This  is  just Unreal  -  Superb work  Greg.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Hard to pick but this is the radio antennae. Attempt 5 today. When I did it years ago it worked well but I’ve always wanted them slack. So very thin wire in the centre and denier lines on the outer. This is pretty much the hardest part of the build
Edited by RGL
Greg
Another Master Class Greg!  :imNotWorthy:
Andrew
Completed (Kits):-
Absolutely!!!!! The Michelangelo of 1/350th ship models....
Stunningly Amazing.....
Quote:
Amazing work  Greg   -    you  should  seriously   see  if any   nautical  museums   would  like thease  for  display   -  they  are   up to  standard  with out doubt.
OC.
Current builds
Completed works.
That's a pretty good rendition of the swell on a mild day on the North Sea.... (10 to 12ft)
Now to duplicate the greyish black-blue of the water...
Geese, a master at work... It's a sheer pleasure watching you do your thing brother...
Quote:
Just stumbled into your log Greg. With a bit of time, I will read the entire thread about how your masterpiece was made. I´m sure, there´s a lot to learn in it. Your Dreadnought looks fantastic overall and I couldn´t imagine, how difficult the antenna rigging was.
Cheers Rob
                             Duchess of Kingston - paused
                             USS Arizona 1/350 Eduard
2 hours ago, amateur said:
I never realized there was this 'slack' in the antennae.
Yep Radio aerials are never taut, especially in the beginnings of wireless.... The copper wire was just plain too soft, they would break under their own weight if stretched too tight... By the time WWII came around they had switched to aluminum wire for aerials, much much stronger, they could actually pull them almost straight...
I have a headache from trying to figure out how he did it without making a tangled mess...
Quote:
