Floyd, Jeff,
Ships curves were developed for drafting/fairing ships lines plans.  Their formilation gives a better fit with the shape we run into as ship model builders.  A full set of 156 curves is hard to find and expensive, but you can find a selected set of 6-8 curves for a reasonable cost on the internet.
For cutting pieces to shape, I use a few ships curves almost as much as a steel straight edge.
Regards,
Pete
Edited by Pete Jaquith
Pete Jaquith
Shipbuilder
Greetings Peter,
Your model is very nice. You may want to consider making a companionway to provide access to the cabin. The plans show two doors in the bulkhead that would be about 2' high according to scale. I think this is a mistake on the original model and has carried through to the MS plans. On my FA, I added an appropriately sized companionway.
wq3296
WQ3296 - The has also been some conjecture that the quarterdeck is in reality a Bermuda deck, fully removable for fair weather, and that the small space may have been used for storage. One day Grant Walker, of the Naval Academy Museum, will take a look inside their model and see what lies within but's it not a priority for them.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
  • 4 years later...
The 14 Gun Brig Fair American, circa 1780 is based on Model No. 60 of the Henry Huddleston Rodgers ship model collection at the U.S. Naval Academy Museum, Annapolis, Maryland.  The model is representative of many of the small ships used as privateers during the American War of Independence.  The brig Fair American had a length of 68’ 0”, beam of 24’ 0”, depth of 8’ 0”, and tonnage of 130 tons.  The model is based on the Model Shipways Fair American kit developed by Erik A. Ronnberg, Jr. and updated by Ben Lankford.  The model is plank on bulkhead construction at 1/4” to the foot scale (1:48) with single planking and scratch built details/fittings.  I made a number of changes in both model design and construction sequence and these were discussed in my earlier posts.
My Fair American build has been in layup (storage) since 11/2011 due to conflicts with my consulting and full size shipbuilding projects.  After working a number of full scale shipbuilding projects in the US and Canada and two home moves, I am now starting to resume my model shipbuilding.  My shop/residence has moved from Hancock, NH to Indio, CA.  My shop in Indio is located in my garage where summer temperatures limit construction to the morning hours.  As I am still busy with several consulting projects, there may still be a need for short breaks in my construction activities.
Note: This is a restart of my earlier 14 Brig Fair American build log posted in 2014-2015.  The actual construction work on this model was started in 2011.
Regards from the shipyard,
Pete Jaquith
Pete Jaquith
Shipbuilder
After surveying my 14 Gun Brig Fair American of 1868 build (in storage since 2011); I was pleased to find it survived with a minimum damage.  As a result, I will restart the build log with planning and installation of lower hull planking (Note that I will repeat a few earlier posts in-order-to provide continuity).  Planning and for lower hull planking included the following:
a. Layout Planking Belts – The lower hull will be single planked with 1/16” basswood.  After examining the hull girths at alternate bulkheads, the stem, lower counter, and stern post; an amidships plank width of 3/16” or 9” was selected.  After laying out the garboard and 1st broad strakes, the remaining hull surface was divided into four planking belts.
b. “A” & “B” Belts – “A” and “B” Belts, the 1st thru 8th strakes below the wales, will be ~9” wide amidships tapering to ~4.5” wide at the stem and ~7.5” wide at the counter.
c. “C” & “D” Belts – “C” and “D” Belts, the 9th thru 16th strakes below the wales, will be ~9” wide amidships tapering to ~6” wide at the stem growing to 13-15” wide at the stern post.
d. Garboard & 1st Broad Strakes – The garboard and 1st broad strakes will be wider than the normal amidships plank width, being 12” and 10.5” wide amidships respectively.
e. Table of Hull Planking Butts – The Table of Hull Planking Butts was adjusted to reflect the addition of the above planking belts.
f. Planning for Hull Planking – The hull planking arrangement and planning were developed using the guidelines outlined in the book “Planking the Built-Up Ship Model” by Jim Roberts, available from Model Expo.
Pete Jaquith
Pete Jaquith
Shipbuilder
With planning for the Brig Fair American lower hull planking complete and some initial planking started; the following points describe the planking sequence:
a. Garboard and Broad Strakes – The garboard and 1st broad strakes were the first planks installed.  Due to their shape, they were fabricated from sheet stock.  These strakes were wider than the normal amidships plank width, being 12” and 10.5” wide respectively.
b. “D” Belt Strakes #13-16 – The first four strakes above the broad strake (#13-16) were the next strakes installed.  Due to their shape, the fwd/aft planks were fabricated from sheet stock.  These planks are ~9” wide amidships tapering to ~6” wide at the stem and growing to ~15” wide at the stern post.
Next steps include: (a) complete installation of “A” Belt, the 1st four strakes below wales (#1-4); (b) install “B” Belt, the 2nd four strakes below wales (#5-8); and, (c) install “C” Belt, the middle four strakes (#9-12).  Note that lower “C” Belt strake (#12) will be the closing strake.
