Very well done JP, I for one think you've done an excellent job on the hull planking, shows what patience and a will to learn will give great results in the end.
I look forward to see how you whitewash turns out, just remember as always to test on scrap wood before you commit it to the hull, just to be sure you like the effect.
Ben
looks like I would think  'taper'..........looks like it narrows toward the bow stem
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
All I can saw is wow. As for the color options, I feel like a student telling the teacher what to do. I know the basswood is tough to stain. Keep up the good work!
Eric
Current build(s) ;
AL San Francisco II
http://modelshipworld.com/index.php?/topic/862-san-francisco-2-by-eric-al-190-sport29652/
MS Rattlesnake
http://modelshipworld.com/index.php?/topic/868-rattlesnake-by-eric-model-shipways-164-sport29652/page-2
Sitting on the shelf : MS Constitution, MS Sultana,
Wish List : MS Essex, Confederacy, and Syren, and a Victory kit by someone ?
"80% of the time it works every time."
JP, great job!! I am even jealous-er now. And no, I would never let jealousy lead to destruction, thats too much like destroying a book or art. It gives me/us something to strive for. As far as your color, have you considered one of the Watco Danish oils or perhaps a dark or ruby shellac? Rockler has these in flake form. There is always the option of a washcoat of clear before you stain. Whatever you choose with the patience and resolve you have shown with your planking I have no doubt your going to end up with a model you can be very proud of.
Current Build Constructo Enterprise
JP,
Great work on the planking. Her hull looks rather 'smashing' ;) . I like the idea to make a reference for future builds to fall back on!
Carl
Ahoy Mates :D
Thank you all for your encouraging words
Ben: Getting consistent results has been very difficult for me. Some tests come out great; others look like “hell”. I really want to avoid a crapshoot when I do my hull and continue to try to refine my technique. The wood has not been very helpful.
Popeye: The problem in the stern is they taper, and then flare. It has been a difficult area  for me to plank.
 Eric: Anything you have to offer, especially when it comes to finishing would be greatly appreciated. I am not the teacher, just the guy who does his homework.
Ferit: This would be true if I had your skill. Currently I am on a ship called ‘persistence”.
Sam: I looked into darker stains you mentioned. I can not however get Basswood to take them in anyway that would be considered acceptable.
Carl: I have found that for me to write them down I have to properly work out the steps. This is the biggest benefit for me
Back to the build:
It should be noted that my “brute force and superstition” to get that last two planks in at the same time method might need to be rethought. I had what only could be considered a mild disaster. The last two planks would not go in all the way where they met the stern post; glue spread everywhere including the starboard side. It was not a good day in the shipyard, fun ran out of the room like it was on fire. It was a kick in the ars to say the least but thankfully in the end, repaired with some creativity. Only one pic, I was a little too busy at the time for them. :P
On the bright side, this did result in an interesting way to fill seams on basswood planks. Comments welcome
First, I apply painters tape to both sides of the offending seam, then use a cut toothpick to trough PVA glue into it (like when doing sheetrock). Remove the tape, then use a paper towel moistened with alcohol to clean up any glue outside the seam (very important). Heat with RC heat gun to dry the wood, then sand the area forcing dust into the seam. When done blow off excess and liberally wet area with brush.  I will post pics if there is any interest.
Edited by JPett
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
interesting way of doing this ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Ahoy Popeye :D
If you are talking about the pic "there is an explaination" lol
If your referring to the seam filling, It was the only way I could come up with that did not stain the Basswood. Stuff is like a sponge
  J.Pett
I use that method of seam filling sometimes.    I quite agree with you about the way basswood sucks up stain........I have pidctures of the Susan A  that tell the story............light stain............very light stain :)
no need to explain about the ship in the closet............I keep skeletons in mine  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
JP,
You're doing great.  Your persistence is paying off.  Yes, planking is a bear but it looks like you're one of the masters.
Hold on -- have you confused your Ratt with your coat?
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Ahoy Mates :D
Thank you all for coming to my planking party, “last call for planksl”
Mark: If I am a master, it is of listening to others like you. Thank you, your log has been very helpful.
Martin: not all of us can afford mink.
Back to the build: :pirate41:
The last plank on my hull was installed last night. I started planking on 01/10/13 and finished 05/06/13. There was a three-week interlude and I estimate it took me no less then 120 hours to plank this hull (Best guess is 150). As much as I found planking a very enjoyable experience, I am glad to be done. The last plank went in without any resistance, which was nice; the second to last took six attempts to fit.
As for planking the Ratt, please find below my overview/notes.
1) Mark the entire hull as per the planking practicum here on MSW. This work, which I called Ratt-Lines, was long, tedious, and boring as hell when I did it: I will do this with more enthusiasm next time because now I know how much work it saves.
2) Double, triple and quadruple check the fillers before starting. Especially in the stern. Once you commit it takes ten times longer to correct any problems here. The planks need to run up to the stern post and counter. Not make sharp turns into them. Test, test, test, then check them two more times. While were here the battens you use to test the fairing of the bulkheads must be right. Do not proceed unless you are good here.
3) Spiling is a must. I fought it and in the end, this was a mistake. Yes, it is more work and the learning curve is a little steep, but once you make sense of it, it really is not that big a deal and actually easier in the long run.
4) Where the planks turn up in the stern requires some difficult bends and the planks need to twist. For me, this was the most difficult part of the hull to plank. The planks also taper then flare out here. Run all these planks long, combing two plank lengths into one worked best for me. This can apply to the bow too. For this reason work towards the mid section coming at it from both ends, not from stern to bow or bow to stern. Fitting planks in the middle section are the easiest and should be done last.
