Hi everyone, been building a 1/72 scratch Victory for quite a while now. keep going off the boil and back again (is this normal) and at the mo I`m building or trying. I picked the Victory at 1/72 simply for the fact that jokita do a fine example at that scale thus giving me a wealth of top notch parts to add to my scratch, cannons, photo etch, e.t.c.
      It will be made as simply as possible with no fancy interior although i am toying with the idea of full cannons on all decks but we will see
  • 5 weeks later...
Hello William,
You are off to a good start.
Will you be using filler blocks for the bow to support your planking?
PS - yes, it is normal to be 'off the boil and back again'.
It happens to us all once in a while.
Good luck with your build and enjoy.
Anja
Those we loved but lost are no longer where they were, but are always where we are.
In the gallery: Albatros 1840 - Constructo
Looks like a great start!  Did you find the laser level helped with the alignment?  Have been toying with the idea on my builds as well.
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Hello William,
Anja
hi Anja, no, didn`t use any filler blocks and already started the planking, although i curved the planks round the bow when fitting i noticed that they later tended to lose the curve and judder round the bow, oh well we live and learn,  cheers
hi Wayne, yes the laser was very helpful, with it being a scratch build, i cut the rib slots slightly wider than the false keel to give me some side to side movement, then with the keel plumb inserted the ribs keeping the centre line of the rib in the middle of the keel and then setting the line on the top strap to the laser, putting in a top strap with a centre line makes sure its bang on, also the top strap gives the ribs much more strength for fairing, planking e.t.c., when the time comes the top strap will be removed. cheers
Hi William,
Good luck with the build. What plans are you using?
hi David, all my plans are from the book The 100-gun ship Victory by John Mckay.  cheers
Nice work on the barge.   That's a sweet model unto itself.
Hi William,
That's very nice work on the barge. Waiting to see the ship progress!
As for your question about going on and off the boil, I can't answer for everyone, but it's almost 3 years since I began my build (which is nowhere near half-way yet) and I've had several "on and off" periods.
Jim.
I cut it twice . . . . . and it's still too short!
HMS Leopard 1790; scratch build 1:80 PoB
Cross Section - HMS Leopard 1790 - 1:44
  1. had a go at carving one of the small guys on the figurehead, quite pleased with myself even though it looks nothing like the real thing except for the stance, the right arm rests on the figurehead crown and will be carved to fit at that stage, (if I ever get there) !
Edited by williamDB
i am looking forward to more of the main build progress photo's, but lovely work on the barge and carvings
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Chip????   I must be going blind.  That shield looks fantastic.
  • 5 weeks later...
William that is some fine carving!
Michael
  • 8 months later...
can we have an update please
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thanks all for your kind coments, small update, finished the first planking of the hull, cut out all the gun ports inserted the linings and filled in all the gashy bits on the ports side, the quarter galley doors have had the linings inserted and left slightly proud so as to let the second planking butt up and then be sanded flush, all prep work finished on this side, started work on the starboard side but still lots of work to do ,cheers
  William
Edited by williamDB
