It’s time to make the gangway iron supports.
Between the various heights of the gun deck spirketing and the gangway
clamp each bracket will have to be to custom fit at their correct location.
Here is the first bracket being test fit.
All the pieces ready for soldering.
And the first one soldered.
Now I just have to clean it up and make seven more. :)
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Hi Rusty.
Nice work on the brackets.
I love the colours you have used on this cross section :)
And the quality of your work is outstanding.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Rusty,
good start with the brackets. My cross section and the plans don't always exactly agree, so I used a piece of timber across the deck resting on the gangway ledges to provide a guide for the underside of the gangway planking. This helped to get the correct angle for the brackets and eliminated the possibilty of them getting out of alignment.
Regards,
Grant.
Thanks Paddy and Antony.
Ben, I used a torch and regular solder.
Grant. Plans and build match? Never had that happen for me! I also used
a plank to check both the height and angle. I marked each bracket and each
location as they were all unique.
Here they are drying. Coat two of ?????? Not gonna be twenty though Ben. ;)
Rusty
Ok all the paint has been applied and gangway iron supports are being installed.
I've also placed the cannon and rigged them.
I'll finish the supports and make the walkway next.
Then it's ladders and a few other bits and pieces. B)
Rusty
Rusty:
The guns looks very good. I have only one concern. Did you double check the diameter of the breechings? It might be my imagination but they look a little large to me. It might be just the photo or something, but it might be worth checking.
The colors are great. I like the subdued tone of the red.
Russ
Hi Russ,
I used some .028” line I had for the breeching rope. It was the closest I had on hand.
Thanks on the colors. I’m real pleased with how they came out.
Hi Ben,
Have you still got that spy hidden in my shop? I started dusting the Echo off just last night! :D
Rusty
Hi Russ,
I wish I could take credit for great planning, but it looked ok and was what I had on hand.
Sometimes it just works out ok in the end.
I am using holly to make the gangways. I measured the length and glued them together
and then used a dremel drum sander to rough in the shape and sandpaper to finish it.
I used a little strange way to make the trim molding. It’s made out of pear. I cut the straight
top piece and then traced the shape for the two curves, cut it out and sanded it to shape. I
wasn’t having a lot of luck making individual pieces to fit the curve and for some reason a
whole piece was easier. Not the strangest thing I’ve done.
And here is the first one in place.
I'm getting there slow but sure.
Rusty
Thank you Paddy.
Hi Pete.
No bevel on the trim. The individual piece still has the pencil
lines on it and may give it a beveled look. :)
Rusty
Beautiful work Rusty.
Ron
Current Build: H.M.S. Triton Cross Section 1:48
Why is it that I always find out the best way to do something is after I have already done it the wrong way? - Me
Now that is Niiiiice Rusty! I like your technique for the pear trim, cutting it in one piece - very clever.
i love the gangways - very nice
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thank you Ron, Grant and Kevin.
Well the other gangway has been installed and the skid beams added.
Gotta make some ladders and the top rails then a case and I should be
wrapping her up by next weekend. Just in time for the hectic end of August
when I don’t have time for any modeling. :(
Rusty
Beautiful work, Rusty.   Good wood choices and clean, precise building.
Hi Rusty.
Wow looking real nice.
Are you going to enclose the model in a display case ?
Regards Antony.
Completed Mayflower
Thank you all for your very kind words. B)
Russ, I was pleased with the way the colors came out. I wasn’t really
certain how it would all look once completed.
Antony, As far as the case goes I’m going to semi cheat and get a premade
plexiglas box and just make the base for it to sit on. I thought about making
my own plexiglas box but I didn’t want to get into that yet.
Rusty
Well I’ve started to make the ladders. I transferred the lines from the
plans to the wood, cut the slots for the treads with the table saw and
then cut the side pieces to the angle dictated on the plans remembering
to make a mirror of each one cut out. :huh:
Hopefully I’ll assemble them today.
Rusty
Well I've installed the ladders and have started working on the case.
Here are the ladders,
The base is made out of oak. I used the full sized table saw to cut the recess for the plexi cover.
And here is the cover in place.
As I said before the cover was purchased on line as I did not feel comfortable making it on my own. (AKA Lazy) ;)
Gotta finish up the case, just a few fiddly things to do and clean her up and we should be done.
Rusty
Hello Rusty.
Very nice work on the ladders mate.
I also like the display cabinet. A simple design and easy to make :) 100% from me on that one.
Your work has been spot on throughout the build.
Well done. Regards Antony.
Completed Mayflower
