Greetings All,
Today I have some more detail work photos to share. The funnel and ventilators were made from aluminum tubing. The funnel was pinched slightly to form the final shape, then the top edge rounded off by pressing a drill bit at 45 degree angle and moving it around the circumference. The ventilator flares were made similarly, then bent to 90 degrees near the top.
The yards, booms and gaffs were all made from glued up layers of maple veneer. Interesting to note that the topsail  is not attached to the yard, as the other square sails are. Close inspection of the Hurley photos shows that the topsail was actually attached to a second spar, mounted beneath the yard itself. I have never seen this arrangement previously, or since. From photos it would appear that the spar is actually a roller, and the sail is rolled up onto this spar much like a window shade arrangement. I do not think there was a spring inside the spar, as in a shade, but instead when the sail is rolled onto the spar a lines are attached at each end. Thus, when the sheets are hauled to lower the sail, the lines attached to the spar roll up onto the spar. So, when furling the sail the two "reef lines", as I call them, are hauled to cause the spar to rotate and the sail to get wound around the spar. There is an arrangement of a metal device, not clear enough to get exact details in the photos, which appears to extend forward from the yard and spar, an arm of sort through which the reef line runs. This arrangement would replace the normal clew and bunt, leech lines for the topsail. I wonder if it worked properly, or as intended, since I have never seen it replicated.
Lastly I have a photo of the light bulb the model will be installed in, along with another of the inside of the cap for the bulb.
Anchor's A Weigh!
John Fox III
We took a cruise aboard "Royal Clipper" just before Covid.  Her yards are hollow, and the sails roll up like window blinds on cylinders inside the yards. Rotation is provided by a hydraulic winch at the port end of each yard. Two crewmen on deck tend the sheets as each sail is rolled or unrolled. Six crew, all on deck, can make or stow all sail in I would think less than forty minutes. A very modern take on the windjammer.
John, I've followed you on bottleshipbuilder, glad to see you posting your amazing work here!  I have to say, your hidden hinge technique is very clever - better than the staple hinge you typically see.  Gives me a lot to think about when doing my build.  Thank you for posting such clear pictures of how you did it!
Greetings Ian,
I never actually looked for anything similar quite that modern. Makes sense though, the technology certainly is up to it now days.
Anchor's A Weigh!
John Fox III
Greetings Mike,
Thanks for the kudos! Hope it does inspire some thinking and experimenting, that's what all my posts are there for! The hidden hinge is certainly not my original idea, don't know if anyone knows for sure who did think the idea up. I know that for many years it was known as the "Hinkly Hinge", due to the fact that a popular ship in bottle builder with that name used it and wrote about it. I just refined it a bit, by using the multiple veneer layers to make the cutting and carving easier that attempting to make the parts by whittling away at a solid wood dowel.
Anchor's A Weigh!
John Fox III
Greetings All,
Today I have some more details added to my Endurance model. The observation barrel, made by wrapping paper around a suitably sized brass tube, then sanding and sealing with CA glue. Funnel and ventilators painted and skylight/bench made from wood and thread. A few over view shots of details in place, including wheel and stern railing. Bow area has catheads and ladders, also rails made from wire pins and thread. The rest of the railings were made the same way. Also added the boat davits, made from wire. Lastly the binnacle, smoke stack and capstan. Smoke stack is painted aluminum tube, with thread holding up the top. The binnacle and capstan were my first attempts at using casting and molding, using a kit from MicroMark. Hadn't mentioned before, but the prop was made from brass.
Anchor's A Weigh!
John Fox III
7 hours ago, BANYAN said:
Some very nice detail for the scale you are working at John.
cheers
Pat
Greetings Pat,
Thanks! I really enjoy working out to super detail, and then seeing if I can do it!
Anchor's A Weigh!
John Fox III
Greetings All,
Today I have some more detail photos, plus an overall view of my Endurance model. The last shot is of the standing rigging. All the forestays are "control" rigging lines, i.e. the lines that are pulled from outside the light bulb to raise the masts. These lines exit the hull into the space carved beneath the upper hull.
Anchor's A Weigh!
John Fox III
Greetings All,
Today I have a few photos to share. Adding sails and the name tag on the stern. Name tag was printed on a cigarette paper, after printing on standard paper then taping with cellophane tape the cigarette paper right on top of it. It was then sealed with thinned varnish, installed with white glue, and a light coat of thinned varnish on top. The sails are printed on thinner printer paper, identical on both sides.
