Display case for Campanula waiting to dry, Seehund base drying so I wanted something to work on that wouldn't take too long while other things were on hold.
This is the VTOL concept Weserflug P1003 in 1/48 scale. I'm not sure if it counts as Luft46 material given that it was a prewar concept that never made it off paper. In essence it has a valid concept but as with all STOVL aircraft the devil is in the details. The two big issues are usually weight vs thrust (its a direct relationship in VTOL) and control. Tilt wing and tilt rotor have culminated in the V-22 and the complexity of the control system is staggering.
This was to have been a two man crew with a single fuselage mounted engine driving the overlarge propellors. With driven shafts and gearboxes weight must be an issue and controlling the wing movement must be an issue. With limited wing in the flight plane the aircraft would have to be VTOL rather than STOVL I would think which limits weight even more and the in-air transition would be more exciting.
I have spent more than half my career on non-helo STOVL aircraft so I'm a bit of an easy sell for this kit. I'm happy to park my doubts and see how it comes out.
The kit comes with a nice big instruction booklet with three colour schemes (all fictitious of course) generally using the leopard spot camouflage in one way or other. Decent sized assembly drawings
I doubt this is a recommended flight configuration
The sprues are nice and clean, No flash or major mould lines and reasonable injection points to the parts. So fr the parts fit beautifully. Every locating pin fits its partner hole and it is  delight to put together.
Its a single seat cockpit (weight limitations must have ruled out that second crew member).
The main landing gear is very nicely done, made up of four pieces with an arm that clips into lugs in the main leg and then swings down into position in the fuselage.
So far this seems to be a very well thought out kit regardless of the authenticity of the finished model.
It looks like being a nice side project and I hope you enjoy seeing it come together.
Thanks for looking in
Alan
Well I'm not too much into flights of fancy like Luft '46 and that stuff... But the Germans had a lot of very talented people that could forward think really well... And given time, they would have made a lot of these speculative design ideas a reality...
I'm in brother...
Quote:
20 hours ago, CDW said:
Nice project Alan. Looking forward to this one.
The Germans paved the way for the modern day, Marine Corps Osprey.
Thanks Craig. I think this is going to be fun and the kit is a delight. Its my first aircraft so I'm right back at the beginning working out order of assembly and basic stuff about colours.
As far as I can tell this is the start of the DNA chain that leads to the V=22
Alan
I'm in brother...
Thanks for joining Egilman. The steadying hand is always welcome. I agree with you I am not very keen on the wild ideas that seem to have come out of Germany towards the end of the war. I assume having a megalomaniac demanding wonder weapons really stimulates the imagination.
Although this never made it off the drawing board I think it has its basis in realistic possibility. Weight would be an issue and control and stability in VTOL mode would be interesting but it might have been possible. You only have to look under the hood of an AV-8B to see what you can do with rods, cables and bike chains.
Alan
Most definitely the West got a treasure trove of flight data, along with the Soviets. Many fascinating concepts that took years to come to fruition. I'm in on this bird. 😁
Ken
Started: MS Bounty Longboat,
13 minutes ago, CDW said:
Think Operation Paperclip. Realize all the technological advances that came as a result of that operation, not the least of which was the 1st manned landing on the moon.
Definitely Craig. Paperclip had some controversy but it was practical politics in the postwar world.
And some of the concepts were valid but the execution had to wait until the associated technologies were available to enable them.
In my field the F-35B has a number of previous concepts in it but needs the massive computing power available today to make it flyable, some of which are actually derivatives of Soviet designs. Very little starts in isolation but is a development of something else.
Fascinating stuff
Alan
I'm in.  Fascinating concept aircraft.  The Germans did get beyond the manufacturing abilities during war.
Alan
This may have been part of it, but I am not so certain it's the whole of it. Where exactly thoughts and ideas came/come from remains elusive and not beyond debate. The regime of that time dabbled in many things not often seen as 'orthodox'.
And all  that reverse engineered  stuff  - trying to create zero gravity  crafts.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
The flying wing ideas of the Horton brothers began in the late 30s, I seem to recall. As well as the helos.  And the megalomaniac screwed with so many aircraft designs, demanding dive bombers from his twin engine bombers and the Me-262. Delayed deployment of a sizable chunk of the Luftwaffe in these wide goose chases. Luckily for us.
