On 11/1/2020 at 1:12 PM, KeithAug said:
Richard - pumps very nicely made, excellent machining of such small parts.
20 hours ago, jwvolz said:
Very, very nice Richard.
Thanks a lot Keith and Joe I've had a blast making all these parts made most as per the scaled drawings provided with the kit.
Regards
Richard
How are you doing Richard. I hope your distractions from model making are all pleasant ones?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
On 12/14/2020 at 12:22 PM, NovaStorm said:
Yes hope all is good with you and yours Richard. Have a great Christmas :)
Thanks for dropping by Keith and Robin have had a few distraction, remaking, but all is good and do hope you had a good as can be Christmas, in the next few days will catch up on all of your builds :)
Regards
Richard
I’ve been away from MSW for a few months and have recently returned.Your progress is a delight to behold and a serious inspiration. Your log has prompted me in a number of ways - I’m chewing through a number of machinist’s tomes and I can say, i have a tiny lathe now and have even soldered in the last few weeks. (Nothing to show for it on the modeling front yet - the current project is more about learning planking.)  In any case, thanks for sharing your beautiful work and happy New Year!
Hi Eric, bit late with the reply but thanks for looking in and your kind comment do apricate it.
So have done a little more to her but not so much in making but redoing, it started with the lower chain plates, which I had made from the brass strips .016" thick supplied with the kit found this out once I removed them, thought I had used some .010" brass sheet.
So now I remade them out of .005" solder small tube to the ends then made a jig to drill the mounting holes and now have the lower chain plates more to scale.
Then was not to happy with the black paint job so sanded that down and as per Robin letting me know that I had not painted the sides right I masked the hull up to include black up the sides of the main rail and Monkey rail, board and buffalo rail.
Put some semi gloss on
Next up was to remake the eye bolts for the deadeye strops which I had made from wire and did not look to good, tried by making out of thicker wire and then soldering a small tube to the ends, but this did not work to well when I went to bend them to go around deadeye 🤔
So decided to use .016" brass flat bar worked out where I needed the holes, drill them first then filed to shape then bent to shape, came out way better than my first try.
Casey blacked all parts and will use a small bolt and nut
Well not much to show these past few months have to figure what I am going to do with the scroll around the hawse holes then paint the cove, then the name plates.
Thanks again for all who have looked in and commenting on my on going build.
Regards
Richard
Great work Richard. Thanks for going into detail on how you accomplish your work. I like the clamp you used to hold the .016 flat bar for filing, something you made for yourself?
Previous build: NRG Half Hull
Previous build: MS Bluenose
Thanks Mark, Wally, Joe and Dave for your kind remarks and all for the likes.
Dave the clamp was not made by me, but by Eclipse N0 10, made in Sheffield England. got quite a few tools from my Gran who was a jeweller
Also have this hand clamp as well from her use both of these a lot
Regards
Richard
Edited by Retired guy
Richard, beautiful work with the chainplates .... and more.
Make me considering going back to the drawing (build) board and re-do mine.
Respectfully
Not sure why you started with a kit Richard. You seem to reject and remake most of the detailed stuff - excellent as usual.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
On 2/25/2021 at 7:58 PM, FriedClams said:
Nice to see you back with an update on your Bluenose Richard.  Great work on the chainplates, eyebolts and such.  Really like those clamps too.
Gary
Gary
Thanks Gary it was a small update but time consuming but I do like how they came out just way better than my first attempt, see right of picture
https://imagizer.imageshack.com/v2/1024x768q90/924/fjJShY.jpg
Yea the clamps work great for handling small stuff got many of her small tools which again use a lot
https://imagizer.imageshack.com/v2/1024x768q90/924/PL4lp1.jpg
Thanks Per as you see from the pic above the re-do was needed, you should try it, was a lot of fun but it was also a lot of filing
Hi Keith thanks for your kind comment, I have been told this before on other sites, and I am not quite sure why! did follow the instruction in the manual, used the supplied brass flat bar and then miss interpreted how the chain plate should look, and then I look at a lot of pictures, so it needed to get reworked will look like the picture now
Thanks again for all the comments and also for all the likes
Regards
Richard
Fine work as always, Richard. I just posted yesterday on my windlass and still have to fashion the bilge pumps. Then it's on to the chain plates. I'll be sure to check your previous posts as I proceed.
By the way, what type of solder are you using?
Dave
Dave
Thanks Dave the solder I use is this one
Regards
Richard
  • 11 months later...
Getting close to a year without a post 🤔 where does time go 🙄
A while ago I started making some parts inside the main cabin, used the information from LB Jensons book but they are not from the Bluenose, they are based on photographs of the Schooner Caroline Rose.
Just wondering if the inside would be painted white
Regards
Richard
Thanks for your comments Wally and Dave, these are the drawings from LB Jenson book the Bluenose 11 (these are to help with my build if not allowed please delete)
He shows a drawing of the Bluenose which I have used for stove and chimney and the other two show the inside of the Schooner Caroline Rose.
This is part of the Captain cabin
 https://imagizer.imageshack.com/v2/1024x768q90/924/YClH68.jpg
This is where I am now and will paint it white inside.
https://imagizer.imageshack.com/v2/1024x768q90/922/5t7AHq.jpg
https://imagizer.imageshack.com/v2/1024x768q90/922/ekzQVo.jpg
Will be adding some curtains where their beds go
Also got the cove painted and also the bowsprit painted and installed
https://imagizer.imageshack.com/v2/1024x768q90/922/JPAVrw.jpg
https://imagizer.imageshack.com/v2/1024x768q90/922/nzcGYk.jpg
https://imagizer.imageshack.com/v2/1024x768q90/922/MpwQQ4.jpg
Until next time
Regards
Richard
So good to see you posting again Richard, sometimes it's good to take a break.  Nice progress and such clean work on the cabin.  I especially like the curved wall and moldings.  Nice work area too!
Gary
Completed Scratch Builds
Gary
Thanks Gary was playing about with a 1/32 scale Lancaster changing the cockpit area but still doing small parts to the Bluenose.
Regards
Richard
I was wondering how I would do the scroll around the hawse pipe, I tried to carve the scroll but the kit supplied wood is no good for this so thought about  painting it but trying to make both the same 🤔
So came up with making the scroll from .018" brass rod, using a pattern from LB Jensons book, in the book it does say ( these were drawn free hand cutting in with a chisel and painting with gold leaf) and also says scrolls done in summer seemed to have more knobs than those done in winter, being in flower, so to speak.
This is the start of the two scrolls as you can see there were some very small parts to solder together.
One completed and then I filed it down
These are the tools I used.
Now got to finish the second one and then paint yellow same as cove.
Thanks again to all who comment and for all the likes do apricate.
Regards
Richard
Richard, those decorations are amazing.
I am going to try the same, thank you.
Respectfully
Wow, cool work on the scroll decorations.  I had something similar on the trail boards of my America build and the thought never even crossed my mind to try to make it out of brass rod as you did.  And nice work on the captain's cabin.  Looks like you have a nice large, comfortable work area.
