HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
I am not commenting on the workmanship, it speaks for itself ...
However, something looks odd to me - I am sure it is according to the plans, namely that there is a screw-well in front of the rudder, while this seems to be twin-screwed vessel. Such a screw-well would cause a lot of turbulences and cross-flows in front the rudder. Is there any rationale, why this was designed that way ? One explanation, I could think of myself is that improves the turning capability - for the same reason tugs had cut large openings cut into the 'dead-wood' in front of the screw. Any thoughts on this ?
perhaps it's because the screws are closer to the hull.......blade radius.    the hull looks super.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Wefalk and Denis,
just a thought,
could be that the outer propcircles (diameters) were overlapping a  bit, like for instance the typical prop-arrangement for the KWdG, therefore the outcut window before the rudder heel. In that case there even had to be a staggered propshaft lengths, so that the circles did not foul each other within the "overlapping" area. It did not seem to be a handicap (Turbolences), because we know that the KWdG was the world fastest liner of around year 1900....
Here the scetch of prop arrangement...
Nils
note the different propshaft lengths, the prop circles are a bit overlapping within the centre window outcut area at the stern heel
Current builds
-Lightship Elbe 1
Completed
Hi Wefalk . Thanks for your rating.   And answer your question.
  This screw-well by Russian ship builders was called "a deadwood window".   At the beginning of the 20th century in the Russian fleet it was believed that this window improves turning effect of the ship.
  This window was made on many large warships. For example, on the battleship Retvizan, the cruiser Varyag, on five battleships of the Borodino type.
However, this window did not always help. On five battleships of the Borodino type with the steady turn of the ship  there was a big  snap roll.
Therefore, the windows were forced to close.
     No such effect was observed on Varyag.
Edited by Valeriy V
continuously neat work Valeriy,
top work !!
Nils
Current builds
-Lightship Elbe 1
Completed
Dear Valeriy,
It's with great interest that i have studied Your report. I would like to emphasize
an extremely high culture of production and outstanding mastery of construction technology, one can feel the a hand of The Master. I think that Your school in shipmodelling is a TOP aerobatics . I wish You luck and inspiration. I will follow with great interesting the constructionof this legendary ship.
My best regards Alexander .
11 hours ago, KORTES said:
Dear Valeriy,
Dear  Alexander , thank you very much!  I admit that I am very embarrassed by your high appreciation.
I hope that my further work on Varyag will not disappoint you.
With my admiration for your work on the  Boeir Yacht     Valeriy.
