SBLim-2A by ccoyle - FINISHED - WAK -1/33 - CARD - Polish license-built MiG-15 variant - a semi-tutorial
Introduction
Welcome to yet another build log for a non-wooden, non-ship model! This build is inspired by a discussion that was had in my A6M5a build log. Fellow MSW member Craig (CDW) shared that his only attempt at card modeling was "a disaster," in his words, so I suggested he take a look at WAK's skill level 2 kits and offered to build one along with him, whichever one he wanted. He took me up on the offer and chose the SBLim-2A, so that's how the subject of the build was selected. Richard (Richard44) has also expressed an interest in building this kit (click HERE to see Richard's build) -- let's see if we can get any others on board, maybe?
BTW, except for a very simple, free, downloadable, flyable MiG-15 glider I built many years ago, this will be only the second jet I have ever built in card. 😮
The Subject
The SBLim-2A is a Polish, license built, two-seat reconnaissance variant of the MiG-15, built by WSK-Mielic in the 1950s. It's actually a conversion of a conversion. Originally, 227 Lim-1 (Licencyjny myśliwiec - licensed fighter aircraft) were built; some of these were later converted to SBLim-1 two-seat trainers (equivalent to the MiG-15 UTI), and some of those were later converted to the SBLim-2A. Confusing, right?
The Kit
The kit, representing an aircraft wearing the 1993 livery of the 7th Naval Special Aviation Regiment, is designed by Lech Kołodziejski, a respected designer who has published his own designs under the brand name CardPlane. I have built five of Lech's CardPlane kits (see the finished non-ship models section). Lech's CardPlane offerings were all models of either prototype aircraft or planes that entered into very limited service. His designs published by WAK have been more widely recognizable aircraft. Some of his recent efforts, including this one, have been collaborations with graphic artist Marcin Dworzecki, whose work is second to none in the hobby. As you can see, I purchased the available molded canopy and laser-cut frames.
A quick pitch here for WAK. They have become one of my favorite publishers and a first-choice vendor. They offer a large selection of kits and always process orders promptly, package them securely, and offer very reasonable shipping rates compared to other vendors. If you shop there, tell them I sent you!
The kit is designed with amateur builders in mind, and it shows. In this next image you can see, for instance, that only very rudimentary cockpit elements are included. Stuff on the side walls is printed rather than being separate parts.
There are likewise no separate control surfaces nor landing gear bays. (EDIT: Upon further inspection, I discovered that optional wheel well parts are included.)
Lech draws pretty easy to follow diagrams. Horrible white balance in this shot -- sorry!
There's a lovely three-view.
Finally, as a huge bonus, but not shown here, the kit includes instructions in English.
The Purpose and Guiding Philosophy of This Build
We all know that when it comes to beginners and wooden ship models, there is such a thing as "too much model." This is certainly true for card models as well. If you have never built a card model before and decide to start with Halinski's Bf-110G-4/R8, you will fail miserably (heck, even I'm not ready for that one). The WAK Skill Level 2 kits are a good compromise between detail and ease of construction. At least I hope that will prove to be the case, because I haven't built one yet -- but I trust Lech. I have titled this as a semi-tutorial, because it is not my intention here to describe every necessary tool and basic technique for building a card model; if you need that kind of help, you can find it in our Torpedoboat V-108 tutorial. So I will not, for example, demonstrate how to fold a part or roll a tube, but I will try to include as much detail as is necessary to get a novice builder through this project. And speaking of 'novice,' I will also try to make this build as much as possible an "out-of-box" project -- except there is no box, of course.
So, join us on this adventure, won't you? And if you're feeling particularly bold, get the kit from WAK and jump in! Come over to the Dark Side --er, I mean, the "wonderful world of card models"!
Cheers!
Part 1: Cockpit Assembly
I started by separating the booklet pages and giving the parts pages my usual coat of matte clear varnish spray (some modelers have suggested that gloss varnish soaks into the paper better, and the shine can be knocked down later with a top coat of matte).
To make the pages easier to handle, I separated the cockpit parts from the fuselage parts.