The last photo shows all the control rigging lines exiting beneath the upper hull.
Anchor's A Weigh!
John Fox III
1 hour ago, Roger Pellett said:
John:
Is the lightbulb an actual lightbulb or something specially made?
Greetings Roger,
Yes, it's a sodium vapor street light bulb. I had a friend who changed them for the city, and got a dozen or so used ones. Opening the bulbs is a bit tricky as the glass is relatively thin. I wrap fine fiberglass cloth around the portion of the "neck" that I wish to cut through, then saturate it with epoxy glue. When fully cured I use a Dremel and thin abrasive cut-off wheel to carefully cut through the glass.
Anchor's A Weigh!
John Fox III
 John, amazing work.  How do you make your deadeyes?
Brilliant work, John!  Love the creativity for the mast hinges and the laminate spars.  I just finished up a much cruder version of the Aurora in a bottle.  The Antarctic exploration vessels from the heroic age are fascinating ships with incredible stories!
Edited by Glen McGuire
John, Absolutely fantastic as always. Glad to see you posting your work here. Seems I lost contact with you over the years.
Al
Al
Current Build
The President by Sergal
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
SIB Pride of Baltimore II
On Deck
Greetings Keith,
Will attach a few photos of how it's done. Wish I had some better ones, but will look around to see if I do. Basically, circular punches are made, shown, in an appropriate dia.. Circles are punched out of stained card stock, or construction paper of the right color, and these are placed on top of threads on a jig, then glued with CA glue. The jig was made from sections of a 71 dpi. razor saw blade, and screwed to a hardwood block. A piece of paper with deadeye spacing lines is slid beneath the threads. The threads were saturated with CA glue before adding the circles. A second layer of threads is rigged in the same tooth gaps, so they are directly over the threads beneath the circles, then glue applied again. The deadeye pairs are then cut from the jig, then trimmed to the outside edges of the deadeyes. If they are large enough, saturated thread pieces can be added between the ones already on the deadeyes, They are surprisingly strong, though it took a while to figure out exactly how much glue to use to make them. I can pull the shrouds quite tightly without them separating, at least most of the time.
426819028_BHRbulb553.jpg.3a62868dae65caed828cd40e3f8eb37c.jpg778298284_BHRbulb616.jpg.a540e61cc8fbea289f66a8e0cac4eb07.jpg
Anchor's A Weigh!
John Fox III
Greetings Glen,
Thanks! Part of the reason for the creativity for those parts is having to make many of them. I often built 2 or 3 models when I was building them for sales, so always tried to find ways to make things better/easier. I love the ships/boats of that era, I did a static display model of Amundson's Gjoa a few years back too.
Anchor's A Weigh!
John Fox III
Al
Greetings Al,
Thanks! Not sure about the "always", but I do try! <Grin> Been lurking around here nearly as long as you have, but been posting a bit more lately.
Anchor's A Weigh!
John Fox III
Greetings All,
First off, thanks for all the "likes" and "wows"! This is the last of the Endurance log. First off I have a photo of the light bulb ready to use on it's stand. Then I have the lower hull part inserted and glued in place. Finally the model with all the control lines tightened and ready to glue. Next two show the special holder I made to keep the lines straight, and with openings allowing me to put CA glue right on the exit points of the control lines. Next I have the upper hull ready to glue to the lower hull, there are pegs to align it. That is probably the trickiest part of the finishing of the model, need to rest the upper hull at an angle, with the pegs near the holes, and then apply white glue to the holes and push the upper hull down. Lastly I have the completely finished model.
Anchor's A Weigh!
John Fox III
An amazing little model, crisp, clean work at 1:275 scale. Sticking it in a bottle (light bulb in this case) is the wow factor. Congratulations.
Love it.  A beautiful build and a unique display.
What a beauty!  Very nicely presented and a well constructed Model John.  You should be proud of this one.
cheers
Pat
Greetings Keith,
Thanks for the kind words! I like making people's eyes pop out! <Grin>
Anchor's A Weigh!
John Fox III
Greetings Mark,
Thanks! Glad the model pleases you! Those large light bulbs offer so many possibilities for models.
Anchor's A Weigh!
John Fox III
11 hours ago, Glen McGuire said:
Superb work, John!  Congratulations on a job very well done!
Greetings Glen,
Thanks! There's a certain level of satisfaction that is hard to beat when I get one right.
Anchor's A Weigh!
John Fox III
