The Shipyard at Foss' Landing (Diorama) by gjdale (Grant) - FINISHED - SierraWest - Scale 1:87 (HO)
Looking very nice, well done 👍
One thing that puzzles me, however, is the orientation of the saw-blade versus the rollers. I would have expected that the rollers feed (planks) into the saw-blade ...
And a little technical detail: the ends of leather drive-belts were attached with special metal 'agraffes' and they don't overlap. If they did overlap there is a jump and slip on the pulleys.
Sorry to say, but I am bit disappointed over technological progress - a boring electric motor and not a little horizontal steam-engine, the boiler of which is fed with saw-dust and off-cuts  ;)
Cross cut or rip saw, it's looking fantastic!
Very good detail at such a small scale😉
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Nicely done with the saw table and power hookup.. These facilities were fairly intricate, despite being located in out of the way places. This build is turning out superbly. 👍
Ken
Started: MS Bounty Longboat,
Thanks again for all the kind comments and likes folks.
The Saw Shed (Continued)
Back to the roofing. We start by constructing the cupola. This is done in exactly the same way as the cupola for the main roof, with carboard substrate/template, prepared timber siding, and the addition of windows with a peeling paint effect. Here are the four sides ready to be glued up.
Next, some purlins are added to the roof to support the roofing sheets.
The roofing sheets received some preliminary preparation with ferric chloride in an earlier post. It was now time to “rust” them up. The instructions were a little vague on this point, “apply some rusty coloured chalk powder”. Perhaps there is an assumption that by this stage we are capable of making our own decisions about how to apply this. Fair enough. I chose three colours to create my version of rust: Rembrandt 235.5 (Orange), 370.5 (Permanent Light Red), and 343.5 (Caput Mortem Red).
My method was as follows:
-       tip a generous pile of each of the three colours, well separated from each other, onto my glass work plate
-       dip a brush into isopropyl alcohol then remove most of the alcohol on a paper towel
-       dip the tip of the brush into the darker colour (343.5) and “blot” onto the roofing sheet.
-       while the sheet is still damp, using a DRY brush, blot generous amounts of both the other colours, then shake/tap/lightly brush off the excess.
I’ve no idea whether this method is considered “correct”, but it seemed to work for me. Here are the sheets ready for installation.
The cupola receives its roof first. After installing a couple of support boards between the rafters, the cupola is then fitted. After this picture was taken, I realised I’d done the ridge capping incorrectly and re-did this.
I then proceeded to attach the roofing sheets to the roof. Again, the instructions were a little scant on this, inviting us to simply glue them on. I wasn’t sure what sort of glue to use for this. As I had successfully used PVA to attach the little cupola roof, that’s what I went with.  Big mistake. I had all sorts of problems trying to hold pieces in place while the glue set up but pushed ahead regardless. When I finally got all the main pieces on, I went to install the ridge capping and found that PVA just wasn’t going to cut it. So, I went with epoxy for these pieces. Then I went to take some photos to upload to the build log and that’s when the camera made it very obvious that this roofing job was just not up to par.
I though on this overnight and decided that a re-work was in order. A day spent on a re-do is nothing compared to forever looking at a botched job! The main issue was how to deconstruct the roofing without destroying the rest of the building. As I’d used epoxy on the ridge capping, I needed to use acetone to de-bond those pieces. That went quite quickly, and they came off without too much trouble at all. To de-bond the main roofing sheets, I used isopropyl alcohol, being as careful as I could not to inadvertently de-bond any major structural components. In the end, it was only the purlins that came away with the roofing sheets. Oh, and the cupola kinda fell apart too. The only real downside was that although I’d successfully removed the roof sheeting, the process also took off most of the rust colouring, so I had to re-do that (using the same process described earlier). Unfortunately, I didn’t take any photos during the deconstruction phase.
Having re-built the cupola and re-coloured all my roofing sheets, I decided to try a different approach to gluing and broke out the CA gel. I don’t normally like to use CA glue in any form as I have a sensitivity to it and develop flu-like symptoms at the slightest exposure. But, there was not readily apparent alternative, so I put on my big boy pants and got on with it. This time the whole process went quickly and easily and before I knew it, I had the roof back on. The final job was to put some “flashing” around the base of the cupola. The instructions say to use epoxy coloured with some paint as we’ve used earlier on, but I find this a little messy to apply. So, taking a tip from another build log, I decided to use some PVA coloured with a little paint and applied using a syringe. That seemed to work quite well and once dry I “painted” some black and grey chalk powder with a little alcohol to dull down the shine and leave a nice dark grey flashing.
