Very nice work Ben!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Thanks for all the likes and nice comments.
I’m making good progress on the QD beams and knees, all the way down to where I now have to start fitting the chain pumps in place.
The pumps were built as per the instructions without much issue along with the Capstans, columns, Main Jeer Bitts and Gallows.
Lets see how this final part of chapter 7 goes!
IMG_6870.thumb.jpeg.50e7f9700479826f081899a754815269.jpegIMG_6869.thumb.jpeg.a38573f4a5fad2f4621e62ff905226c0.jpegIMG_6868.thumb.jpeg.32c09edf3163090af8d556d6a8d735fe.jpeg
Completed Chapter 7 with the completion of the Chain pumps and their associated cranks.
I won’t install the elm tree pumps until much later as I’m bound to knock them off.
Just a little bit of sanding to do on the QD beams and knees to flatten them down for their margin planks and then to install the QD carlings.
20 hours ago, woodartist said:
Did you glue all your bulkheads onto keel before you removed the char?
Yes I certainly did, glue the bulkheads and maybe spacers between them all in place before going near it with sandpaper, you will do that when you "fair" them roughly before adding the gunport cills.
Edited by Trussben
Chapter 8 has begun by adjusting the positions of the Forward six FC deck beams as per the layout plan, they all needed to be moved forward to some degree.
Also both sets of the riding bitts were built and installed.
IMG_6900.thumb.jpeg.50737a7afa7dbd2e2cf5407cea5ec7b6.jpegIMG_6899.thumb.jpeg.5d632a4b94ec526f488736016557c835.jpeg
Look back at many logs, you’ll find fairing is one of the most challenging and crucial steps of your build. It defines all that comes after. In this case the char actually helps as a guide.
Regards,
Glenn
Current Build: Royal Barge, Medway Long Boat
Completed Builds: HMS Winchelsea HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
As beautiful and precise as ever. It's a real pleasure to see this work moving forward! Thanks for sharing.
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • HMS Winchelsea 1764 - Syren Ship Model - 1:48
Chapter 8 has been completed, just a little sanding of the deck beams and knees when I start planking to get a nice run.
I still haven’t added the cannons in the waist yet as want to keep them out of the way as long as possible so I don’t knock them loose with an errant elbow.
IMG_6910.thumb.jpeg.05388f743ee6ff3e96c11950132cc628.jpegIMG_6911.thumb.jpeg.ff92bd159c5172fa2d10c10b64e9130b.jpegIMG_6909.thumb.jpeg.518744b3efc73a2fe5e457a6cb1bafee.jpegIMG_6912.thumb.jpeg.c651e2e7270f0ed1f4bb5951dc068bbc.jpeg
Well done! Like you my elm tree pumps and waist cannon weren't installed until the end of Chapter 11.  Your wood selection and paint choices, not to mention the framing cutout, make yours unique with lots of visual appeal.
Regards,
Glenn
Chapter 9 is well under way with the QD and FC side plates to cover the last of the framing done, Caprails installed and the QD planking half completed.
There will be lots of paint touchups that will need to be done and small gaps filled when the planking is completed.
The center section isn’t hard, with all the tapering and fitting around hatches, nope not hard at all 🙂
Regards,
Glenn
Center planking on both QD and FC completed ( did not put the notches around the scuttles on the QD - prefer the look ) and I started the gangways, I want to finish most of the inboard details before I begin the railings to avoid damaging them.
IMG_7002.thumb.jpeg.1e42a957e4a255887ddb3236fe7de59a.jpegIMG_7004.thumb.jpeg.0ac4b4075106a74b1bbeeb3a13c451a4.jpegIMG_7001.thumb.jpeg.cde3b7ff081ea68b2ab78eb2a4a2cadd.jpegIMG_7006.thumb.jpeg.30af31e953dbd11963658f709eebc1d3.jpeg
Edited by Trussben
