Hi All,
I'm about to start my second kit, and want to avoid some of the disasters of the first one.  Last time I just got some balsa blocks to rest the upside-down carcass on during construction, but surely there's a better option?
What is your preferred method of supporting the model when planking?
Thanks - and Merry Xmas!
Brett
Edited by ortho85
Hi Brett.
I have kept mine in the keel clamp which is on a ball and socket joint.( Small boat )
Do the hull planking before adding any detail to the deck's including deck planking.
Mount the upturned hull onto a board tempeary while planking.
You could use some false masts fixed to a board.
I am sure ther will be many more good suggestions come forward :)
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Hi Antony,
How's the West in Winter?
Did you buy or make your keel clamp?
I like the idea of the board with false masts - thanks for that.
Cheers,
Brett
I use several methods. To plank while the hull is in normal position, I use a hull planking vise. To work on the undersides of the hull, I use some paint roller covers to support the upside down hull. I sometimes just use my lap.
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
I am using a Triple Duty Foam Cradle for Model Ships that I bought from MicroMark (Item #: 85819)... about $19. It is very flexible with two removable sections that allow it to fit most boats and use in many positions. I have found it very adaptable to most work from planking to painting.
The only thing I used a vise for was the original framing of the bulkheads. There I wanted something that held the full length of the keel to help keep it straight. I tried the ship clamp sold at Model Expo, and it was ok, but found the vise on my workbench was even better for that.
I also read from one of our members about using a sock filled with rice. Sounds like a much cheaper and more flexible answer.
Richard
Richard
Member: The Nautical Research Guild
Ahoy Brett :D
I started with a Panavise. I owned it, but they sell for les then 30 dollars at Frys. It worked great. I have since purchased an Amati Keel Clamp which while more then twice the price is very nice.
I don't know how some of these guys planked without the keel securely mounted but I guess they proved it is possible
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Ahoy Brett :D
I use the Panavise a lot for almost all the rigging operations, holding small parts such as blocks and a multitude of other tasks, but not to hold the frame during planking. While planking, the hull of the model has to be in the up-side-down position and clamping the keel is not practical. After all. the planks have to go around the keel as well.
I rested mine on several layers of old towels. The rail along the sides, the rail on the stern and part of the bow supported the hull with the tip of the bow hanging over the edge of my workbench.
Jay
Current build Cross Section USS Constitution  http://modelshipworld.com/index.php/topic/10120-cross-section-forward-area-of-the-uss-constitution/
Finished USS Constitution:  http://modelshipworld.com/index.php?/topic/103-uss-constitution-by-modeler12/
'A picture is worth a  . . . . .'      More is better . . . .
Ahoy Modeler :D
It worked great for me
I guess it depends on when you do your deck
Edited by JPett
  J.Pett
I built foam rubber cradles out of swim noodles with a broom handle it the center hole to cradle the hull in all its crazy angles during planking. There's a picture of them on my build log. I use three of them, but remove the center  one when I want a perfectly upright model. I use all three when I want it upside down laying on her deck. Someone thought they looked like rolling pins from my wife's kitchen. They gave me ( and continue to give me) a soft, well supported system no matter what angle I'm working on. When I start the topside and rigging, I'll make something more sturdy.
Ahoy Modeler :D
Looks good JPett. That goes to show how versatile that little vise is.
Jay
Thanks for all the answers.  I like the "bean bag" type.  We have a wheat filled heat pack that will be perfect.
The foam looks good, but shipping to Australia??
I have found the Panavise at Hobby Tools Australia - so I may have to buy (yet) another tool!
Cheers,
Brett
Cheers,
Brett
Go for it! There is no such thing as "too many tools". :)
Instead of swim noodles, most hardware stores sell lengths of foam pipe insulation in various diameters which also have a hollow core if a broom handle dowel is to be inserted.
I have my little vise mounted on a 'portable workbench' and use it often with various hand tools.
Jay
I use a variety of foam shapes I have made up over the years.
Any furniture upholstery shop has mounds of foam pieces in all shapes that
should suit your needs.The shop I used was glad to get rid of the pieces.
Mike
How about a link to that cradle
  • 1 year later...
I do this as well but use the foam that is used to protect computers. It is thicker and there are less air bubbles. At work there is always someone getting a new computer and last year some got new laptops.
Marc
Current Built: Zeehaen 1639, Dutch Fluit from Dutch explorer Abel J. Tasman
Unofficial motto of the VOC:
"God is good, but trade is better"
I planked my Badger (both plankings) on my lap, and the first planking of my Pegasus in my lap.  I might just do the Pegasus second planking in my lap, but I've been thinking of using my Amati keel clamp for the upper second planking, and my Panavise for the lower second planking (when I flip the ship upside down).
My preferred support when planking is single malt whisky.
Hornet
             Current Build: - USRC Harriet Lane - Model Expo.
             Completed Ship Builds:   Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
Hi,
I use two types of support for planking.
Foto 1 This is simplest way for support hull during planking
            Can be difficult to use with some kit buildings because they have integral deck as part of structure.
Foto2 - 4 Revolving jig for hull planking
               For models scrap built is possible easily apply temporary brackets on bow and stern part of keel for attach to jig.
Tadeusz
Hi,
Tadeusz
I did something similar to your 1st photo. I just used two 2x4 uprights, slotted with a dato, to fit the keel board, then, mounted those 2 uprights on a 3rd 2x4, and clamped the setup in my homemade board clamp. It was really sturdy and worked well. It worked a lot better then my planking abilities.post-17674-0-88199500-1427334993_thumb.jpg
  • 4 years later...
Well now I gotta build one of those portable work surfaces too...  My wife got me the Syren for my birthday, I've been having so much fun compling tools and supplies and reading other build logs... I wonder if i"ll ever get around to building the kit?
Hi Brett, for something left of field, I used a combo of a hull/clamping vice and pool 'spaghetti' :)  The latter is cheap, works well and even allowed me to transport the model (even with the masts and rigging)  with no problems at all.  The slots allow the hull to be restrained, but simply lifting the hull you can lay it at any angle on the foam without damage to the planking etc.  The sides and length can be adjusted as needed; and the round holes to accept the longer side pieces are precut, but it is easy to make new ones.  I was lucky that the precut holes worked for me at 1:64.
This is my Endeavour being rigged (top) some years ago, and being held by the keel clamp.
114102801_Endeavour26Dec15.thumb.JPG.6cf4bc2fa90eb73e6591e59e5012e93d.JPG 1971465833_DeadlightsFittedStern.thumb.JPG.5ef7d246184de7193709a5e100e32cfc.JPG
Edited by BANYAN
