Hello Dali,
very ingenious manufacturing and a superb model. Thanks for your examples for me to follow.
With the hull almost completed, do you also  build the masting and rigging, or do you leave it as a hull only build?
When and how will you mount the hull on the final display stand?
best regards
cotrecerf
Hello Dali,
my question about the final placing of the hull on the final stand was pertaining to the handling of the hull with all it's delicate inner and outer details and their potential damaging whilst  mounting to the final display stand. I am pondering this question with my own model presently before I will condinue with all deck items, cannon mounting etc. in order to avoid any damaging.
best regards
cotrecerf
Hi Cotrecerf. Oh, now I understand your question. I was concerned about permanently attaching everything to the deck, but I did attach everything except the pumps. Now I will have to be careful with the rigging, but I don't think it will be too bad. The cannons had to be attached permanently, there was no exit, the winch (capstan) had to be permanently attached, because the bowsprit would be attached to the winch.
Greetings, Piotrek
Superb work, what mill do you have (and it is a rotary indexer Greg). I also love the weird 'helpers' that appear from time to time. Looks like they are now putting out requests... I would go for Echoes..... my fav PF track.
Andy
Thank you very much for your opinions and likes
Yes it is a swivel vise adapted to the Proxxon milling machine, very precise and useful thing. The photos show what my milling machine looks like.
Andy, Echoes is a great choice 🙂, my "helpers" and I send you my best regards.
Just wonderful work!!! Thanks for sharing the pictures.
Cheers,
Daniel
In dockyard: HM Colonial Schooner for Port Jackson (scratch), HM Armed Vessel Bounty, HM Cutter Sherbourne
Next builds: HMS Victor 1797 & Gannet 1814 Cruiser class sloops, ship and brig rigged (scratch)
Hello Dali,
once more: your work is fantastic!  What ready-made product or which chemicals do you use for blackening the metal parts, it seems to work well on solderered spots? Would you mind describing you process?
best regards
Joachim
Thank you for liking, thank you Joachim, thank you Daniel.
Hello Joachim, I use BRADIM Oxide for brass blackening. Oxidation does not black evenly, I try to keep the tin as little visible as possible and more from the inside.
Do czernienie mosiądzu używam Oksydę BRADIM . Oksyda nie czerni równomiernie, staram się żeby cyny było jak najmniej w miejscu widocznym a bardziej od wewnątrz.
Greetings, Piotrek
Edited by Dali
Absolutely fantastic!
Do you make your own ropes? And if so, what material do you use?
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • HMS Winchelsea 1764 - Syren Ship Model - 1:48
This is also my question. Your rigging is superb. I hope you can tell us some of the secrets. 👍
STAY SAFE
current builds:
Hello Piotrek,
I noticed that you have an LED light on your Proxxon mill.
Can you tell me where you get it? Is it with batterie?
Thanks!
BTW, excellent build! 👍👍👍
Hello. Joachim, please ask the question more precisely again, because the Google translator explains it so much that it is incomprehensible to me.
Jean-Paul, I do the ropes myself, I use ordinary sewing threads Talia 30 and Talia 120. The photo below.
Gary, Me and my crew, thank you. 🙂
Hsae, I bought the LED lamp on Ebay, it is nice, shapely, well made of good materials, powered by 230 V / 50 Hz and most importantly it fulfills its task. Below is a link to the store.
https://www.ebay.de/itm/164086042897?fbclid=IwAR35O5R0y9f0eCbQ19GbPhMmrcuiLGfoSXxG1rehb2L6xzvBX_uhtZYNQCQ
Thank you very much for your kind words and likes. Greetings, Piotrek.
