That looks very good.  Like Mike mentioned,  be sure to check the run with the ship right side up.  Thats the most important part.
While you have it taped and lined so nicely, one thing that helped me was a red hash mark on the bulkheads signifying the butt shift pattern. Easy to lose track of them while planking.
Regards,
Glenn
Current Build: HM Flirt
Well laid out Frank!  Happy New Year to you too!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
21 hours ago, Chuck said:
Looking good....I would love to see pictures at this stage with the hull right side up.
Chuck
Thanks Chuck, Here some pictures of my beginner’s planking layout…It takes a very long time this way, but I just want to get it right…hopefully no anomalies anymore…I’m eager to start planking now after all this fiddling with fine tape and pencil…though I still have to find some plank joints and mark with a red cross… and tweak some tapes to an average in lining and spacing now that I look to these pictures.
Edited by FrankWouts
Current builds on MSW:
HMS Winchelsea 1:48
Prior builds on MSW:
None
That looks pretty darn awesome to my eye.   Well done.  You will never build another model without lining off the hull ever again.   That time spent will pay off in huge dividends.
Hi Frank, your planking prep looks really good.
Still, I'll add Chuck's advice:
Quote
Just watch the planking over the first three bulkheads as you work your way lower.  I see many people start to develop a dip there that will look like a dent in the hull in the lower two belys.  Try and correct this if you see this developing.  And absolutely turn the hull right side up to check this.....its the only way to really tell for sure.
(52 post on of my thread)
I still had to do some fine sanding at some bulkheads when planking.
So fingers crossed and I wish you all the best in this new year.
Dusan
Currently building:
HMS Portland 1770 by westwood - 1:48
HMS Winchelsea 1764 by westwood - 1:48
Revenge 1577 - by westwood - 1:64
In preparation:
Fourth-rate ship 1681 - 1:48
Very nicely done.   That is some fine looking planking.  Remember to flip the hull over every few strakes to check the run.  You will be able to tell more easily if your planking has started to form dips and you must adjust the run.   Especially at the bow and stern.
Frank, that looks so good! Well done! A fine example to follow.
Jim
Current Build: HMS Winchelsea, Model Shipways Mayflower
Completed Builds: NRG Half Hull Project
                                   Model Shipways 18th Century Armed Longboat
                                   Dumas 1954 Chris Craft 36' Commander
                                   Dumas 1940 Chris Craft 19' Barrel Back
Thanks Chuck, Glenn, James and Paul!
Yes, I flip the hull over now and then to check for strange looking curves and dips.
I’m beginning to feel key is that all curves bend fluently and following the lines set with the tape run not much can go wrong…but checking is better 😉💪🏻
HMS Winchelsea 1:48
None