Pete Jaquith
Pete Jaquith
Shipbuilder
Working along on the Brig Fair American lower hull planking.  A" Belt Port, strakes #1-4 below the wales, is nearing completion.  Bow and stern planks are splined and cut from sheet stock.  I will post pictures at significant milestones.
Pete
Pete Jaquith
Shipbuilder
Work continues on lower hull planking.  With the Brig Fair American garboard and broad strakes and lower “D” Belt complete; work proceeded on “A” and “B” strakes:
  • Completed "A" and "B" Belts Port - Completed the 1st eight strakes below the wales port.  These planks are ~9" wide amidships tapering to ~4.5" wide at the stem and ~7.5" wide at the counter.  Due to their shape, the fwd/aft planks were fabricated from sheet stock.
My planking techniques included the following:
  • Four planking belts were laid out and faired considering the maximum plank
  • Shaped fwd/aft planks were cut from sheet stock using paper templates
  • Plank width was determined/confirmed using proportional dividers
  • Planks were cut using a single edged razor blade and ship’s curves
  • Final sanding will follow completion of lower hull planking
Next steps include: (a) Install “A” and “B” Belts Stbd., (b) install “C” Belt, the middle four strakes.  It is planned that lower “C” Belt strake (#12) will be the closing strake.
Pete Jaquith
Added pictures
Pete Jaquith
Shipbuilder
With the Brig Fair American lower hull planking belts "A" and "B" Port, and "D" Port/Stbd. complete, work continued on lower hull planking:
  • "A" and “B” Belt Strakes #1-8 Stbd. – Completed the first eight strakes below wales (#1-8).  These planks were ~9” wide amidships tapering to ~4.5” at the stem and ~7.5” wide at the counter.  Due to their shape, the fwd/aft planks were fabricated from sheet stock.
Due to high temperatures in the shop (garage) during the afternoon and evening, I am currently only completing 1-2 plank strakes per day, however the end is in sight.
Next steps include: (a) install “C” Belt P/S, the middle four strakes.  Note that lower “C” Belt strake (#12) will be the closing strake.
Pete Jaquith
Pete Jaquith
Shipbuilder
Looking good !
Dwight
current build : Fair America by Model Shipways
Completed Build : 18th Century Armed Longboat by Model Shipways Armed Virginia Sloop by Model Shipways
Under the bench : Syren by Model Shipways ,, Rattlesnake by Model Shipways
The FA is on  my to-do list for a semi-scratch build someday...  I have bookmarked your log,  It will provide inspiration and expertise.   Keep coming with the details!
― Jimmy Buffett
Slow crawl:    Rattlesnake
Thanks for your interest and likes.  After 7 years away I am now starting to get back into ship modeling.  Still have to sort of the rest of my tools and supplies but I am getting there.
The Brig Fair American is a good looking model, but the kit has problems (bulkheads don't fair, bulwark height, etc.).   I would not recommend it as a first build.
Regards,
Pete
Pete Jaquith
Shipbuilder
Hi Pete,
Your work is always an inspiration.  Are the plans inaccurate or just the cut kit parts?
Thanks, Greg
Greg,
Plan sections, elevations, and details appear to be slightly different scales.  Also, bulkheads were poorly cut and were often different P/S.  This requires great care be could be a frustration to new modelers.  This is part of the reason I added bass wood fillers between the FWD/AFT bulkheads.
Regards,
Pete
Pete Jaquith
Shipbuilder
I ordered the " Lauck Street Practicum " hoping that it wil lhelp clear up some of these problems
Dwight
With the Brig Fair American garboard and broad strakes, and lower “A”, “B”, and “D” Belt planking complete; a major construction milestone was completed:
  • “C” Belt Strakes #9-12 – The third four strakes below wales (#9-12) were the last strakes installed.  Note that lower “C” Belt strake #12 was the closing strake.  These planks were ~9” wide amidships tapering to ~6” wide at the stem and 13-15” wide at the stern post.
  • Fair Planking – After completion of planking (a major milestone), limited wood filler was used to fill a few open seams and the hull was lightly sanded using fine sanding sticks.
Lessons learned from hull planking include:
  • Layout of planking belts and strakes is key
  • Proportional dividers are great for dividing up planking belts
  • Shaped planks were cut from sheet stock using ships curves (I may try Chuck’s heat bending technique on my next project)
  • Fine sanding sticks from the beauty supply shop are great for fine tuning planks
  • Filling the forward/after hull bays with basswood blocks provided need planking support
  • Planks were edge glued with white glue – to date despite 7 years of storage and significant temperature and humidity swings from southern NH to the CA desert (60-100 degrees F and 15-90% humidity) I have not had any cracking or open seams.
Next steps include: (a) confirming pedestal fit.
Pete Jaquith
Pete Jaquith
Shipbuilder
With the Brig Fair American hull planking complete, the next step is confirming the pedestal fit.  The pedestals had been initially fitted to the keel subassembly.  At this point, they required minor adjustment to suit the hull planking.  This task was accomplished at this point to avoid the need for adjustment at completion.
Next steps include: (a) building a construction cradle.