Fold lines need to be scored in advance. For this I use a straight edge and a small-diameter manicurist's spotting tool. A scribing tool could also be used for this task, but it makes a sharper crease, which makes the ink more prone to cracking when a part is folded.
The part is then cut out and folded.
This task is repeated for the observer's tub. I wrote the part numbers for the two tubs (sounds like a missing novel in the LOTR series -- "Book 2A: The Two Tubs, in which the fellowship finally bathe after weeks on the road without showering") in pencil on the reverse side just to help distinguish which is which. Afterward, I glued one side of each tub. Leaving the other side open for now will make it easier to add internal details, such as the seats.
A quick note on edge coloring: At this point, I'm not sure how much, if any, of these edges will be visible later. To be safe, I have colored the cut edges with a gray Crayola marker (hi-tech, I know). At some point, each builder will need to decide on an edge-coloring technique to use and start thinking about matching colors in the kit.
That's it for this evening, but looking ahead at the build sequence I saw that laser-cut parts will soon be needed (if you are using them), and I was going to conclude my workbench session by numbering the parts with a pencil. But I was pleased to learn that each part already has its number laser-engraved, eliminating the need to manually add one -- a very nice touch!
See you next time!
18 minutes ago, Ian_Grant said:
Seems to be a very small aircraft; kind of stubby.
A lot of 1st generation jet fighters had that stubby "pilot strapped to the back of a jet engine" look.
On the plus side, the finished model should not take up too much precious display space.
The instructions call for the first section of fuselage to be be built next. Here is the section and its joiner strips.
But before we can move on, we need @CDW and @Richard44 to make a decision: wheel wells or no wheel wells? If the former, then we will need to remove part of the joiner strip before gluing it to the fuselage piece, as indicated here:
1 hour ago, CDW said:
If it’s ok, would prefer to try my first card model with gear up.
The option is to do no wheel wells -- gear up would require some modification, but I could probably do that without too much difficulty. I can look into it.
EDIT: Gear-up is definitely doable. Doing so would require making a stand, but that would not be difficult.
Either gear up or down is okay with me, I just thought the added issues with wheel wells might be a lot for a 1st kit. I'll follow your lead whichever that is.
I'll try for the wheels down. I can always use the photo copied pages for a second go 😁. Wheels though, not easy to make realistic looking ones 😬.
Richard
Current builds:
Completed builds:
SBLim-2A, MiG 15 variant, WAK card
Harpy by Vanguard
AL's Endeavour,  Corel's BellonaAmati's Xebec,  Billing's Roar Ege, Panart's Armed Launch
Ships' Boats - Vanguard 1:64 and Master Korabel 1:72
 Alexander Arbuthnot,  Christiaan Brunings,  Pevenseall by World of Paperships, card
HMS Pegasus by Victory
Captain John Smith's Shallop by Pavel Nitikin
Rumpler "Taube" 1911 by HMV, card
Tell you what, I will go for gear down and add the wheel wells, but will point out how to do the simpler versions.
Wheels are not too hard to make, just a little labor-intensive -- but that comes later!
This is all I had time for last night. In this progression, we see first the fuselage parts with the joiner strip as it should be used for the no-wheel-wells option, the parts with the joiner trimmed for wheel wells (nose wheel, in this case), and the prepped fuselage section with its bulkhead, which consists of a laser-cut frame and printed part laminated together.
image.jpeg.9a5ae1b4899b5dadde071c5d70bd1dec.jpeg image.jpeg.b8539b451f7f656c6f1bb5d172194390.jpeg image.jpeg.2d86373dbcdf0f0af540b6b52c473b74.jpeg
Some thought had to be given to the bulkhead. As I mentioned earlier, the frames are laser-engraved, as seen here.
It took me awhile to realize that the printed part is not the interior cabin color, but rather a kind of false air inlet that will be seen from the front of the finished model. Therefore, the part needs to be glued to the back of the printed bulkhead, making sure the two oval-shaped holes align properly -- they are not centered.
That's it for now!
3 hours ago, CDW said:
How should I proceed with my build, separate thread or here?
