Now here is the progression on the shading I did not go black base on this typical Mr Surfacer 1200 was the laid and MM Africa 1942 Sand then the upper panel lines were done in MM Italian Sand.I then started inside of the panels with the Italian Sand(darkest) next came Yellow Zinc Chromate and on to white.I then came back over that with the 1942 slowly building it up I was still not happy with it pic2 so I laid down more #3.I started on the bottom with a med Grey for the panel lines and ever so lightly in a few panel started with the 1942 and went back over with RLM 78 you will notice in #4 R/wing has the dust and the L/wing needs more toning down.The toning down and dust came in #7 I like the effect.I then made a color of a lot of white 70% and 30%1942 almost pink I misted the wings up top and the spine of the fuselage a dust effect sun fade #5 did all the white also.I have the clear on it now and will do some more tomorrow before work and let dry good then decals and pastels :D
Edited by Javlin
2 hours ago, Canute said:
Shaping up nicely, Javlin. 👍
Thks Ken the build has had it's learning curves in weathering for me liking it thus far.;)
1 hour ago, ccoyle said:
I really like the color schemes used by all of the combatants in North Africa. I have Hans-Joachim Marseille's Bf-109F-4 and a USAAF Spitfire Vb tropical in my card model stash.
I don't know what it is about the Africa Campaign but it does interest me alot these days Chris,Marseille's crate is in the stash also.;)
1 hour ago, king derelict said:
Looks very impressive. Coming on well
Alan
Thks Alan this one is a teacher we wait and see if the student can take it forward.;)
Last coat of clear hit the plane this morning already decals soon.:D
Edited by Javlin
I like your rendering of the Africa camouflage. The result is very convincing.
Waiting to see more,
cheers,
Dan
Decals have been applied I know we like thin but man some of these were just to thin I lost several.I have several mistakes in the paint all on the undersides 1) the white under the wings went one panel to far inboard.2) the white band on the tail is 1/16" to wide hint the "A" hit the white centering the "Z" and 3) the RLM 78 was to go much lower between the wing and tailplanes live and learn.I think when done 9 out of 10 people will never notice those mistakes so I march on.I made up the colors for the props,bombs and prop covers.;)
If you hadn't said anything, I doubt we would have noticed the paint issues.
superb look'in bomber Jav.....great paint! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I busted out a box of pastels using a light white grey and an even lighter sand mixed started some blending.I had the airbrush set up with some flat I coat spray coat till I was happy....I think I am happy with the wings and the L/Tailplane.The build is starting to come together just longer than most for me at least it's getting artistic ATTM.;)
So nice😃
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
I see a great paintwork nicely finished by the decals. The transparencies also turned out very sharp. This will be a terrific model.
Dan
19 minutes ago, CDW said:
Your glass work looks remarkable in these photos.
Thks Craig I just about had a small flub when reglueing the top piece some glue oozed out made it a little glossy when to go hit with a brush/flat clear will .... the brush must on been dingy:default_wallbash: So out came the Africa 1942 color had pastels at the ready a light touch of paint and before it could even think about drying on went the pastels it's working called it quits for the night.;)