Here are some pictures of the completed shed.
The next task will be to start work on the diorama base – another “totally new to me” excursion…
That is  looking Fantastic.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Coming along nicely, Grant. It does look like a weather beaten old building, shed, etc.
Jack
Current buildUS Constellation
The brutal honesty of the close-up camera is always discouraging, but in the end, I think it makes us better modelers.  Wonderful work Grant!  Such a fun project.
Gary
Completed Scratch Builds
I'm loving the uncared for looking roof! Really good work.
Current builds;
Completed:
Very nice job on rusting the roof. The saw shed looks great.
A mini primer on stages of rust. Your rust pigments are spot on. The lightest is the most "fresh" rust, say bare metal a few days after a rain. The rust darkens over time through the middle shade and old rusty items get the dark reddish shade you used. If you have any railway lines near you, look at the unused and lightly used rail heads for the beginning stages of rust. All the rails are darkly rusted on the web of the rail. That's the part supporting the rail head.
Ken
It's been a while since the last update, but that doesn't mean that I've been idle. Quite a few pics for this update, so I'll spread them over three posts.
The Diorama Base
Our attention now turns (temporarily) to the preparation of the diorama base. This starts with a base board of ¾” thick MDF cut to a size of 18” x 17 ½”. The instructions call then for two layers of ½” thick Styrofoam house insulation for a total thickness of 1”. I could only find 30mm thick stuff locally, so went with that instead. This is cut to a basic outline (shown with various measurements in the instruction manual) and glued to the MDF substrate. The instructions suggest using hot glue for this – I went with Elmers Glue-All (looks like a type of PVA) instead and this worked just fine.
I couldn’t resist checking out the basic “fit” of the various structures at this stage.
As the top surface of the main dock must be level with the top surface of the main building foundation, I made up a measuring stick to determine the height of some temporary pilings for the dock, taking into account the thickness of the dock main supports.
A few of these temporary pilings were then spot-glued to the underside of the dock.
The foundation epoxied in place, following exact placement dimensions from the instruction manual, and the dock test fitted to check alignment of the top surfaces.
Another quick test fit of the main buildings, and all looks good.
Some further shaping of the Styrofoam is then called for. This is simply achieved with a sharp snap blade utility knife and includes an initial rough shaping of the “pit” (where the ship under construction will be placed) and a “shelf” to allow the end of the dock to sit flush against the building foundation. I also gave the Styrofoam and base board a coat of paint, using some water-based artist’s acrylics.
More to follow....
Continued from previous post...
We are then instructed to test the fit of the ties we will be using, ensuring they fit flush under the rails extending from the dock, and then to epoxy these down. The ties are not included with the kit, presumably because there is an assumption that anyone building this kit is a model railroader and will have their own supply of these. A quick search on the internet and I was able to locate and procure some HO scale ties (Mount Albert brand). I could have made these from scratch material, but this was a quick and convenient solution. The bigger problem was how to space them correctly, and before that, working out what the correct spacing between ties should be. A search on the internet revealed that there are three common spacings between centres used (assumed “standard” gauge and not “narrow” gauge) – 20” for “main” line, 22” for “branch” line, and 24” for “sidings”. Lacking any further guidance, I decided that the lines in this diorama would be considered “sidings”, so went with 24” between centres. I then drew up a paper template using TurboCAD and attached this to simple jig using temporary spray adhesive. The jig is simply a scrap piece of 9mm MDF with another piece of scrap wood as a straight edge to but the ends of the ties against.
Two pieces of very narrow double-sided tape are then laid on top of the template to hold the ties in place.
And the ties are added – in the example below, the is the longer of the two tracks that will run alongside the derrick dock on the left of the diorama. The ties have all been “grained” and cleaned of fuzz. I initially tried staining them first, but quickly discovered that they would not stick well to the double sided tape, nor the masking tape in the next step.
A piece of high tack masking tape was then laid over the ties and pressed firmly into place.
The entire template assembly was then removed from the jig by carefully peeling away the template paper from the jig (hence the use of temporary spray adhesive earlier on).
The excess tape and template paper were then trimmed from the edge, and the remaining template paper carefully removed along with the double-sided tape, leaving the ties attached only to the masking tape and ready for placement.
Having marked the position of the tracks onto the diorama base, a layer of epoxy was applied to the base and the ties placed in position. I used a 15 min epoxy for this task just to allow myself a little extra time to make sure everything was in the right place.
Once the epoxy had cured, the masking tape was removed, et voila!