Ken
Before the USMC did it, Canada had it done....the CL-84 Dynavert.
They even tested a gunship version of it with 7.62 miniguns in pods.
Canadair CL-84 Dynavert - Wikipedia
Cool project!
Brad/NavyShooter
Hiller was the first one to get a tilt-wing to fly the X-18 in 1955...
They were followed by Curtis-Wright  with the X-19 in 1960, followed by the Ling Temco Vought XC-142 in 1964, then the Bell X-22 in 1966 and finally the Canadair CL-84 "Dynavert" in 1972....
But is is important to note that these are all tilt-wing aircraft, the V-22 Osprey is a Tilt-Rotor aircraft, same aeronautical theory, completely different mechanical arrangement...
But they are all amazing engineering accomplishments...
Quote:
Welcome Mark
I've been reading up some of my STOVL material and it registered that tilt rotor (like the V-22) requires a surplus of power compared with tilt wing because in tilt rotor you waste thrust blowing on the non-compliant wing.
So for the days of limited power (although in STOVL you always have limited power) the Germans made the correct choice. The fixed stub wings might even have given them a little STOVL capability too
Alan
Craig
You are right, I was being a bit frivolous but I do get the impression Hitler wasn't an easy person to tell that the wonder weapons were not working out.
As you say their science and arts had some strange and esoteric frontiers all the way to mysticism. Maybe thats a fertile environment for unrestrained thinking
Alan
Definitely Ken
Along with his fat Reichsmarshall I think they severely reduced the effectiveness of the Luftwaffe and could be argued paved the way to losing the war. No complaints on my part. The aviation designs and concepts are fascinating though. The Ho229 in particular. Again an early concept that led to things like the YB-49 i think. I have a Ho229 on the wish list
Alan
Looking forward to what you are able to do with this Alan
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Cool project!
Thanks Brad
I think there are a number of variations on the tilt rotor / tilt wing theme.  Some were pretty successful even before the digital age.
Alan
Thanks as always Egilman,
Great reference information. I have a nagging feeling that there was a German tilt wing post war Dornier maybe? I haven't had time to dig out that STOVL book
Alan
Thanks Lou
I hope you will like it. The kit provides three colour schemes all what i would think as late war. I think I will try what I think is the night scheme of black underside and the leopard light grey and violet grey above
Alan
The cockpit has been finished off in the late war dark grey. I added some dry brush metal on the wear surfaces around the cockpit and a panel line wash. I used the Mig panel line wash and found it didn't flow terribly well until I added more thinner.
It's not terribly noticeable but a check with the canopy on suggests it's all going to be invisible anyway. Tape seat belts and I used the Mig crystal fluid in the instrument dials and then some bright metal wear.
Then closed it all up. It went together nicely and needed little clamping to hold the fuselage halves together. The fit has been great. The stub wing is quite a complicated shape but it fitted without any persuasion.
A coat of Mig One Shot black primer and then onto colours
I borrowed someone technique and used clear coat to "glue" the masked canopy in place. It seemed to be a good fit and easier than masking around the seat
Thanks for all the input and likes. I hope everyone has a great weekend
Alan
Unfortunately the cockpit gets closed up, but you did a nice job beating up the details in it. Typical of a aircraft used hard, with so-so maintenance.
Ken
Thanks Ken
It looks a little better closer to actual size 😃
I imagine there were some fast grabs for the controls in this one at times
Alan
Yep, The Dornier Do 31... in all respects to the extent they tested it, it surpasses the Osprey... (it was never flight tested to it's full capability) They simply ran out of money and when they tried to sell it to the US Navy for onboard replenishment, they Navy wasn't interested...
The first truly successful V/STOL aircraft... And one that most know nothing about... It was actually capable of doing an aileron roll, or what would pass for one in a conventional airplane.... (demonstrated in public, and the test pilot was told to never do it again)
It was definitely an example of forward thinking, and of others without that capability deciding what to do...
Quote:
