Pz.Kpfw 1 Aust F Early by King Derelict - Flyhawk 1/72
looking really good Alan........the detail on these small models is amazing :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Share on other sites
15 hours ago, Backer said:
Nice work Alan.
If the sprocket teeth dont fit. I usually cheat 😇 and cut some of them off.
Mostly on older models with rubber tracks as on this Airfix Centurion sprockets (link to buildlog in signature)
Thanks Patrick.
I shaved a couple of the teeth and there was then enough room in the track links to accommodate the misalignment. I need to get in the habit of checking stuff like this before reaching for the glue.
Alan
Link to comment
14 hours ago, Egilman said:
I've cut off sprocket teeth as well, but I hit on an easier solution, I cut off the alignment tabs or square locators and align them with a pair of machinists angles so the blade is vertical... putting a sprocket tooth against the square blade on each side of the sprocket forces the correct alignment and using two on opposite sides forces the two halves to be concentric...
It's a bit more work, but eliminates sprocket alignment issues in all cases without cutting off teeth......
You guys do beautiful work.....
Thanks Egilman
I should have checked the dry fit and registered teh misalignment before gluing. Your solution would have then been an elegant fix. As it was I stumbled through it. I do need to learn that the kit manufacturer isn't always delivering a perfect kit. Flyhawk is so good generally that I get lulled into a false sense of security.
Alan
Link to comment
Thank you for the kind comment Popeye. This is a great kit and I have enjoyed it a lot. Flyhawk put a lot of detail into a tiny tank.
Alan
Link to comment
The major task of the day was to complete the tracks by using the single links to bridge round the drive sprocket and the rear wheel. The detail of the single tracks is very impressive and they assemble very nicely on a flat surface. Unfortunately I found them very difficult to build up around the curvature of the wheel. The sprocket wasn't so bad because the teeth held the link in place and ensured the spacing. The rear wheel was more difficult ; the links didn't seem to like the radius and wouldn't lay up next to each other. I tried assembly a section on the bench and folding it around the wheel while the glue was soft but it still fell apart once the radius was tightened. Eventually I laid one link at a time and let the glue set before adding the next and got a reasonable result. It certainly looks better than the Airfix Churchill I built about 55 years ago. It had the elasticated tracks that you were supposed to fuse together with a hot knife blade.
The track guards were installed and the details added. I put the turret in place - its a lot safer there; with the PE grab handles there are very few places that you can hold the turret. I put a couple of very thin black washes on to bring out the wheel details and panel lines. Next is the weathering. From Patricks notes this was mainly a training asset and I can't imagine any Prussian training establishment allowing their equipment to get too squalid.
I do want to try the Mig Oilbrushers and see what i can do though.
Thanks for looking
Alan
Link to comment
Look at the detail on that  - superb.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Looks great from here, Alan.  I hope the weathering goes well.
Link to comment
Today I painted the last details, the shovel and the axe and touched up a few areas that needed attention. Then the weathering!
I used the Steel paint from the Bare Metal Oilbrusher set I used very small amounts where I thought there might be significant wear. and then washed it to thin the effect.
I used the AV Vallejo Rust, Stain and Streaking set for rust. I kept it to limited areas, mostly the corners of the track guards that might have got beaten up in training. I used the darker colours to get a deep, paint chipping effect and surrounded it with the light rust colour which I washed out with a wet brush. I added a light rust wash to the wheel centres and also brushed a small amount over the bare steel effects which produced a result that I like.
I'm not sure if the decal on the hatches was necessary, the information is limited
I think this is finished. I hope you like it.
Thanks for looking and responding351854681_RIMG0145(1280x720).jpg.ee2096450d2d3e78dfe52fe7b28be17a.jpg
Alan
Link to comment
Now that does look nice  - just about perfect weathering  - you should be pleased with that mate.
OC.
Current builds
Completed works.
Link to comment
OC.
Thank you OC. I feel I didn't overdo it this time and I like the result. There is a lot to learn there.
Alan
Link to comment
A very nice model. Congrats 👍.
Regards, Patrick
Finished :  Soleil Royal Heller 1/100   Wasa Billing Boats   Bounty Revell 1/110 plastic (semi scratch)   Pelican / Golden Hind  1/45 scratch
Current build :  Mary Rose 1/50 scratch
Gallery Revell Bounty  Pelican/Golden hind 1/45 scratch
To do Prins Willem Corel, Le Tonnant Corel, Yacht d'Oro Corel, Thermopylae Sergal
Shore leave,  non ship models build logs :
ADGZ M35 funkwagen 1/72    Einhets Pkw. Kfz.2 and 4 1/72   Autoblinda AB40 1/72   122mm A-19 & 152mm ML-20 & 12.8cm Pak.44 {K8 1/2} 1/72   10.5cm Howitzer 16 on Mark. VI(e)  Centurion Mk.1 conversion   M29 Weasel 1/72     SAM6 1/72    T26 Finland  T26 TN 1/72  Autoprotetto S37 1/72     Opel Blitz buses 1/72  Boxer and MAN trucks 1/72   Hetzer38(t) Starr 1/72
Si vis pacem, para bellum
Link to comment
Amazing detail for a model so small, very well done....
