Hi Pat, I showed my set up here: http://modelshipworld.com/index.php?/topic/410-hms-sphynx-by-alex-m-scale-148-english-20-gun-frigate-as-build-1775/?p=5559 I have turned them on an old Unimat SL machine. To turn taper surfaces you should set the head stock to the angle of taper, so I do it as showed in the picture from above. Then I have tuned each gun at one time using brass template as guide.
Here is my Unimat:
Alexander
Current build: HMS Sphynx, 20 gun ship launched in 1775 at Portsmouth, Hampshire.
On the drawing board: HMS Anson, 64 gun third rate ship of the line, launched in 1781 at Plymouth
Excellent build!! Simply fascinating. I especially like your jig for making the breeching rope.
Construction Underway:
Builder's Yard - USS STODDARD (DD-566) 1967-68 Configuration (Revell 1:144 FLETCHER - bashed)
In Development - T2 or T3 Fleet Oil Tanker (1:144 Scratch Build Model) - 1950s era
Currently - 3D Design/Printed 1/200 scale USS PURITAN (BM-1)
Completed:
Armed Virginia Sloop (1768)
Royal Caroline (1748)
Sloop/Ship PEACOCK (1813) (Scratchbuilt)
USS NEW JERSEY (BB-62) 1967-69 Configuration (Trumpeter 1:200 bashed MISSOURI)
3D Design/Printed various scale USN Gun Mounts/Turrets, and GFCS Directors
Member:
New Bern Ship Modeler's Guild
NRG
NCMM Beaufort -CSMA
Hello,
before I put the guns on their positions, I have decided to work around hull, especially the stern area und the bow. Here are few pictures of making the windows. The wood is Castello, the strips are 0,5x0,5mm and 0,5x0,8mm. For glazing I have used 0,3mm thick plastic from package, then glued framing with CA. The framing of stern windows was transfered  to transparent paper, then the windows mullions are drafted on this transparent paper according to plan. Then I have glued white paper sheet to wood plate, and glued transparent paper over the first. So I have correct windows outline and right angles. Then placed clear plastic sheet over paper, and fixed them with tape.
Now the mullions. Horizontal mullions (0,5mm x 0,5 mm) are glued directly to plastic with CA glue. Then slots for vertical mullions are cut out with chisel, they are not halflapped, they go through horizontal down to plastic. This is showed in third picture. Then vertical mullions are glued on. then all was cut to right length according to drawing. Then outer frames (0,5mm x 0,8 mm) are glued, again directly to plastic. Then the windows are sand flush, the plastic was then cut out, and the window is ready.
The horizontal strips are glued first, then gaps for vertical strips are cut.
Vertical strips glued on, cut to right height, and outer framing gluing
overall view with outer frames. Also the sliding windows.
Close view after sanding
The frame for permanent window glued over additional sheet of plastic
Check how they fit. The windows need some cleaning, then coat of varnish will be added to simulate old glazing.
Preparing framing for galleries beginns
The shape of windows traced to transparent paper.
The windows for galleries are done in the same manner as before. The glazing is imitated by adding a coat of varnish, this give the irregular transparence like old glass. The battens between windows added separately. They will recieve mouldings later, and are hold at now by a little spot of glue.
All windows are dry fitted at now.
Here is how the wooden shindles are made, and ready cover for gallery
The planking of stern is completed. The arches are made from two strips of 0,6mm boxwood glued together.post-835-0-51550100-1361438004_thumb.jpg
Internal view with few beams of QD installed
To be continued
Alexander
Those stern lights are beautifully done. I like the way you've also shown the sashes. Can you tell us  a little more about your varnish technique for the glazing. Is it just held in place by surface tension when you apply it, or do you do this on a non-sticking surface?
Thank you Karl nad druxey!
The base for windows is plastic sheet, as I have described earlier. The varnish is applied between mullions on to plastic, as it do only imitate old glazing. The idea is from Karl, I was impressed by his windows of Bonhomme Richard model.
Alexander
Hello Alexander,
obviously the whole MSW Forum had to break down before i recognized your build log. What a beautiful ship you are building. How clean and accurate work. I will surely follow your build from today on. Not only because we might be neighbors obviously....;-)
Regards from Dossenheim
Harry
'Tag Alex,
Thanks for taking the time to upload the excellent photos of your work. What a shame that all your earlier work was lost. They show the quality of work that we should all try to achieve. Please tell us how you attached the monograms to the gun barrels. I suppose the monograms were photo etchings of thin brass sheet?
Peter :rolleyes:
The arches and windows look excellent as does all of the ship. Keep the post and pictures coming, I am watching this one all the way.
Wacko
Joe :D
Go MSW :) :)
This has always been one of my favorite builds to follow.  Thank you for taking the time to repost.
Toni
Member IPMS
                           Utrecht-1742
Thank you Harry, Gregg, Peter, Joe and Toni! I very appreciate your comments!
Hi Harry, warm welcome and hope to see your build log soon here, It's Kit or Scratch?
Hi Peter, the monograms are glued with CA glue to barrels, I have describet this here: http://modelshipworld.com/index.php?/topic/410-hms-sphynx-by-alex-m-scale-148-english-20-gun-frigate-as-build-1775/page-2#entry5559, pictures from 13 to 16.
Alexander
Hello,
Before I begin to install all guns, and work further with beams and knees for quarter deck, gun port lids must here. So the production of hinges, the lids itself are made earlier. I hope, the images are self explainable.
The installation of hinges and lid tackles.
After I have installed all lids, I have made blanks for channels, shaped them to right size and thickness, and installed them (only dry now).
To be continued
Alexander
Hello,
the next task is to make deadeyes. I have tried to photograph each step, and hope the images are self explainable.
One end rounded with "truck tool"
Turned and cutted
Holding tool for drilling
Truning of the holder
The first deadeye
One side done, shaped witn fine grind paper
Ready deadeye
And here are these
This was the last post from me before crash, so the re-building of the log is now done.
To be continued
Alexander
Edited by Alex M
Alex,
Just an awesome build.  Beautiful work and detail.  In particular, really liked the jig for the breeching rope and the way you installed the breeching rope around the cascabel.
Dave :)
Hello,
here the making of chain plates for deadeyes, step by step in images.
To be continued, now in real time :)
Alexander
Edited by Alex M
Hi Dave,
thanks for warm words!
Alexander
Thanks you Greg and Joe!
I will not solder the joints, because I would not rig the Model. The little angled part is put in to hole driven in the channel, is covered by decorative moulding and not visible.
Alexander
