MIG 15 by Danstream - Trumpeter 1:48 - Finished
On 12/26/2021 at 5:26 AM, Danstream said:
I wrote that my post was the last one, but actually, I am still posting a WIP for the engine stand which I scratch built blending various configurations posted above by @Egilman. Clearly, the comparison with the workshop equipment built by Gary in its diorama is intimidating, at any rate that's mine:
The engine looks really good. We used to have parking bases which were just stands for spare engines that were simpler and cheaper than the workshop stands. It looks great too.
Alan
Link to comment
Share on other sites
@king derelict thanks for your clarification about the stand. I am glad that you find it adequately reproducing something realistic, I will pose it next to the aircraft.
Best regards,
Dan.
Completed non-ship builds : Spitfire MK I - 1:48Arado 196B - 1:32, Sea Fury - 1:48F-15C Eagle - 1:48Hawker Tempest Mk.V - 1:48F104S Starfighter - 1:48
Link to comment
Hi all, being domestic commitments for the festivities over, these are the really last pictures of the last missing bits. The engine was completed and put on its finished stand:
Clearly, there is no claim for accuracy, being the added wiring and tubing is just an over simplification and its purpose was just to convey the impression of the real thing.
Finally, the wire aerial, although it is barely visible in this picture:
Next, canopy and final pictures.
Thanks for following,
Dan.
Edited by Danstream
Link to comment
Mikoyan-Gurevich MIG 15 Bis
Red 40 - Nikolay Shkodin, 1953
(Trumpeter 1:48)
Hereinafter the pictures of my completed model of this Soviet fighter. The build presented few fitting issues, but at the end I am pleased with the result. I chose not to install the jet engine inside the rear fuselage and to display it next to the aircraft. I used aftermarket seatbelt, instrument panel and resin main wheels for increased detailing.
The Jet engine Klimov-vk1 is fairly reproduced for this scale and, as said, I display it on a scratch build static stand.
The model was finished with Tamiya acrylic colors mixes and Vallejo metallic for the metallic finished parts. I tried the camouflage bands by spraying them free-hand to obtain feathered demarcations. However, perhaps the effect that I obtained is a bit out of scale.
I obtained the 2 x 23 mm gun muzzles by aluminium tubes, while the muzzle of the 37 mm cannon is an Eduard replacement.
I modified the oversimplified pilot seat to better reproduce the type used at the time of this aircraft.
The panel lines were obtained by oil colors washes. Other small stains were made with watercolor pencils.
I found this aircraft rather interesting to build and I hope you like my final pictures. The complete build log is reported in the above pages. I would like to thanks all those that followed my long build and especially those that have provided comments and suggestions.
Best regards,
Dan
Edited by Danstream
Link to comment
Very nicely done Dan, I enjoyed following all of the way. Not too many model aircraft stables even have this plane in them for some reason.
I was able to watch a real one practicing for an airshow a few years ago. While not nearly as fast as the new stuff it was still pretty impressive. This was enhanced by the apparent need to kick in the afterburner for each evolution performed.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Excellent build Dan, I think the soft edges look perfect for a field applied camo... The colors just work as well....
Beautiful modeling job....
Well done...
Quote:
Link to comment
Nicely done, Dan. A significant development in early jets.
Ken
Started: MS Bounty Longboat,
Link to comment
Thank you for trying to find a positive side to it! 😉
Link to comment
Thanks to @ccoyle, @lmagna, @Egilman, @king derelict, @CDW, @GrandpaPhil, @Canute for your kind comments and thanks for all the 'likes'. Thinking of what could be next.
Cheers,
Dan.
Link to comment
Very nicely done Dan  -  it just so looks the part  - weldone.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
I think you've built an outstanding model Dan.....the camo looks great just the way it is!    very nice job on the engine as well.......it's very seldom you see a display pairing like this.  then again,  there aren't too many kits that have the engine,  unless they are large scale kits.  Soviet or Japanese planes are not commonly modeled....I've not done any.   first class model my friend :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
@Old Collingwood, thanks for your note, I know little about Soviet planes (I did some readings within the frame of this build) but as you said, it looks the part sufficiently also in my view.
@popeye the sailor, thank you Denis very much for your super kind words, happy that you find the camo style appropriate!
Kind regards,
Dan
Link to comment
Excellent job Dan, it looks great, I like the idea of the engine not fitted, otherwise the detail of it would be unseen😉
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Congratulations Dan on a fine model.  Beautiful work on the color rendering - I particularly like the underside oil washing.  Very nice.
Gary
Completed Scratch Builds
Link to comment
Thank you for your words. Actually, the engine lacks some important details, but it was fun to work with and it gave me the opportunity to try some new things with the metallic acrylic.
Thanks Gary, I am glad you like the result. The underside turned out OK thanks to the oil washing and also to the marbling pre-shading, It was nice to try these techniques that make uniform surfaces more interesting.
Greetings to all, to the next build,
Dan
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