Quote:
Link to comment
Very nice work Alan
I know next to nothing about German tanks. All these years all I thought of was Panzers and Tigers, and here on the forum, thanks to builds like this, I am learning that they had a seemingly endless line of armored vehicles I knew nothing about.
I enjoyed following your build, thanks for sharing.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
2 hours ago, lmagna said:
Very nice work Alan
Thank you for the kind comments Lou. I'm learning about the Armour world too. I hadn't realized that there were these small, two man infantry tanks armed with machine guns. I have a couple of Renault tanks that look about the same size and the Panzer II which I think is a similar size too. I am thinking of building a Tiger or similar large battle tank to provide a comparison
Its great to see the expanding range of AFVs having really only been aware of Shermans, Panthers and Tigers, T-34s and Churchills. After reading Colin Forbes Tramp in Armour" I would like to try a Matilda at some point.
Thanks Again
Alan
Link to comment
Whatever you choose I will be looking in. They may be small but you make them interesting.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
Thanks Lou; I think the Renault will be next up. It looks like I won't be subjected to individual track links this time. I need to read up a bit more as the Renault 17 spans a period 1917 - 1945 or possibly later with a wide range of operators from France through the US to Brazil
Alan
Link to comment
If you need info about the ft17. Just ask.
The ft17 has many possibilities.
Regards, Patrick
Link to comment
Patrick
Yes please. The Flyhawk kit is quite comprehensive; it builds two complete vehicles in any of six configurations. A paint scheme is provided for all six but nowhere in the instructions have I found a clue to the six configurations or the operators of each paint scheme. The first one has a marking "Le Tigre" so maybe that is a French one. I quite like the white  / brown camouflage but have no idea who might be behind
Ïnfantaria" marking. If you are able to shed any light on any of these paint schemes it would help enormously.
Many Thanks for your help and Interest.
Alan
Edited by king derelict
Forgot to add image, Sorry
Link to comment
A first impression
I  France WW1 western front (Le Tigre : the tiger)
II France WW1 western front
III France WW1 western front
IV Spain post WW1 in Spanish Morocco
V France WW2 (1940) (Le champagne) in French Morocco
VI France  WW2 (1940) home land
If you build the WW2 MG version, this should have a more modern MG
Edited by Backer
Regards, Patrick
Link to comment
This is an American marked tank..... It doesn't have the playing card flash on the tail panels, The French were the only ones to put it there...
The colors and camo pattern is French as they came from the factory painted that way...
GS Patton jr in 1918 (he commanded the field portion of the Tank Corps in France) set up the marking scheme for US tanks....
This below is part of the order he circulated....
Tanks:
In addition to its registration number, any battle tank carries two brands which one can distinguish the Battalion Group
or the Group or the Company or the tank and in the Group or the Company, battery or section of tank. The brand of the Group or Company is formed by a cartridge as defined below:
Group 1 or 1st Company - circle 25 cm in diameter.
Group 2 or 2nd Company - square 25 cm in diameter.
Group 3 or 3rd Company - Triangle 25 cm in diameter.
Group 4 or 4th Company - Diamond 25 cm in diameter.
The cartridges are painted in white on each side of the tank in half of the upper rear panel.
The brand of battery or Section consists of an Ace inscribed in a circle of 15 cm, painted black in the center of the cartridge after the rule below:
Battery 1 or Section 1 - Ace of Spades
Battery 2 or Section 2 - Ace of Hearts
Battery 3 or Section 3 - Ace of Diamonds
Reserve (Section d’echelon) - Ace of Clubs
French Renault FT units were organised in : Régiment - Bataillon - Compagnie - Section
In addition, they would paint a small number next to the designation marking signifying which tank in the section it was....
So Tank #II in the sheet of schemes above is marked for the 426th tank battalion, 4th company, 3rd section, Tank #1.....
Not all American tanks were marked like this but the ones in Patton's command were...
Quote:
Link to comment
I would have thought the IV paint was the winter one.
Link to comment
6 hours ago, Backer said:
A first impression
Thanks Patrick
That is hugely helpful. I had been thinking Spain for #4 but the paint scheme doesn't look very desert but I suppose Spanish Morocco was also the coast and some of the Rif mountains as well as Western Sahara, I still like the paint scheme so this will be one of teh two builds.
Thanks again Patrick
Alan
Link to comment
Tanks:
Many Thanks Egilman. That is some very detailed research and I value it a lot. I learned a lot as well now having an identity for the tank. Its a great help
Thanks again
Alan
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