Refer back to the PM I sent last Sunday.
BTW, that was less than two weeks' shipping time, right? The people at WAK don't mess around!
One thing I have learned over two decades of building card models is that it pays to study and re-study the diagrams. The part I mentioned in post #12 is not a false air inlet -- it's the interior nose wheel well color. Also, I noticed that the pilot's seat protrudes above the level of the fuselage, so it can't be glued into the cockpit tub until after the tub is in the fuselage.
Here's a couple of simple modifications I made to the bulkhead before proceeding. First, I don't know how much of that bulkhead will be visible on the finished model, so to be safe I added some interior color to it. It's not an exact match for the cockpit tub, but at least it's not pulp board colored. Second, I added some scrap card along the lines that indicate where the tub is to be glued. This will make neater and stronger joints between the tub and bulkhead.
Here's the fuselage section glued into a ring. Try to get the ring as round as possible -- it will make fitting the bulkhead easier, and the ring will be more difficult to shape once the bulkhead is in.
A couple of tips on the bulkhead. Notice that the fuselage section isn't a true cylinder -- it's a conic section. Beveling the edge of the bulkhead will make it easier to fit and enable it to make better contact with the fuselage skin. Only a slight bevel is needed, so don't go overboard. If you want, you can soak some thin CA into the bulkhead to stiffen it.
With the joiner strip in place, it can be difficult to align the bulkhead properly, unless you were careful in aligning the joiner strip to the fuselage piece first. If you were careful, then gluing the bulkhead flush with the ends of the darts cut into the joiner strip will also make the bulkhead flush with the cylinder opening. You can see here that the dart tips just touch both the fuselage skin and the interior bulkhead.
Tip: With a large bulkhead like this one and any type of fast-setting glue (such as canopy glue), you may not have time to adjust the part if you apply glue to the entire rim of the bulkhead first and then try to position it within the cylinder (or vice versa). What I do in such instances is position the dry bulkhead first, then run a bead of glue around the interior seam -- like caulking a tub.
That's it for this session!
I continue to admire the way you open the world of card modelling to others. Thanks.
Tony
Edited by tkay11
syntax
Being an intermediate-level kit, only rudimentary cockpit details are included. Here is the instrument panel laminated to its laser-cut backing and edge colored. No option for glazing is included, but it could be done by using a photocopy of this part. I have depicted glazing in some of my other logs.
And here is the panel glued into the cockpit. You might be able to see where I added a center line tic mark on the fuselage skin to help position the panel correctly.
The next numbered part is the gun sight. I suggest holding off on that part, because it sits on top of the cockpit dash, which means it might get bumped a lot during the fuselage construction. I have circled this part on the construction diagram to remind myself to add it later.
Next we'll work on the bits that go into the cockpit tub.
A bit more progress. . .
Next we have the rudder bar. There is a template for making the bar from wire. Don't worry about matching the template exactly -- this element will be difficult to see in the finished model. In fact, the instructions even suggest omitting the rudder bar if you don't want to deal with it.
Here's the finished rudder bar mounted to the cockpit floor. The bar is fiddly -- there's no magic bullet for coping with the tiny parts. Maybe keep a swear jar handy?🤔 Also, there's no locator mark on the floor, but the bar is supposed to be positioned directly below the instrument panel.
Next we will start on the seats, remembering that the pilot's seat doesn't go into the cockpit tub until later. Here's a bunch of seat parts that need to be doubled, i.e., folded and glued to make a 2x-thick part.
The instructions say that the two seats are identical, but there is obviously two different sets of parts #11. I suspect the difference is linked to slope of the floor in each tub, but I will need to confirm this once both tubs are ready for seats.
There's also a bunch of seat cushions that must be laminated to laser-cut backings.
That's it for tonight. Time permitting, I'll get the seats assembled tomorrow.
Here are the parts for the two seats.
Making the seats is not difficult. Matching the curve of the bottom to the two sides on each seat is a bit challenging, but not overly so. There is no reverse-side printing on the parts, so you will need to add some color to the front of each bucket. You can now see the different cant produced by the two sets of seat mounts -- the seat on the right with the steeper cant is the pilot's seat.