Pete Jaquith
Pete Jaquith
Shipbuilder
Pete ,
Please forgive me but I'd like you to expand on post #16 where you " adjusted " the windows to fit the curve of the planking. I'm assuming you simply twisted the frames using the straight edges to hold them in place then pushed on one corner with something to get them to deforme. Is this the idea or am I way out in left field ?
Dwight
Thanks Pete , I figured it out myself. Sorry to interrupt. I used the jaws of my caliper as the two straightedges and a pr of needle nose to twist them. BTW , your Fair America looks great !!
Dwight
  • 5 months later...
With the Brig Fair American hull planking complete, the next step was building a construction cradle.  The cradle was designed to hold the hull upright with the waterline parallel to baseline.  The construction cradle was lined with peel-and-stick felt tape.
With hull planking complete, construction will now focus on external hull outfit.  The hull outfit sequence has been designed to facilitate painting and minimize potential handling damage.  Hull outfit prior to paint includes channels and gangway steps; dry fitting the quarter badges; chess trees, fairlead and hawse holes; catheads, knightheads, and timberheads; cheek knees, bleak head, and transom trim; and cutting the bowsprit notch.
At the same time, I also plan to fabricate and dry fit the bowsprit and start fabrication of deck furniture.  These assemblies will be held off for painting with their installation sequenced to ensure good access for cannon rigging.
Pete Jaquith
Pete Jaquith
Shipbuilder
  • 3 months later...
After a few months of full scale shipbuilding activities, I am returning the my "Fair American" build.  I am currently working on P/S hull attachments including channels, gangway steps, quarter badges, chess trees, and main/fore tack fairlead holes.  Description and pictures to follow.
My full scale activities included a recent SNAME/ASNE webinar on modern "Asian Warship Design, Production Engineering, and Construction Practice".  Over 500 attendees and many interesting questions, all in an attempt to influence USN design and acquisition practice.
Pete
Pete Jaquith
Shipbuilder
With the Brig Fair American hull planking complete, construction shifted to fabrication and installation of upper hull outfit.  The first zone handled was the P/S hull sides:
  • P/S hull attachments were laid out.
  • Channels were fabricated/installed from 3/32” sheet stock.  A spindle sander was used to shape the inner surfaces.  Deadeyes and chain plates will be installed after hull paint.
  • Channel caps were fabricated from 3/64” x 3/32” strip stock.  The channel caps will be installed after hull paint.
  • Chess trees were fabricated/installed from 3/32” x 3/32” strip stock.  Main tack fairlead holes were then drilled thru the P/S bulwarks.
  • Gangway steps were fabricated/installed from 1/32” x 3/32” and 3/64” x 1/16” strip stock.  They were assembled with the aid of double sided scotch tape.  The remaining steps will be installed after hull paint
  • Quarter badges were dry fitted to the hull.  Note that the windows still require framing out and the quarter badges will be installed after hull paint.
There will be many additional details added in this zone after paint: i.e. deadeyes & chain plates, channel caps, gangway steps, quarter badges & windows, and gunport hinges for the closed aft gunport.  Next steps will continue with upper hull outfit.
Pete Jaquith
Shipbuilder
With the Brig Fair American hull planking complete, construction continued with fabrication and installation of upper hull outfit. The next zone to be addressed was the bow zone.  Note that cheek knees, head rails, and head rail knees will be addressed later in the build:
  • P/S hull attachments were laid out in the bow zone (due to plan inaccuracies, I chose to lay out and check all bow attachments at this point).
  • Catheads were fabricated/dry fitted from 3/16” x ¼” strip wood.  The catheads are pinned in place with 3/64” dowels.  The catheads will be installed after hull paint.
  • Fore tack fairlead holes were drilled thru the forward bulwarks.
A few small steps in completing upper hull outfit.  Next steps will continue with the knightheads and timberheads.
Pete Jaquith
Shipbuilder
With the Brig Fair American hull planking complete, construction continued with fabrication and installation of upper hull outfit.  This work continues outfit of the bow zone:
Because of their delicate nature, knightheads and timberheads will be installed after cutting the bowsprit notch.  Catheads and their attached timberheads will be installed after hull paint.
Many fiddly little pieces here but it is starting to look like a real ship.  Next steps will continue with fabrication and dry fitting of the bowsprit, bowsprit bitts, and the jibboom.
Pete Jaquith
Shipbuilder
With the Brig Fair American hull planking complete, construction continued with fabrication and dry fitting of the bowsprit and jibboom:
  • Bowsprit was fabricated from 5/16” dowel stock.  The bowsprit was turned on my mini-lathe using fine standing sticks.  The eight sided square inner foot and the square outer end were shaped with a disk sander.
  • Jibboom was fabricated from 1/8” dowel stock.  The jibboom was turned on my mini-lathe using fine standing sticks.  The outer tip was shaped with a sharp razor blade and fine sanding sticks.
Next steps will continue with detailing the bowsprit and jibboom, fabricating the bowsprit bitts, and dry fitting the completed assemblies to the hull.
Pete Jaquith
Shipbuilder
