at about 7 RDA, meaning that your toothpaste has to be at least that hard to polish your teeth. As you can see Crest can easily do the job with room to spare. should do the same on glass or plastic.
The only higher abrasion I could find was Colgate 2 in 1 Tarter Control/Whitening or Icy Blast/Whitening listed at 190-200! There are of course many that are lower and would give a finer polish. But then so would using the same toothpaste for a longer time and adding water. I have the list if you want it.
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Thanks for that lou, I have just been looking online at our local store to see what they have - not seen the above mentioned but they do have many others.
OC.
Current builds
Completed works.
I will PM you the list so you can compare it with what you have available. You may not have access to the higher abrasion formulas where you live. The list is a bit long.
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Dooh... I forgot about the toothpaste trick.   Been so long since I've dealt with scratched lenses.   facepalm_48.png.dba6c4171564dd12b2404f59826e6c3b.png
This is what makes our forum so special  - we are like a family  looking out for each other and helping where we can.
OC.
Current builds
Completed works.
I have not done it myself, but there are a lot of videos on youtube that show how to remove scratches from glass. I would assume that yours would not be very deep given how they were made and so, one of these techniques with the buffing compound should work.
-Well, after I posted that, my page refreshed and all of those better responses popped up. Gotta love technology some days... 🙄
By the way, work on the ship prior to the whoops, was looking great! :)
Edited by EJ_L
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Thank you sincerely EJ.
OC.
Current builds
Completed works.
Back to normal   - toothpaste  to the rescue   - final result     magnifier  1   finger  0  "ouch".
View through magnifier after repair.:dancetl6:
OC.
Current builds
Completed works.
and everyone lived to fight another day
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Indeed  - felt like the whole site was on hold  over my magnifier episode  - so glad full service has resumed.
OC.
Current builds
Completed works.
woohoo-1298.gif.d2898f7ea033163417cbf733e670314d.gifyellow-smiley-salute.gif.877786ca8ce09d6ca58a76ac472ddd46.gif
Glad you got your dilemma cleared up, OC. I've used the toothpaste to clean up watch glass in the past. Our "family" always manages to come up with workable solutions. They're the best.👍
Ken
Started: MS Bounty Longboat,
37 minutes ago, CDW said:
It's one of those things that most guys our age can relate to...if I lost my magnifier, much of my small scale modeling would be over until I replaced them.
Very true - Im the same without my reading glasses  - completely blind.
OC.
Current builds
Completed works.
So so true each and every one are diamonds:cheers:
OC.
Current builds
Completed works.
A year ago, I bought a set of the sanding and polishing sticks from Flory Models in England. There are polishing sticks in that set that will buff out clear plastic beautifully. The come in various grades of coarseness, all the way down to the actual polishing grade. If you can see your way clear to acquire a set of them, they are well worth the money.
You mean for sanding plastic or even wood parts?    I use nail sanding files  - I have a mix of the flexible two sided ones and many that are thin with card in the center   - I have beautiful nails now 🤣
OC.
Current builds
Completed works.
OC.
These are more specifically suited for plastic. I use coarser grades of the "manicure" variety for my wooden models.
Flory designs his products for use around plastic models, but there may be other uses I have not discovered.
I have got a great new tool for shaping spars  - its a rounded scraping tool that slides in and locks (extended or retracted)   it will be great for shaping the tapers on my dowel spars.
OC.
Current builds
Completed works.
OC.
Don't keep us in suspenders...what is this spar shaping tool you've got? Inquiring minds want to know. 🙂
I could use a tool for spar shaping.
This one  -
OC.
Current builds
Completed works.