The control stick has been added. The kit provides a paper part to be rolled, which is a pain for tiny, narrow tubes, so I replaced it with painted 0.88 mm styrene rod.
All we needed to do next was glue the tub into the cockpit section and add the seat. BTW, there are locator marks for the seat on the cockpit floor, but they don't match the width of the seat mounts. They're useful, though, for centering the seat.
Next we move to the observer's station, starting with his instrument panel. The panel consists of three pieces of 2 mm laser-cut card to be laminated together and then skinned.
The construction is not difficult.
And now for some bad news: We had our first hot day in the Upstate today. I had to turn the AC on for the first time this year to cool down my sweltering upstairs man cave (I really dislike summer weather). We also got a cubic yard of topper for the front lawn, so a lot of spring yard work is in the immediate forecast (I really dislike yard work). Hopefully I will still get some modeling time in.
That's all for now!
Now we get to see that fuselage grow! The forward bulkhead of the observer's section has a color piece to be laminated to the laser-cut bulkhead.
Here are all the parts and sub-assemblies for the observer's section. Both bulkheads have been beveled.
We add the joiner strips, close the cylinder, and glue in the forward bulkhead. It's better, I think to glue the instrument panel to the bulkhead after the bulkhead is glued in -- adding the panel first would make it more difficult to glue in the bulkhead.
I added some scrap 2mm card to the flimsy observer's tub to increase the gluing surface area.
Once the tub is glued in, there's no way to reach into the fuselage to help position the aft bulkhead. To make the task easier I punched a couple of holes in the bulkhead and stiffened it with CA. The holes make it possible to manipulate the bulkhead with pliers.
And here's the finished assembly.
A little bit of muscle (but not too much) will be required to glue the two fuselage sections together, so it's a good idea to let the glue cure for awhile.
That's it for now!
And yes, if you're wondering, I did mow and edge my grass today and plan to de-thatch it this evening. Fun. 😑
Now we get into one of the construction sequences that is affected by whether the builder opts for wheel wells. If you choose to omit wheel wells, the sequence is pretty straightforward -- just two more conic sections and a bulkhead. (NOTE: Regardless of option, weight must be added to the interior of the nose for the model to sit correctly on its tricycle gear.) If you decide to go for the wheel wells, well then things get a little dicier.
First we fold and glue up the nose wheel well -- no biggie. I later added scrap card strips along its sides, as I did for the observer's tub. DO NOT add strips to the front or back -- the tub is designed to fit snugly between two bulkheads. Note that there is a small projection on the forward end of the well.
Here we have the forward bulkhead with the faux air inlet laminated to it. The builder can either leave it like this or choose to add a more detailed inlet divider. The cutout at the bottom is only done for the wheel well option -- this is where the previously mentioned wheel well projection passes through the bulkhead.
The next part could be a challenge. The first part of the detailed air inlet consists of a printed interior color ring that has to be wrapped in multiple paper rings. The challenge lies in getting the first ring perfectly round. Here's how I went about that. First, I needed to pre-shape the interior color ring. Happily, it fits perfectly around the handle of a 23mm dapping tool. The part was dampened, wrapped, taped, and allowed to dry. Note that the color side goes on the inside of the ring.
Note that the ring parts are lettered b to f and that their lengths increase slightly with each part, because as each one is added, the diameter of the ring increases.
Leaving the first ring on the dapping tool, I overlapped the seam with ring b to close the first ring. For each successive ring, I shifted the seam slightly so as not to create a weak point in the ring's structure.
Here's the finished ring with some items to note. First, I wrapped the wrong end of the interior color cylinder. 😑 The wrapped rings should be at the front of the cylinder, and the little printed triangle on the interior ring points in that direction, hence my rings are on the back. Fortunately, this is only a minor error, but it's still annoying. Second, I did not add ring f; I noticed that each ring produced a widening gap at its seam, indicating some error creep, so on the very strong suspicion that the ring will be slightly too large even at this stage, I chose to leave the last ring off. Lastly, I soaked the outside of the ring with CA to stiffen the part.
