Of course, I'll do a theme from the beginning. I need time (given that I started to build this ship by this since the beginning of the year.
Screensaver of Forum is reviving (to materialize)
Edited by AlexBaranov
What beautiful craftsmanship.  You have done all of this in 8 months?  Incredible.  AntiSpiral mentioned that there is a Russian forum you have the build posted on as well.  Would you mind posting a link to that?  Thanks.
Toni
Member IPMS
                           Utrecht-1742
Hi, im glad you've started to post your work here, i've been looking at your progress on the russian forum and your work is very impressive! :D
Now, these works will be here
I think that there is no point in doing link building progress will continue at the MSW
I is manufactured by a composite body. I'm layering the required number of layers of thin boards. I'm using PVA glue. The fastening straps, thin boards (stapler). This technology protects the ship model from changes in humidity and steady. In this case, the use of the five layer boards. The model is very large. Maximum length of 1,697 millimeters
Alex,
brilliant stuff! May I ask what material you used to cast the cannons and what you used to maked the moulds? Did you use a single or a two-piece mould?
Regards
Peter
Hello Peter!
I use the age-old method of casting bronze and brass investment casting. I use two types of wax (wax models for single and bulk wax models (injector)).
You can see more samples on my website here:
With return to MSW, Alexey! Magnificent model and fine work!
:)  :cheers:
Edited by Garward
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
:)  :cheers:
Everyone knows that the Earth is round, but there are always people do not always equal status. I highly appreciate my colleagues around the world, and I think that our art has no specific nationality. We all live in a shared house. We are united by common interests. Among other things, this is a decent answer to Mr. Demin (shipyard on the table). :cheers:
Alex,
if I were to supply you with master cannons, could you cast them for me in the amount required? I Need 68 cannons in three different sizes, the largest being approx. 15 cm in length, the others slightly smaller. Do you cast them with the dolphins in one piece, or are they soldered onto the barrels later?
Regards
Peter
All guns are made in one piece. Of course I can not do any artillery. However, this process does not depend only on me. I do not have a foundry, so hire a caster. Foundry work has a very high price. Very big gun 15 centimeters! The fact that this product will be extremely difficult. I pay 1.5 euro per 1 gram of product.
If the artillery is very necessary for you, I propose to discuss this issue more seriously. Need to weigh and count to consider the number and size of models, the total number of artillery guns on each model.
Simply great, thanks for sharing the log. Did I miss it or what are the dimensions?
Inspirational
Cheers, Harley<p
Under Construction:    USS Yorktown CV-5 1/200 by Trumpeter
Completed:              USS Curtis Wilbur DDG-54 1/200 by ILoveKit
                                USS Atlanta CL-51 1/350 by Very Fire
                                Liberty Ship John W. Brown 1/350 by Trumpeter
                                HMS Spiraea K-08 1/350
                                 USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                 USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                 USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                 USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                 USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                                 US Brig Syren 1/64 Model Shipways, Wood
Started, On Hold:  Frigate Confederacy 1/64 Model Shipways, Wood