The ties were given the alcohol and chalk powder treatment. For these I was going for a much more greyish tint to the colouring than used on the main buildings.
Continued next post...
We are then instructed to complete the preparation of the brick retaining wall and the sea wall, both resin castings. The brick retaining wall comes in two pieces that fit together like a jig-saw puzzle and is designed this way to show the deterioration of the wall. In the picture below, the brick wall has been painted its base colour, while the sea wall (also two pieces) are shown in their unpainted state.
The process for the brick wall is to paint the casting, then cover the entire casting in plaster, washing off the surface to leave the plaster in the joints. I had some trouble with this as when I washed the plaster of the surface, it also took the paint off. I had done this using acrylic paint (AK paints). After a second failure, I spent some considerable time cleaning as much of the plaster out of the joints as I could before starting again with a lacquer-based paint. Here are the wall pieces after cleaning out.
And after application of a red-oxide lacquer primer and re-treatment with the plaster.
The sea wall gets an initial undercoat of AK 11008 (Grimy Grey).
A random application of three other colours is then applied AK 11031 (Buff), AK 11007 (Rock Grey) and AK 11057 (Vampiric Flesh).
A light wash of alcohol and chalk powders is then applied (I used both 408.3 (Raw Umber) and 411.3 (Burnt Sienna)) for this. These washes produce quite a transformation…
The walls are then test fitted and a strip of scrap wood used to block them up to just below the surface of the diorama before epoxying into place.
We now  leave the diorama base for the time being and commence construction of the star of the show – the ship!
Excellent  dio  building.
OC.
Current builds
Completed works.
1 hour ago, Glen McGuire said:
That had to be a lot harder than you make it seem!
Thanks Glen. Actually, the hard part was figuring out the methodology. Once I'd designed and tested the jig and the methodology, the rest was pretty easy.
NAH!!! One of the players for sure, but it takes all of them to make it shine.....
You doing a Foss boat brother or a generic?
Quote:
It's a general purpose ship under construction - just keel and ribs and lots of scaffolding.
Well, historically, you could do a wooden tugboat hull in the process of being rebuilt... Say about 1934-35 or so, post an old worn out name plank titled "Wallowa" leaning up against the office and a new one named "Arthur Foss"  leaning right next to it....
She's the oldest wooden tugboat in the world....
Time period would be the time she was rebuilt in Tacoma, (main deck up, they also did some hull work) after starring in the MGM production of "Tugboat Annie".....
Check her out, She has a rich history being one of only two boats from the Alaska Gold rush still afloat, A movie star, She was involved in the construction of all three of the great west coast bridges, (Golden Gate, Tacoma Narrows & the Lake Washington floating bridge) she was the last ship out of Wake Island before the Japanese took it.... A very rich history....
Would add to the nautica here for sure...
Sorry bout that, the historian comes out in me from time to time.... Anything you do Grant would be wonderful....
Edited by Egilman
Quote:
This dio is shaping up nicely. Good work with the brick and stone. I have a kit of Satriale's Pork Store, from the Sopranos TV show some years back. The street face of the building has a coloration like your sea wall, without the heavy weathering. I plan on copying your colors for the store. 👍
The beginnings of your track work look good. Ought to beat up the ties before you lay your rails. Most sidings aren't very pristine and overgrown with weeds.
Ken
Thanks again everyone for the kind comments and all the likes. It's been an "interesting" week or so....
The Ship Under Construction
The ship under construction is an important element in the diorama – after all, it is the reason for the existence of the Shipyard!
We begin with the Keel, which is provided in the form of three laser cut pieces – one cardboard central piece, and two outer veneers that include some laser scribing. The outer pieces are first given a light wash with AK 11110 (Leather Brown) – my substitute for Floquil Roof Brown – and then stained with chalk and alcohol.
The three pieces are then glued together, and some trim pieces added at stern and stem.
The keel supports are now added, building them up as needed to keep the keel relatively level.
The frames (or “ribs” as the instruction manual calls them) are made up of a three part lamination in the same way as the keel. Again, the outer pieces are stained prior to gluing up. The central pieces have a laser engraved number on them, but as this disappears once glued up, I took the sensible precaution of numbering the carrier sheet to ensure later positive identification.
We then start adding the frames to the keel notches. I had placed four of these when I had the thought that perhaps the ship would look better if the timber looked more like freshly cut wood, rather than the same weathered look of the buildings. While I was thinking on this, I had a PM from one of the people following my build suggesting exactly that and pointing me to a thread where he had done exactly that. So, there was nothing for it but to deconstruct the frames and keel supports and re-visit the colouration, starting with giving all the pieces a light sanding.
Following the example given in the discussion thread, the next step was to apply a base coat of AK11004 (Ivory) – my substitute for FLoquil Aged (Antique) White.
After a little trial and error, I then settled on a combination of Rembrandt 231.3 (Golden Ochre) and 234.3 (Raw Sienna) chalks. Once the alcohol/chalk treatment had dried, I went over all the pieces lightly with a steel bristle brush. This removed the excess chalk and ensured that any scratch lines followed what would be the line of the grain.
Here is the keel ready to go.
And here are the frames also ready to go.
During the week, my additional shingles arrived in the post (at last), so I was able to go back and complete the roof on the Yard Master’s Office. This included finishing the shingle laying, capping the roof, adding rafters and rafter tails, and adding the flashing at the rear of the roof where it will adjoin the Warehouse. I didn’t take any in-progress shots of these steps as these are simply repeats of earlier work. I was then able to join the Yard Master’s Office to the Warehouse/Main Building. I also decided to switch my photo background from black to white for these shots.
After taking these pictures, I realised that the rafters on the end of the Yard Master’s Office are not quite in the right position, so I may have to some delicate deconstruction/reconstruction tomorrow. I also now need to add the roof hardware (chimneys etc), which will be a challenge in its own right!
Edited by gjdale
Fantastic work.
OC.
Current builds
Completed works.
Thank you very much OC, and to all of the likes.
With the roofs now complete, I was able to turn my mind to the roof hardware installation. My concern here was that as these parts were nearly all made from white metal (except the chimney, which is resin) and they all had angled bases to sit against the roof, they would be difficult to hold in place while the glue dried. I decided to add a small spigot to the inboard end of each piece, to be inserted into a corresponding hole to be drilled into the roof. My hope was that the spigot would provide the necessary stability while the epoxy set.
For the four larger diameter pieces, a 1/16” (1.6mm) brass rod could be used for the spigot, however for the two smaller diameter pieces, only a 1mm diameter piece could be used. Drilling these holes into the angled bases without the drill bit deflecting or breaking was the key challenge here. Once again, my little DSPIAE vice proved its worth, holding the piece securely under the drill press.
Here is one of those smaller pieces being drilled with a 1.1mm bit. (This is the tidy side of my work space!)
And a little closer shot.
And here are all the pieces drilled and ready to receive their spigots.
A short section of brass rod was then epoxied into each of the pieces and locating holes carefully drilled into the roof using a pin vice.
The individual pieces were then epoxied in place and the spigots did their job of holding things securely while the glue cured.
Once the glue had cured, the stack on the Yard Master’s Office had three supporting wires attached. These were made from 0.5mm diameter brass rod, cut to length, blackened, and then epoxied into place. To assist in positioning these, a small “elbow” was bent into the bottom end of each and inserted into a corresponding locating hole drilled into the roof.
Here are a few overall shots of the roof hardware in place.
At some point I managed to knock off the top of the lightning rod on the top of the cupola, but managed to glue it back in place with some CA gel – still looks a bit wonky in these pics – may have to try and straighten later.
And here is the Yard Master’s Office Roof:
In the above photos, you can see the boo-boo I made when shingling the Yard Master’s Office roof. I only spotted this when I was installing the roof hardware. I knew that I had to use a thinner shingle strip for the final row, but I forgot that I should have still used a normal width row first, and then placed the thinner row on top. The result is an elongated row of shingles (second row below the capping). I briefly considered whether this might be salvageable, but in the end decided that it was too high a risk of doing extensive damage. I will just have to live with this one.
Looking at the close-up photos, it looks like I need to go back and dull down some of the "pitch" at the base of some of the hardware items too.
With the roofs finally complete, I can now return to the ship under construction.
Edited by gjdale
Looking very convincing!
I wonder, why they didn't cast on a spigot right away. They could have used it for the casting process as riser or something.
I don't know much about such constructions, but wondered whether there shouldn't be some sort of sleeve or a sheet of metal around the sheet-metal stove-pipes to prevent the shingles from catching fire?
I would not have notice the shingling boo-boo, unless you pointed it out.  Too many other amazing details competing for my eyes' attention.  And even if I had spotted it, I wouldn't have thought it was a mistake since it's uniform on both sides of the roof.
The real world is filled with wonkiness and like Glen, I wouldn't have noticed the shingle thing unless you pointed it out.  Nice progress Grant - looking really terrific!
Gary
Amazing detail work, Grant!
Is DSPIAE an acronym or a brand name? Also, what brand and model is your small drill press?
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
