20 minutes ago, Canute said:
Good looking piece of kit, mate. La Haye Sainte will look great in that case.
Thanks Ken.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
@mtaylor  And others  I have just found this bit of writting about  Shako  Plumes   -  I Quote
The plumes were liked by Napoleon, in some early fight, he discovered that the tall color plumes magnified his soldiers' appearance and caused the enemy to fire too soon and too high. The soldiers like the plumes during parades and generally in peacetime.
In combat, however, they thought that the color plumes attracted far too much attention from enemy's artillery and skirmishers. It was also impossible to hide in tall crops and surprise the enemy with a sudden attack. The enemy saw your tall plumes before you saw him.
So you wasn't far off Mark.
OC.
Current builds
Completed works.
Evening all,   A bit more progress  this evening  -  I have painted the White cross belts and haversack belts  - any untidiness will be cleaned up with the Dark Blue in the Jacket.
OC.
Current builds
Completed works.
your powering right along OC.........the figures look super :)   nice looking case too.......what happened with the other gent?  did it come down to not being able to produce a case like that in glass,  or did he decline to go further?  I'm sure he lost some money having to post all those claims for damage.  anyway,  I'm glad you finally have a case to work with ;)   now you have a definite playing field to work with.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
The original maker of the glass case  came out to collect the second broken one  - he was going to repair it and bring it back out to us  - it was not fair on him doing that so I to him to call it quits  and keep the money I had paid in good faith to cover all his costs.
I found a larger  plastics (acrylics)  company  and did an online  request  got a quote  accepted  it  - it took about Three weeks to make  and  deliver.
Its been an expensive  endeavour  for a  display case  - deffo  a One Off.
OC.
Current builds
Completed works.
Evening all,   some more progress in my Three hour schedule  -  the vest are painted an  off White/Buff colour  and the trousers dull White.
Just to get an idea of the size of them  - they are ontop of Admiralty Paints  small tubs.
OC.
Edited by Old Collingwood
Current builds
Completed works.
OC, do they include a drummer boy? Just about everything I've read about French attacks, they beat out the "Pas de Charge" for the assaulting units. Don't know if you get that deep into units. Drummers may have been kept further back, outside the range of your dio..
Ken
Started: MS Bounty Longboat,
I have a couple in my stash  - I will have to find out if any where close to LHS  during the attacks  - I have not read anything  so far  about any drummers  being involved in the attack.
OC.
Current builds
Completed works.
There would have been some drummer boys, usually behind the Eagle and possibly on the flanks of the column.
There was that famous incident at Hougoument, when the French got into the courtyard, then the Guards Regiment (Coldstream I think) closed the gates and slaughtered all the French troops except the drummer boy😉
Edited by Edwardkenway
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Thanks Edward,    I might include one then.
OC.
Current builds
Completed works.
OC.
That's probably a good idea, OC.  Drummers were used not just to set the pace while marching but also to relay commands to the troops during battle as they usually could be heard over the din.   Commands such as "attack", "retreat", were pretty common up until WWI.
Thanks Mark,   I have been able to track down  the  painting details for them for each unit in the  54/55th  ligne regiment,  so I should be able to include  even just the one.
OC.
Current builds
Completed works.
Some news  (exciting I hope)   when I have finished these bunch  and now possibly the drummer boy  -  I will be  (wait for it)..........be starting on the  farm complex - base - scenery, I will have to rearrange the table  to create more room  as the base is quite large at 3 feet  by nearly 2 feet, and I still need room for my lamp.
OC.
Current builds
Completed works.
is that a majority of the armies completed now, they look great
lol dont forget all the spectators taking videos for the social media networks
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Hiya Kevin,   no mate  still a fair way to go yet  - I am about  a Third of the way  there  - I am hoping to make about  100-150  figures, it will be quite busy  in the space I have  - but that was how it was  back then.
OC.
Current builds
Completed works.
2 hours ago, Canute said:
OC, nice to read that. This will be a nice visualization of one corner of this sprawling battle.
Thanks Ken,   I am quite looking forward to  working with MDF  its all laser cut  but I will super detail it  as Its  a bit 2 dimensional, I will  be adding a floor in the farm house  - so I can put some of the figures firing from the  bedroom windows,  also with some of the brick detail (its flat  so I will try to show the mortar lines better)   I will probably work on  each section  while they are flat  before I  glue the sections together.
Then there will be the painting/weathering  to do.
OC.
Current builds
Completed works.
Evening folks,    getting closer to finishing  this group  - with Red being applied  - collar/cuffs/shoulder epaulettes, nearly done.
OC.
Current builds
Completed works.
4 minutes ago, Canute said:
An intimidating band of French Infantry there. That dio will be quite busy.
Thanks Ken, its amazing how long they take to make/paint  - roughly 6-8  a week.
OC.
Current builds
Completed works.
They are superb OC, and when they're in the dio, they will be the db's😊
Current builds;
Completed:
10 hours ago, CDW said:
Wow OC. Impressive work being done on your armies! Really coming along beautifully.
Quite a lot of work involved in detail painting a set like this. Hats off to you for all the time you're putting in to get it done. It's paying off.
Thank you so much for  those kind comments  and for looking in craig.
OC.
Current builds
Completed works.
Thank you  kindly Edward.
OC.
Current builds
Completed works.
Evening all,   still more progress this evening  - I  worked on the hands and Muskets, only took me another  3 Hours  to do the group, I wont put any pics on as they must be  quite repetitive   - will wait till all  of the Tirailleurs  are finished.
OC.
Current builds
Completed works.
Just catching up OC and I see you’re progressing nicely.  The figures are terrific as expected and that extra face shading really makes a difference.  At your level of detailed perfection, it does not surprise me that you can only complete 6-8 per week.
After all the problems with the glass case(s) it must feel good to finally be in possession of an undamaged display case.  I think switching to acrylic was a good choice and I look forward to watching the building of the structures and scenery.
Gary
Completed Scratch Builds
Gary
Thank you so much Gary for saying that  and for looking through my build  - it means a lot.
OC.
Current builds
Completed works.
So  my next stage  is to  do the staps White on the muskets  then  the Black gaitors and shoes  - then a bit of  dirt/dust on the bottom sections of the legs  (remember the ground was muddy from the previous nights  down poor)
OC.
Current builds
Completed works.
Evening all,   I gave in  - couldn't help it  so I have relented and taken some more pics of my progress  (I'm sure you don't mind)   -  I finished detailing the  muskets then I gave them including the hands a wash to bring out the shadows, after  I attacked the gaiters  (these were not going to be great  as the moulding  was actually just trousers so a while back I tried to scrape and file the lower area of the leg - below the knee  to show where the gaiter would hold the trouser bottom In)   I painted a few layers of Black to just below the knee  but left Two of them with there trousers intact (they had lost there gaiters in the battle).
I then used my lighter skin colour back on the  hands to highlight them mainly on some of the fingers palm of the hands and knuckles,  just the buttons and the cocade  on the shako  then It will be time to work on the backs containing the haversacks and coat tail details / ammo box  sabre etc.
OC.
Current builds
Completed works.
Hi all,  a bit more progress tonight  - I had painted the last of the details on the bodies inlcluding the Shako Cocade  Tri colour version, then the brass buttons on the  jacket and  cuffs,   then I started on the back packs  -  first thing I had to do was trim a small amount of the tails from the jacket bottoms as  they had the  shorter versions, then after a clean up  they were glued in place.
The first stage of the painting is the Grey coat  on the top of the back pack, then a small bit of Red  detail tooked away between the ammo box and the sabre,  more to follow.
OC.
Current builds
Completed works.
