HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
Hi Ben, I use two x-acto knives. One with the tip broken off to get into the
corners, one sharp and one very small chisel.
Thanks Joe, Bob and Ron.
Mark, No sins? Obviously you haven’t spoken with the Admiral!
Thanks Sinan. Just wait you’ll see what I mean when you get there!
Well 32 down, 22 to go. That means there are 44 mortices to cut. It's getting
sad that I'm counting how many are left! :huh:
Last night I was finishing the last one, had a good tight fit, and pushed it out
and away it went high in the air, bounced on the end of the desk and landed
right in the trash bin. :o
Of course it was almost full with bits and pieces and lots of saw dust. I sat there
for a good five minutes trying to decide if I wanted to go dumpster diving or not.
I finally decided discretion is the best course and made a new one. :)
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Very nicely done... no gaps, clean, precise, sharp.  Hmmm... out of words.  Great job, Rusty!!
Very nice joints there Rusty - clearly practice does make perfect!
Thanks Pete, Paddy and Grant.
pics of the tools and how you do it would help me greatly if you can?
Hi Ben, OK here is how I do it and is by no means a tutorial on how to do it.
Just a way that works for me. :)
Here are the tools. The top is a U.J. Ramelson chisel. Next is the x-acto blade
with the tip broken off (usually I get this from the sharp blade as I break the tip
while using it :o ) and the bottom is a regular x-acto blade.
First I score the beam at the correct location
and then widen it to the proper width using the pointed x-acto.
Next I cut down each side
And then horizontally with the broken tipped x-acto down to the desired depth.
Then I use the chisel to clean it up.
And here is one roughly done. I fine tune them as I cut and fit each piece to them.
I hope this helps.
Rusty
Nice tip Rusty.I was wondering the best way to do thoses.  Thanks Larry
With Age Comes Wisdom,I'm Still Waiting!
Current Builds:Syren.Triton Cross section.
Completed Builds: Virginia by AL
                           King of the Mississippi by AL
                           Constellation by AL
Thanks for the pics and explanation Rusty - that makes it really clear.
Thank you very much for the pictures Rusty! Can you tell us the size of the ledges and the carlings? I am studing right now the plans of the decks and I can´t see these pieces around... at least in the plans I have for the complete model. I am using the book of the AOS series about the HMS Diana to figure out how to do the decks.
Thanks again. Good work.
Daniel.
p.s. now I can see a little gap on pic number... :)
Rusty
Thanks for the tutorial. I'm at the stage now of installing the carlings and ledges and this information is just what I needed as I have already glued the pillars and beams in place for the lower deck. I was just sitting back and doing a lot of thinking on how to cut them and then I saw your post and went  :dancetl6: Wow, just what I needed. Your work is wonderful and a delight to follow. Please keep posting little tutorials like this please. Thanks
Ron
Current Build: H.M.S. Triton Cross Section 1:48
Why is it that I always find out the best way to do something is after I have already done it the wrong way? - Me
Hi all and thank you for your kind words.
Hi Daniel I used the following sizes. Ledges 1/8” x 1/8” and carlings 3/16” x 3/16”.
Not sure if they are 100% accurate but they worked for me.
The way I used for cutting the mortises is what worked for me. Experiment and
see what works best for you. We all add our unique touch to how we do things.
Well here it is with all of the carlings and ledges in place. Now to sand it all smooth
then next up will be adding the waterways and decking.
Rusty
Rusty, another special thanks for showing us how you did your mortise and tendon work for it has me now looking forward to attempting the process using your approach when I arrive at that point. No longer dreading it. ;)
Thanks again. :)
1st Year Apprentice :mellow:
A new member of the NRG as of 8/28/13
Work in Progress -
 Triton 28 Gun Frigate Cross Section
Hi all. Thanks for the kind words. I hope it works for you as well as it did for me.
Here I’ve added the waterway and have started on the hatches. Both are being cut from red heart.
Here the sides are cut to length with the bevel cut into them.
Here they are notched for assembly.
And here it is assembled.
Are here they are set in place but not yet glued down.
Next I'm going to make my first attempt at making my own hatch gratings. :wacko:
Rusty
Rusty,
great work on the hatch coamings. Is the wood really as red as it seems, or were the pictures edited a little to bring the colour out? Looking forward to seeing your hatch grating.
Regards,
Grant.
Grand work on the hatch coamings. I really like the look of the Redheart you used and just checked a dealer I frequent and they have some in stock. I feel another purchase for the dockyard coming on. ;)
More beautiful joinery! :)
Work in Progress -
Thanks Russ, Joss, Grant and Pete.
Grant. You can see the difference between the earlier picture and the close up
of the completed one. The completed one is the color with a coat of wipe on poly
applied. No touch up. It’s that red.
Paddy. One thing they say is the Red Heart can fade some over time especially if
exposed to sunlight. This is some I have had on hand for a couple of years and it
hasn’t faded. Also I plan on keeping it out of direct sunlight once completed.
Daniel. Nope not Blood wood but Red Heart. Blood wood is a deeper darker red. I
have used it in the past but I didn’t have enough for this so I couldn’t use it now.
Again thank you all! :)
Rusty
Looking good Rusty, That red heart is a beautiful looking timber. As others have said the joints are an excellent fit.
Excellent work as always Rusty. I always looking at your beautiful work. I have been following your work for a few years now since we first meet and I enjoy every minute of it. Keep the pictures coming, I for one am always watching.
Wacko
Joe :D
Go MSW :) :)