5) Unless fitting; if possible all planks should be soaked and dried “long”, cut to the correct length only just before gluing them. Cutting them short here really hurts too, so measure twice.
6) Just throw away the bad planks and start again. Yea it hurts when you spend an hour on one plank and it is not right, but realize that you will look at it forever if you put it on. Basswood is cheap.
7) I soaked all my planks and allowed them to dry on the hull. I avoided having to forced them to make a bend or twist when it came time to glue them. Fitting the planks this way was slow but it allowed me to make sure the plank was right before I glued it in. It also made gluing much easier.
8) Do not forget to give yourself a break. Getting aggravated because of a mistake or problem only takes away from the experience. I had to walk away a few times. Planking was a very long process for me and I chose only to enjoy it.
Sorry “no Pics”
She is in the spa, getting all pretty for her reveal :P
Edited by JPett
  J.Pett
Hey Jp,
 Your hull turned out very well. Hull planking I enjoy very much. it offers a great challenge for me. I don't find it a pain. But then again i enjoy ratlines too. Maybe I'm weird....
BUT JUST LOVING YOUR PROGRESS JP......GOOD GOING
Thank You all...
Mario
:piratetongueor4:  :piratetongueor4:
"Each of us is a mixture of some good and some not so good qualities. In considering one's fellow man it's important to remember the good things ... We should refrain from making judgments just because a fella happens to be a dirty, rotten SOB(biscuit) ;) "
My Builds....
BETTEAU WAR OF 1812     BOUNTY LAUNCH(bashed)    CHESAPEAKE BAY FLATTIE
THE SEA of GALILEE BOAT   VICTORIAN STEAM LAUNCH(bashed)    HOWARD CHAPELLE's CRABBING SKIFF
LADY KATHRINE 1812 SCHOONER
JP,
We're holding our breath for pictures...   Rats... I'm soundling like someone else we know. :o
As some fictional character once said:  "Patience, Grasshopper".  Both in planking and waiting for pictures, I guess.
Let me see, let me see, let me see!!!!!
“The World is a book, and those who do not travel read only a page.” - Augustine
Artesania Latina San Francisco II 1:90 Scale
On the Shelf:
Model Shipways Armed Virginia Sloop 1:48 Scale
Good comments in your planking experience JP, it would seem you have learnt all of the major pitfalls, experiences and techniques of planking a hull properly and well, very proud of you for sticking with it, your next model will be a totally different experience because you know what to expect and will want to exceed the quality of your first build.
Congrats again man on this milestone.
Ben
Hey JPett -- those 8 comments you list should be reviewed by everyone getting ready to set plank to hull.  It's good to read a slow and steady modeller's reflections.
Cheers and bring on the cheesecake!
Martin
So I'm lost or just mad, probably both actually. Why is the Rat in the closet. Is this your way of giving it a time out? :D
I've used the PVA and sand technique also, I used it on the keel/stem post scarf joint with cherry to help fill my poor cutting/shaping skills and it worked quite well even with this hard wood. I typically clean with H2O, is there a benefit to alcohol, and do you use isopropyl or ethanol?
So the last planks are in and no pictures, Is it still serving time in the closet for being bad?
Can't wait to see her in all her glory.
I too found it interesting how the twisted section in the stern required a thinning/narrrowing of the planks and then a flairing at the stern post. You should label your 8 steps as the Zen of planking, I found nearly every step true with my Swift planking. Especially the importance of soaking and allowing them to dry on the hull, Sometime multiple times to get the curvature/twist just right. Oh I was going to ask what you used for plank narrowing. I found the small HF block plane invaluable in doing this for roughing in the shape, then lots of sanding.
So until we have photographic evidence that the plankings comolete, I guess we'll patiently wait, just like waiting for a plank to dry.
Ahoy Mates :D
Sorry for the delay, BUT
As we all know the ladies can take some time to get ready :P
After much deliberation, testing, posts and some beer, well maybe a lot of beer,  I have decided to let the lady show some skin. Many hours of testing only confirmed that for this build “not staining” would be my best move. After wiping down the hull with mineral spirits I found that this “look” suited my lady better then any other.
Thank you all for your patience and help on my build. I would have never reached this point alone, “Really” Thank you, (place bowing emoticon here)
Back to the build:
Using Buck’s suggestion to make patching dust with finer grade sandpaper I came up with Basswood Patch Mk2. The finer dust was collected and then water added. About five times as much as needed. The dust was then allowed to ‘soak’. After which I stirred in a very small amount of PVA glue. Then I put drops on areas I needed to fill. The surface tension used to keep the mixture in place. It usually took three to four applications to fill a small void.
As for the Sanding gala. I used an eraser as my sanding block. It was one of those moments when you look at something completely unrelated to the task and say, Hummm.
The finish so far is one coat of “General Finishes” satin Gel Topcoat wipe on Urethane thinned with mineral spirits. I want to paint the wales black and keel tallow, and then I will put on a few more coats of Poly: Oh yes, and a million more treenails
Suggestions, comments welcome and “again” thank you MSW :)
Edited by JPett
  J.Pett
I'm flabbergasted ... A marvelous, stunning job JP!!! What else is there to say ...
Carl
Wow! That looks amazing. I'm glad this thread exists; knowing I can go back and read it will bolster my confidence when it comes time to planking my own Ratt.
there you go.....you nailed it!   well worth the effort.......I'll be right back........I gotta go hang my hull in the closet!
splendid job........superb in every way!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
