Wonderful Giampiero. You rarely see the rudder coat included on models. I suspect that fitting and nailing it over the tiller opening is not easy!
In fact it was like performing surgery, especially because ebony needs to be drilled before nailing.....
Giampiero
Following your work as well. Just catching up, and as usual updates are brilliant. From a few clicks back, those doors and hinges are beyond perfect. (:-)
Michael
Edited by md1400cs
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Giampiero
Your "small updates" would be for most of, well major milestones (:-)
As usual brilliant. That chair. for example is well - (as we say here in the USA) - "ridiculous"  It's a huge compliment (:-)
Cheers,
Michael
Under the table:
Completed:
Vasa-Corel -
Just beautiful, Giampiero.  Is the ebony laid onto the decoration of the rails in the last 4 pictures?
I love your inlay work.   And as Mike pointed out, that 2nd from the last picture is wonderful.
Here we go again - with "little progress" awesome indeed. Brilliant work.
I am learning a lot from you, apart from just enjoying the absolute beauty of your skills with this log. Thank You !
Michael
Under the table:
Completed:
Vasa-Corel -
Now that a detail one doesn't often see actually done on the French models.   Impressive work, Giampiero.
I started to build the doors for the oars; the major difficulty has been to be able to realize the hinges so that they were functional.
First, by a thin copper foil has formed the curved part:
I filed the interior with the grinding wheel after drilling the holes 0.3 mm
I finished the outside
I made the hinges by cutting half with the grinding wheel
The part of the hinge to be fixed at side
Fantastic micro work.  I'm surprised you could make something that tiny functional.  Very well done.