Finally, here's a group shot of all the parts that will go into making the nose of the aircraft: two conic sections, the wheel well, the inlet bulkhead, the inlet ring, and the parts to make the inlet divider. Unlike the previous fuselage sections, the larger ring here has no seam tab, since its two ends will land on the wheel well (hence the addition of the scrap card along the well's sides), and the smaller ring does not wrap around a bulkhead -- it will be glued to the joiner strip on the larger ring aft and to the interior air inlet ring forward. I suspect I may need to bevel the inlet ring to get things to fit easily. Fingers crossed!
Okay, I made a significant blunder in this next phase! 😬 More on that in a moment . . .
Next we assemble the air intake duct. A pair of laser-cut parts form the divider. You can see that I somehow managed to scuff the black portion on the left side, so I painted over both faux recesses. The left side of the sheathing needed very slight trimming, as did the center-line covering strip.
 image.jpeg.97ea016a4f0a5d05ff5e763dfb180554.jpeg image.jpeg.2e8872964d67c108e4c45b1d29f50230.jpeg
There are two ways you can do the forward section with the intake, either add the intake to its smaller ring and then join the two rings together, or glue the rings together first and then add the intake. I strongly advise the latter option. There is no joiner strip provided for the forward ring, so I mad a small one from 20# bond. Joining the rings might seem awkward at first because the aft ring isn't closed at this point, but the task is not difficult.
Next I added the wheel well to the cockpit section. There is no tic mark printed on its interior, but you can easily position the well by aligning its hole (where the nose wheel strut will go later) with the hole in the bulkhead and its sides with the fuselage's printed lines.
And here's the finished nose. When joining these two sections of fuselage, care must be taken to make sure the forward projection of the wheel well fits into the bulkhead gap provided for it and within the fuselage skin. Don't forget to add glue to the wheel well sides where the ends of the fuselage ring land on them.
Let's see -- did I forget anything? Oh, yes, that's right -- I forgot to add EXTRA WEIGHT to the interior of the nose! 😑 Derp!! Oh, well -- I have a solution in mind for that when the time comes.
That's it for now!
Time to work on the aft fuselage. This next fuselage section was supposed to be added before working on the nose section according to the instructions, but that fact was only very briefly mentioned, which is how I managed to overlook it. In reality, it makes no practical difference whether one adds it earlier or only just now, as I have done.
This section is a basic ring structure plus a bulkhead. There are two spots, marked with a 'W', that must be cut out. You can do that now, or after the section has been added to the fuselage. The latter option is advisable, since cutting them out now will create two weak spots along that edge.
And here's the fuselage after that section has been added.
Just one more section to go!
Is that treatment with the paint pens you got recently?
Andrew
Completed (Kits):-
The 'treatment' of the seams seems very successful.
Dan
No, the treatment is an idea that popped into my head while pondering the fact that the seams appear much darker than the surrounding print (but I'm sure I'm not the first person who ever thought of this). I created a thin wash from very dilute white glue and light gray paint. The hope was that the wash would tone down the edge coloring without completely covering it -- kind of like looking out a window covered by gauzy curtains. The wash is thin enough to wick into the offending seams.
Now for the last fuselage section. It begins with the engine exhaust nozzle, a rudimentary structure consisting of four concentric rings and a bulkhead. Warning: the inner nozzle piece was too long and ended up forming a cylinder with a diameter too large to wrap the outer piece around. I fixed this by forming the outer cylinder first, adding the bulkhead, and then trimming the inner cylinder to fit inside.
This finished basic cylinder gets wrapped with a pair of spacers.
The last fuselage section is a simple conic section with a joiner strip. After that is glued and has had time to dry, the faux exhaust nozzle is added from the front and the spacers (not the cylinder!) are aligned with the end of the cone.
Yet more drying time, after which we can glue the last section to the rest of the fuselage.
With that, the fuselage (except for the canopy and gun sight) is done! Next we'll move on to the empennage.
